Mainboard für Intel Pentium G840 Sandy Bridge 2.8GHz LGA 1155 65W
Hallo
Ich habe diesen CPU herumliegen und suche passendes, gutes ATX Mainboard:
Ich suche wirklich was gutes und kann etwas mehr Geld ausgeben, bis ca. 150.- Euro.
Und wie findet Ihr AsRock Z77 Pro4, Z77, LGA1155, PCI-E 3.0, CF, ATX?
Hallo
Code:
Intel Pentium G840 --------------------------------------------------------
[General Information]
Processor Name: Intel Pentium G840
Original Processor Frequency: 2800.0 MHz
Original Processor Frequency [MHz]: 2800
CPU ID: 000206A7
CPU Brand Name: Intel(R) Pentium(R) CPU G840 @ 2.80GHz
CPU Vendor: GenuineIntel
CPU Stepping: Q0
CPU Code Name: Sandy Bridge-DT
CPU S-Spec: SR05P
CPU Thermal Design Power (TDP): 65.0 W
CPU IA Cores Thermal Design Current (TDC): 113.5 A
CPU GT Cores Thermal Design Current (TDC): 35.5 A
CPU Power Limits (Max): Power = 84.00 W, Time = 1.00 sec
CPU Power Limit 1 (Long Duration): Power = 65.00 W, Time = 1.00 sec [Locked]
CPU Power Limit 2 (Short Duration): Power = 81.25 W, Time = 0.00 sec [Locked]
CPU Type: Production Unit
CPU Platform: Socket H2 (LGA1155)
Microcode Update Revision: 28
Number of CPU Cores: 2
Number of Logical CPUs: 2
[Operating Points]
CPU LFM (Minimum): 1600.0 MHz = 16.00 x 100.0 MHz
CPU HFM (Maximum): 2800.0 MHz = 28.00 x 100.0 MHz
CPU Turbo: 2800.0 MHz = 28.00 x 100.0 MHz [Locked]
CPU Current: 2793.9 MHz = 28.00 x 99.8 MHz @ 1.1759 V
CPU Bus Type: Intel Direct Media Interface (DMI) v2.0
Maximum DMI Link Speed: 5.0 GT/s
Current DMI Link Speed: 5.0 GT/s
[Cache and TLB]
L1 Cache: Instruction: 2 x 32 KBytes, Data: 2 x 32 KBytes
L2 Cache: Integrated: 2 x 256 KBytes
L3 Cache: 3 MBytes
Instruction TLB: 4 KB Pages, 4-way set associative, 128 entries
Data TLB: 4 KB Pages, 4-way set associative, 64 entries
[Standard Feature Flags]
FPU on Chip Present
Enhanced Virtual-86 Mode Present
I/O Breakpoints Present
Page Size Extensions Present
Time Stamp Counter Present
Pentium-style Model Specific Registers Present
Physical Address Extension Present
Machine Check Exception Present
CMPXCHG8B Instruction Present
APIC On Chip / PGE (AMD) Present
Fast System Call Present
Memory Type Range Registers Present
Page Global Feature Present
Machine Check Architecture Present
CMOV Instruction Present
Page Attribute Table Present
36-bit Page Size Extensions Present
Processor Number Not Present
CLFLUSH Instruction Present
Debug Trace and EMON Store Present
Internal ACPI Support Present
MMX Technology Present
Fast FP Save/Restore (IA MMX-2) Present
Streaming SIMD Extensions Present
Streaming SIMD Extensions 2 Present
Self-Snoop Present
Multi-Threading Capable Present
Automatic Clock Control Present
IA-64 Processor Not Present
Signal Break on FERR Present
Streaming SIMD Extensions 3 Present
Carryless Multiplication (PCLMULQDQ)/GFMUL Present
64-Bit Debug Store Present
MONITOR/MWAIT Support Present
CPL Qualified Debug Store Present
Virtual Machine Extensions Present
Safer Mode Extensions (Intel TXT) Not Present
Thermal Monitor 2 Present
Supplemental Streaming SIMD Extensions 3 Present
Enhanced SpeedStep Technology Present
L1 Context ID Not Present
Segment Limit Checking Not Present
Fused Multiply Add Not Present
CMPXCHG16B Support Present
Send Task Priority Messages Disabling Present
Performance/Debug Capability MSR Present
Processor Context ID Present
Direct Cache Access Not Present
Streaming SIMD Extensions 4.1 Present
Streaming SIMD Extensions 4.2 Present
Extended xAPIC Not Present
MOVBE Instruction Not Present
POPCNT Instruction Present
TSC-deadline Timer Present
AES Cryptography Support Not Present
XSAVE/XRSTOR/XSETBV/XGETBV Instructions Present
XGETBV/XSETBV OS Enabled Present
AVX Support Not Present
Float16 Instructions Not Present
Random Number Read Instruction Not Present
[Extended Feature Flags]
64-bit Extensions Present
RDTSCP and TSC_AUX Support Present
1 GB large page support Not Present
No Execute Present
SYSCALL/SYSRET Support Not Present
Read/Write FS/GS Base Instructions Not Present
TSC_THREAD_OFFSET Not Present
Bit Manipulation Instructions Set 1 Not Present
Hardware Lock Elision Not Present
AVX2 Instructions Not Present
Supervisor Mode Execution Protection Not Present
Bit Manipulation Instructions Set 2 Not Present
Enhanced Performance String Instruction Not Present
INVPCID Not Present
RTM Not Present
RDSEED Instruction Not Present
Multi-precision Add Carry Instructions Not Present
[Enhanced Features]
Thermal Monitor 1: Supported, Enabled
Thermal Monitor 2: Supported, Enabled
Enhanced Intel SpeedStep (GV3): Supported, Enabled
Bi-directional PROCHOT#: Enabled
Extended Auto-HALT State C1E: Enabled
Extended Stop Grant State C2E: N/A
Enhanced Halt State C3E: N/A
Enhanced Halt State C4E: N/A
Enhanced Halt State Hard C4E: N/A
Hardware Prefetcher: Not Supported
DCU Prefetcher: Not Supported
IP Prefetcher: Not Supported
Adjacent Cache Line Prefetch: Not Supported
MLC Streamer Prefetcher Supported, Enabled
MLC Spatial Prefetcher Supported, Enabled
DCU Streamer Prefetcher Supported, Enabled
DCU IP Prefetcher Supported, Enabled
Intel Dynamic Acceleration (IDA) Technology: Not Supported
Intel Dynamic FSB Switching: Not Supported
Enhanced Multi Threaded Thermal Management: N/A
Intel Turbo Boost Technology: Not Supported
Programmabe Ratio Limits: Not Supported
Programmabe TDC/TDP Limits: Supported, Disabled
[CPU SNB Features]
Internal Graphics: Supported
2 DIMMS per Channel: Not Supported
VT-d: Not Supported
ECC: Not Supported
DDR3 Frequency Support: 667 MHz (DDR3-1333)
[Memory Ranges]
Maximum Physical Address Size: 36-bit (64 GBytes)
Maximum Virtual Address Size: 48-bit (256 TBytes)
[MTRRs]
Range 0-200000000 (0MB-8192MB) Type: Write Back (WB)
Range 200000000-240000000 (8192MB-9216MB) Type: Write Back (WB)
Range B7800000-B8000000 (2936MB-2944MB) Type: Uncacheable (UC)
Range B8000000-C0000000 (2944MB-3072MB) Type: Uncacheable (UC)
Range C0000000-100000000 (3072MB-4096MB) Type: Uncacheable (UC)
Range 23FE00000-240000000 (9214MB-9216MB) Type: Uncacheable (UC)
