<Fehlersuche> BSOD i7 6950X mit und ohne OC
camber88
vielleicht hat jemand eine Idee oder kennt das Problem.
Ich habe sporadisch einen BSOD mit folgender Kennung:
On Mon 20.07.2020 17:17:13 your computer crashed or a problem was reported
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: pshed.dll (PSHED!PshedBugCheckSystem+0x10)
Bugcheck code: 0x124 (0x0, 0xFFFF8784CDB3D028, 0xBA000000, 0x58000402)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\pshed.dll
product: Betriebssystem Microsoft® Windows®
company: Microsoft Corporation
description: Plattformspezifischer Hardwarefehlertreiber
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem.
The crash took place in a Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sun 19.07.2020 18:23:58 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\071920-25500-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3DDB60)
Bugcheck code: 0x124 (0x0, 0xFFFFCB8ADC12A028, 0xBA000000, 0x58000402)
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
description: NT Kernel & System
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
das System ist:
- Lian Li PC-X2000FNB TYR Series Big-Tower USB 3.0, schwarz - gedämmt
- Intel® Core™ i7 6950X
- MSI X99S XPower AC
- 32Gb=2x16Gb G.SKILL F4-3200C14D-32GTZ Kit
- MSI GeForce RTX 2080 Ti GAMING X TRIO
- Windows 10 Professional 64 Bit
- Creative Soundblaster AE-9
- Enermax Platimax 850W ATX 2.4
Das passiert wenn der Rechner übertaktet ist genauso wie wenn ich ihn auf Standard lasse. Bei einer Übertaktung auf 4.2GHz und Stresstest mit Prime,AIDA oder Intel Extreme Tuning Utility läuft er. Ich habe keine Idee
N
NatokWa
Guest
Hmm ich hatte ähnliche Probleme mit meinem alten 6800K ... das hat ich so zur Weißglut getrieben das ich das Teil verschrottet habe und gegen das Sys in meiner Sig. ausgetauscht habe .... die X99 CPU's der 6'er Reihe waren durch die Bak Krüppel .... die MB's leider auch oft.
Tolotos66
Volt-Modder(in)
In welchen Slots stecken denn die RAMs? Die sollten in 1 +5 verbaut sein.
Außerdem verschenkst Du mit einem Dualchannelbetrieb Leistung > Quadchannel
Gruß T.
Noel1987
Kannst du Mal die vccsa Spannung prüfen ?
Normal sind so 0.85 bis 1.1v solltest aber so niedrig wie möglich bleiben aber noch so das es stabil läuft
Mit wieviel MHz betreibst du den Speicher ?
TE
TE
C
camber88
Momentan steht SA auf "Auto"
RAM läuft XMP auf 1600MHz
Ich mach mal Bilder aus dem BIOS
TE
TE
C
camber88
TE
TE
C
camber88
Ich hatte bereits den 5820K, den 6850K auf dem Board und keine Probleme.
Noel1987
Bios ist das aktuellste denke ich Mal
Leider steht genau bei vccsa keine Spannung wäre sehr hilfreich
Aber wieso auf manuell stehen und darunter beides auf Auto ? Stell das manuelle Mal auf Auto
Sollte aber wuppe sein
Ich kann dir aber auch nicht sagen ob's wirklich daran liegt
Kann aber sein daß die CPU das nicht mitmacht ohne das du den SA etwas höher anlegst
Versuche es Mal mit 1.050v
Normal für die CPU ist glaub ich 2400mhz RAM
TE
TE
C
camber88
das ist schnell aufgeklärt. Es geht um Offset oder Manuell
TE
TE
C
camber88
Welches Tool kann ich nutzen um die erwähnten Spannungen zu sehen?
Nach dem Feststellen das SA Spannung auf 1.05:
On Tue 21.07.2020 16:20:43 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\072120-28968-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFF81097DB16028, 0xBA000000, 0x58000402)
Wie gesagt, es passiert sporadisch.
Noel1987
OK dann liegt es daran nicht
Ich weiß gar nicht ob's ausgelesen werden kann
Vllt mit hwinfo
Bei mir stand die Spannung immer BIOS dabei
Noel1987
Aber whea Error kann auch gut passieren wenn die CPU zu viele Fehler produziert
Einige kann die CPU korrigieren aber zu viele nicht
Ich hatte das bei meinen 8700k sobald ich auf 5.2 GHz gegangen bin egal bei welcher Spannung
Diesmal steht auch nichts von memory im fehlertext
Ich würde den RAM erst Mal ohne xmp laufen lassen
Also das BIOS komplett auf Default setzen
Dann würde ich mit dem CPU oc anfangen
Denn wenn der RAM nicht 100 Prozent stabil läuft wird die Fehlersuche echt schwer
Dann würde ich wenn das CPU oc stabil läuft gucken wie weit du mit dem RAM kommst
Core Voltage Necessary For A Stable Overclock
The maximum stable overclock of 4.3GHz is achieved with 1.38V. This is exactly what we saw from the Core i7-6900K. Predictably, the situation looks a bit better at 4.0GHz.
Intel Core i7-6950X: Overclocking, Power & Temperatures
Das ist was ich finden konnte
Sieht so aus als wäre die Spannung zu niedrig
Auch auf einer anderen Seite könnte ich sehen das für 4.5ghz 1.4v angelegt werden mussten
Weil 4.2 GHz sind ja schon 1.2ghz overclock
Das auf 10 Kernen
Ist halt nicht ohne
N
NatokWa
Guest
Die Spannung könnte durchaus zu niedrig sein mit 1.2V@OC . Mein 6800K hat für 4.3Ghz damals 1,34v+ gebraucht um stabil zu laufen. Allerdings sollte 4.0Ghz eher kein Problem sein da der Spannungsbedarf bei der Prozzi-Reihe mit jedem weiteren Multi schneller ansteigt.
Hatte die 6800 damals auf dem berüchtigten Rog-Strix X99 und es lief die meiste Zeit relativ gut bis auf 1 oder 2 WHEA pro Woche und eben das es ein OC Krüppel war (vor allem im Vergleich zu Mainstream-CPU's . Dachte damals ich kauf was gutes und dann kam sowas bei raus *g*
TE
TE
C
camber88
Ist noch was bei rumgekommen
Vielen Dank fürs Interesse. Baut ein wenig auf.
Leider nicht. Ich habe mich dazu entschlossen Windows zurückzusetzen. Hat leider nicht wirklich gewirkt, was mich auch gewundert hätte.
RAM habe ich auch mal in den Slots getauscht. Kein Erfolg.
Ich habe keine Idee wo ich ansetzen kann. Jetzt habe ich RAM da zum tauschen und hätte auch eine CPU zum tauschen.
Der BSOD Code bleibt gleich
On Fri 24.07.2020 09:44:00 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\072420-13546-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFAD0F25F1A028, 0xBA000000, 0x58000402)
file path: C:\WINDOWS\system32\ntoskrnl.exe
crash dump file: C:\WINDOWS\MEMORY.DMP
file path: C:\WINDOWS\system32\pshed.dll
On Thu 23.07.2020 21:40:44 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\072320-12640-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFB0083F145028, 0xBA000000, 0x58000402)
TE
TE
C
camber88
Die Fehlercodes sind so unnachvollziehbar für Laien wie mich.
Irgendwo habe ich überfolgen das es auch die Grafikkarte sein könnte, sprich der Treiber oder die Karte(?)
Lustiges Ratespiel - TRA³
Noel1987
Würde es nicht Sinn machen es irgendwie abzustoßen ?
Klar es ist schon eine gute CPU und die Boards sind super aber vllt bekommst du noch einen guten Betrag dafür ?
Natürlich alles wahrheitsgemäß angeben
Aber deine 400 bis 500 sollte es noch wert sein
Dafür bekommst du ja schon gute Teile eventuell neu
Vllt kannst du die Teile in deinem Umfeld testen lassen
GPU in einem anderen PC oder halt CPU und MB testen sowie RAM um auszuschließen was defekt ist
TE
TE
C
camber88
CPU getauscht und QuadChannel bestückt
Ich bin gespannt.
Wenn das nicht klappt, was wäre denn noch eine Komponente die getauscht werden könnte? Andere RAM Riegel oder eher erst Netzteil?
TE
TE
C
camber88
Ich stimme Dir in der Überlegung zu. Ich habe das System mit einem 5820K betrieben und war immer zufrieden. Fehlt sich nix.
Jetzt habe ich mit der Grafikkarte und der CPU nochmal für bis zu 5 Jahren gerechnet und ich scheue den Aufwand für ein neues System. Ich bastel so gerne meine PC´s und werde dann
eher pedantisch bis ich alles wieder zusammen habe.
