GUSTEL
The ALC882 series 7.1+2 Channel High Definition Audio codecs with UAA (Universal Audio Architecture), featuring five 24-bit stereo DACs and three 20-bit stereo ADCs, are designed for high performance multimedia PC systems.
The ALC882 series incorporates proprietary converter technology to achieve over 100dB Signal-to-Noise ratio playback quality; easily meeting PC2001 requirements and also bringing PC sound quality closer to consumer electronic devices.
The ALC882 series provide 10 channels of DAC that simultaneously support 7.1 sound playback, plus 2 channels of independent stereo sound output (multiple streaming) through the Front-Out-Left and Front-Out-Right channels. Flexible mixing, mute, and fine gain control functions provide a complete integrated audio solution for next generation multimedia PCs.
Features of Realtek High Definition Audio Driver :
• High-performance DACs with 103dB SNR are ideal for Dolby Master Studio
• ADCs with 90dBA SNR
• Meets performance requirements for audio on PC2001 systems
• 10 DAC channels support 16/20/24-bit PCM format for 7.1 sound playback, plus 2 channels of independent stereo sound output (multiple streaming) through the - Front-Out-Left and Front-Out-Right channels
• 3 stereo ADCs support 16/20-bit PCM format, two for microphone array, one for legacy mixer recording
• All DACs support 44.1k/48k/96k/192kHz sample rate
• All ADCs support 44.1k/48k/96kHz sample rate
• Applicable for DVD-Audio solutions
• 16/20/24-bit S/PDIF-OUT supports 44.1k/48k/96k/192kHz sample rate
• 16/20/24-bit S/PDIF-IN supports 44.1k/48k/96k/192kHz sample rate
• Up to four channels of microphone input are supported for AEC/BF application
• High-quality analog differential CD input
• Supports external PCBEEP input and built-in digital BEEP generator
• Software selectable 2.5V/3.75V VREFOUT
• Six VREFOUTs are supported by default, with additional four VREFOUTs available by sharing unused analog I/O pins
• Two jack detection pins each designed to detect up to 4 jacks
• Reserve analog mixer architecture for backward compatibility with AC'97
• Wide range (–80dB ~ +42dB) volume control with 1.5dB resolution of analog to analog mixer gain
• All analog jacks are stereo input and output re-tasking for analog plug & play
• Built-in headphone amplifiers for each re-tasking jack
• Supports both analog DC volume control and GPI digital volume control
• 2 GPIOs (General Purpose Input/Output) for customized applications
• Optional EAPD (External Amplifier Power Down) is supported
• Power support: Digital: 3.3V; Analog: 5.0V (Minimum AVDD is 3.6V)
• Power management and enhanced power saving features
• 48-pin LQFP lead (Pb)-free package
• Meets Microsoft WHQL/WLP 2.0 audio requirements
• EAX 1.0 & 2.0 compatible
• Direct Sound 3D compatible
• A3D compatible
• I3DL2 compatible
• HRTF 3D Positional Audio
• Emulation of 26 sound environments to enhance gaming experience
• 10 Software Equalizer Bands
• Voice Cancellation and Key Shifting in Karaoke mode
• Realtek Media Player
• Enhanced Configuration Panel and device sensing wizard to improve user experience
• Microphone Acoustic Echo Cancellation (AEC), Noise Suppression (NS) and Beam Forming (BF) technology for voice application
• ALC882D features Dolby Digital Live output for consumer equipment
• ALC882H features Dolby Home Theater software
• ALC882M features Dolby Master Studio software
Changes in Driver Package R2.40:
Realtek HD Audio Driver support all of Realtek HD Audio Codec.
1. Vista/Windows 7 WHQL Supporting: ALC882, ALC883, ALC885, ALC888, ALC889, ALC892, ALC861VD, ALC660, ALC662, ALC663, ALC665, ALC260, ALC262,ALC267, ALC268, ALC269, ALC270, ALC272, ALC273, ALC887,ALC670, ALC275, ALC680
2. Windows 2000/XP WHQL Supporting: ALC880, ALC882, ALC883, ALC885, ALC888, ALC889, ALC892, ALC861VC, ALC861VD, ALC660, ALC662, ALC663, ALC665, ALC260, ALC262, ALC267,ALC268, ALC269, ALC270, ALC272, ALC273, ALC887,ALC670, ALC275, ALC680
3. HDMI Device WHQL Support: ATI HDMI Devices
4. OS Supporting: Microsoft WindowsXP, Widnows2000, Windows Server
2003, Vista, Windows Server 2008, Windows7 - x86/x64
5. Pack with Microsoft High Definition Audio UAAV1.0a(5013)
6. Add/Fix
1.) Driver :
1. Customizations.
Link : Realtek High Definition Audio Driver R2.40
• A3D compatible
• I3DL2 compatible
6. Add/Fix
1.) Driver :
1. Customizations.
