[MB] DFI LAN Party P35 T2R ***Sammelthread***
jign
Dfi LANParty P35 T2R
***sammelthread***
P35 T2R
I. Allgemeine Infos zum Chipsatz
- Unterstützt Core2Duo/Quad (65nm/45nm) (1066Mhz/1333Mhz)
- Heatspreader auf der Northbridge
- Southbridge ICH9R
- Unterstützt PCIe 2.0 für Grafikkarten
- Unterstützt PCIe 1.0 für andere Erweiterungskarten
- Unterstützt DDR2 und DDR3 (wahlweise oder gemischt)
II. Technische Details zum Board [DFI P35-T2R]
# LGA 775 socket for: - Intel® CoreTM2 Quad, Intel® CoreTM2 Extreme, Intel® CoreTM2 Duo, Intel® Pentium® D or Intel® Pentium® 4
# Supports Intel Enhanced Memory 64 Technology (EMT64T)
# Supports Enhanced Intel SpeedStep Technology (EIST)
# Supports Intel Hyper-Threading Technology
# Supports 1333*/1066/800MHz system bus speed *Available only on CPUs that support 1333MHz FSB
Chipset
# Intel® chipset - Northbridge: Intel® P35 Express chipset (with Intel® Fast Memory Access technology) - Southbridge: Intel® ICH9R
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 533/667/800 MHz
# Delivers up to 12.8Gb/s bandwidth
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered x8 and x16 DIMMs
BIOS
# Award BIOS
# 8Mbit flash memory
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-LAN and Wake-On-Ring
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/Northbridge temperature and overheat alarm
# Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
Storage
# Intel ICH9R chip - Intel Matrix Storage technology - Supports up to 6 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1, RAID 0+1 and RAID 5
# JMicron JMB363 PCI Express to SATA and PATA host controller - Supports up to 2 UltraDMA 100Mbps IDE devices - Supports 2 SATA devices - SATA speed up to 3Gb/s - RAID 0 and RAID 1
Audio
# Bernstein audio module - Realtek ALC885 8-channel High Definition Audio CODEC - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
# DAC SNR/ADC SNR of 106dB/101dB
# Full-rate lossless content protection technology
LAN
# Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IEEE 1394
# VIA VT6307
# Supports two 100/200/400 Mb/sec ports
Rear Panel I/O Ports
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 IEEE 1394 port
# 6 USB 2.0/1.1 ports
# 2 RJ45 LAN ports
I/O Connectors
# 3 connectors for 6 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 connector for an IEEE 1394 port
# 1 connector for the Bernstein audio module
# 1 front audio connector (on the Bernstein audio module)
# 1 CD-in connector (on the Bernstein audio module)
# 1 S/PDIF connector (on the Bernstein audio module)
# 1 IrDA connector and 1 CIR connector
# 8 Serial ATA connectors
# 1 40-pin IDE connector and 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 6 fan connectors
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Expansion Slots
# 3 PCI Express x16 slots (PCIE1 at x16, PCIE3 at x4 or x1 and PCIE4 at x1)
# 1 PCI Express x1 slot
# 3 PCI slots
PCB
# 6 layers, ATX form factor
# 24.4cm (9.6") x 30.5cm (12")
III. Tipps/Tricks und Problemlösungen
CPUz freze beheben *klick* (ACHTUNG funktioniert nicht immer)
IV. Sonstiges
- Kleiner bench Vergleich zischen DFI P35 und Gigabyte p35 DS4: klick
- Aller Wahrscheinlichkeit nach kommt dem nächst eine Version ohne HP Konstruktion also nur mit normalen (schwarzen) passiv-Kühlern, der Preis wird dadurch Wahrscheinlich um 40 geringer ausfallen.
- ACHTUNG: Das bord verweigert offenbar gänzlich seinen Dienst in Verbindung mit einem Enermax Liberty 620w
V. Impressionen
*klick*
*klick*
VI. Layout [DFI P35-T2R]
http://bernd.czerrahn.de/gallery/albums/userpics/10001/LP_UT_P35-T2R.jpg
VII. OC Liste
VIII.RAM Liste
Team Group Xtreem PC2-6400 DDR2-800 [4 Riegel getestet]
Cellshock DDR2 1150 CL5 (CS2221650) mit Micron D9GKX [4 Riegel getestet]
Crucial Ballistix DDR2 800 CL4 mit Micron D9
IX. Downloads/Links
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS: klick Oder offizielle DFI beta site: klick
IV. Geizhalslink: klick
V. DFI LANparty X38 Sammelthread klick
AW: Dfi LANparty P35 T2R ***sammelthread***
Willst du mir netmal schnell messen wie hoch der Mosfetkühler is? Möchte das Board kaufen, brauch aber das Maß :)
AW: DFI LAN Party P35 T2R ***Sammelthread***
Auf der einen Seite 38,1mm (oben), auf der anderen Seite 38,3mm (unten)
Das ist ein spawa kühler ;) die mosefets sind unter den 2 kleinen Kühlern neben und unter den RAM-Bänken
Aber nun mal die gewünschten Maße: 4,1cm
Und auch hier die Frage, bietet das MoBo 3 USB Pin Header und ein Firewire Header?
Mosfets sind Spawas :p
Aber danke für die Maße, damit rettest du mir den Tag. Denn mit 4,1cm hohe sind sie dem HR-11 nicht im weg :D
Hat jemand schon erfahrung mit dem Board oder gibt es irgendwelche Testberichte?
Haben tun es schon einige offizielle Tests gibt es afaik noch keine aber ne menge user-Berichte, kannst auch mal den thread im luxx durchsuchen der ist schon recht voll.
Wenn du aber ne spezielle Frage haben solltest immer raus damit :D
Zitat von jign: Haben tun es schon einige offizielle Tests gibt es afaik noch keine aber ne menge user-Berichte, kannst auch mal den thread im luxx durchsuchen der ist schon recht voll.
Was meinst du mit luxx??:confused:
Der is ja schon auf 45 Seiten angeschwollen - na gut, frag ich da auch mal ;)
@jign: Wäre nett, wenn du die Luxx-Sammelthreads auch verlinkst :)
weiß jemand ob bei dem Board die grünen steckplätze so UV flourozierend sind? Ich hab ein DFI Lanparty UTnf4 ultraD und bei dem leuchten die gelben steckplätze in verbindung mit einer UV-röhre.
Normalerweise sind die auch UV aktiv. War bisher bei jedem LANparty UT so
PS: Meins wurde grad verschickt :D
