• Achtung, kleine Regeländerung für User-News: Eine User-News muss Bezug zu einem IT-Thema (etwa Hardware, Software, Internet) haben. Diskussionen über Ereignisse ohne IT-Bezug sind im Unterforum Wirtschaft, Politik und Wissenschaft möglich.
PUBG- Monthly Patch - da geht was vorwärts
Pladdaah
HI miteinander,
da PUBG im Moment immernoch ziemlich "gehyped" wird , dachte mir ich verbreite hier mal die Patch-Notes. (5,3 GB sind es als DL btw.)
Hier hat sich einiges getan, aber seht selbst: :daumen:
Server Optimization:
Optimized fences, doors, and windows
Optimized vehicle physics
Client Optimization:
Optimized memory usage for world objects
Optimized terrain rendering
Optimized User Interface
New Items:
Added new weapon Mk14 EBR. Mk14 EBR is a Designated Marksman Rifle that can only be obtained from Carepackages. This weapon is chambered for 7.62mm and sniper rifle attachments
Character:
Added two new face presets and hairstyles to character customization for both genders
Gameplay:
Added 1st Person server options to NA and EU Solo and Duo game-modes
Players who choose 1st Person mode will be matched together
Character view is set to 3rd Person mode in starting airplane and during free fall from the airplane. This will be set to 1st Person only in a future update
Camera will stay still while looting items to prevent dizziness
Added a new feature to report players
Some people killed knocked-out teammates in order to avoid giving kill count to an opponent who knocked them down. Now the kill count will still go to the opponent in this specific case.
Added new animation when using different consumables Improved camera transition when disabling Free look feature (Alt Key)
Decreased the reload time of VSS
Players may now re-enter games if they have been disconnected mid-game
You may now play with Xbox controllers, and we will continue to make improvements with Xbox controllers
Sound volume difference from inside and outside of building is more obvious
Added new sound effect while scoping or aiming weapon
Added new effects when a character is running or sprinting over different types of surfaces
Improved character animation without any weapon or with melee weapon
Added slight delay when using the drag-and-drop feature on items in inventory UI. We implemented this delay to provide a fair gameplay environment to all players
Improved post-process effect when a character takes damage outside of the blue circle
Items and Vehicles:
Added a lower rail attachment slot to SKS
You may now honk a car horn when sitting in the driver's seat with Left Mouse Click
Decreased the chance of vehicle explosion after the vehicle gets stuck in objects
Vehicle driving sound will change slightly in FPP and TPP modes
Added new sound effects for motorcycle tire screech while driving
Eliminated firing delay of S1897 from pump action after reload
Improved effects of boats
Added spark effect to flat tires
Reduced cast time of First Aid Kit / Painkiller to 6 seconds
Reduced cast time of Med Kit / Adrenaline Syringe to 8 seconds
UI:
Added more features and hot keys to the Options Menu
Added new option for V-Sync
You may now designate a maximum of two different keys for each key bind
Added new option to set toggle on certain actions and features
You may now use Mouse wheel up/down as one of your key binds
Added new keybinds, such as all mute (Ctrl+M) and switching Voice Channel (Ctrl+Y), and a new option to adjust the volume of voice chat
Added new keybinds to use specific throwables
Added Colorblind Mode
Added an FOV slider for 1st person view
Added some region names to the mini map
Added new option to display helmet, vest, and backpack equipped on HUD UI. This HUD UI will be updated further in the future
Added new option to display all equipped weapons on the right side of the screen. This UI will be updated further in the future
Bug fixes:
Partially fixed client crash issues
Fixed an issue of weapons sporadically ceasing to fire despite being set to auto firing mode
You may not use consumables in vehicles underwater
Fixed bugs below while spectating another character
A character appeared to be shaking when the character moves around
Camera swing when a character scopes while walking
Camera swing when a character peeks left or right while scoping
A character appeared to be shaking when the player moves his mouse while scoping in Prone
Characters farther than 500m away from a vehicle will no longer hear the tire screech sound
Fixed post-process bug underwater in FPP mode
Fixed an issue of the reloading sound getting played repetitively after dropping a weapon while reloading
Fixed the probability of getting rainy weather to previous value
Fixed a bug where a character could not equip attachment with full inventory
Fixed a bug where weapons would continue to play looped reload animation even after canceling the reload
Fixed a bug where a character could see through the other side of wall when scoping or crouching against certain walls
Fixed a bug where a character sitting on objects inside of certain buildings could see through ceilings and walls
Fixed sporadic issue of disabling in-game UI
Eliminated bombing outside of Red Zone
und dann kommen noch die Neuen Kisten dazu - ja da freu ich mich schon drauf - dann rennen die ganzen Kiddies mit ihren gekauften bunten Sachen rum und sind einfach zu finden :lol:
Das spannenste Update (der "Gameplaychanger) lässt leider auf sich warten - kanns kaum erwarten endlich durch Fenster und über Mauern zu springen.
Quellen:
PLAYERUNKNOWN'S BATTLEGROUNDS
PUBG patch notes shed light on contentious paid crate system | PC Gamer
Gruß,
Plad
Booman90
Bin schon auf die 1st Person server gespannt. Denn immer aus sicherer Deckung über Mauern und um Ecken zu peeken, um dann kurz darauf n sicheren kill zu machen, ist doch schon manchmal frustrierend. Auch wenn man es selbst macht. :ugly:
joraku
PCGH-Community-Veteran(in)
Eben mal First Person getestet. Echt ein anderes Gefühl wenn man auf die Ansicht beschränkt ist. :D
Aber die Server sind entweder überlastet oder haben das Server-Update nicht vertragen. Starke Lags, DeSyncs und ab und an schmieren sie einfach ab. Also macht euch keinen Stress - da muss noch ein Hotfix nachgeschoben werden. :)
Es gab übrigens noch einen Client-Patch von knapp 500MB den man noch laden muss nachdem man das große Update gezogen hat. ;)
