GTX690 Treiber(?) Probleme!
WD hat gleich mal richtig schön geruckelt...
Date , GPU Core Clock [MHz] , GPU Memory Clock [MHz] , GPU Temperature [°C] , Fan Speed (%) [%] , Fan Speed (RPM) [RPM] , Memory Used [MB] , GPU Load [%] , Memory Controller Load [%] , Video Engine Load [%] , Power Consumption [% TDP] , PerfCap Reason [] , VDDC [V] ,
2014-06-09 20:31:21 , 914.5 , 1502.3 , 53.0 , 38 , 1500 , 142 , 1 , 0 , 0 , 28.7 , 16 , 1.0370 ,
2014-06-09 20:31:21 , 914.5 , 1502.3 , 54.0 , 38 , 1500 , 142 , 0 , 0 , 0 , 28.5 , 16 , 1.0370 ,
2014-06-09 20:31:22 , 914.5 , 1502.3 , 54.0 , 39 , 1530 , 142 , 0 , 0 , 0 , 28.3 , 16 , 1.0250 ,
2014-06-09 20:31:22 , 914.5 , 1502.3 , 54.0 , 39 , 1530 , 142 , 0 , 0 , 0 , 28.1 , 16 , 1.0250 ,
2014-06-09 20:31:23 , 731.6 , 1502.3 , 53.0 , 39 , 1530 , 142 , 2 , 0 , 0 , 27.1 , 16 , 0.9870 ,
2014-06-09 20:31:23 , 731.6 , 1502.3 , 53.0 , 39 , 1530 , 142 , 0 , 0 , 0 , 27.2 , 16 , 0.9870 ,
2014-06-09 20:31:24 , 731.6 , 1502.3 , 54.0 , 38 , 1530 , 142 , 0 , 0 , 0 , 27.0 , 16 , 0.9870 ,
2014-06-09 20:31:25 , 731.6 , 1502.3 , 53.0 , 38 , 1530 , 142 , 0 , 0 , 0 , 27.2 , 16 , 0.9870 ,
2014-06-09 20:31:25 , 731.6 , 405.0 , 52.0 , 38 , 1500 , 142 , 0 , 1 , 0 , 13.9 , 16 , 0.9870 ,
2014-06-09 20:31:26 , 731.6 , 405.0 , 52.0 , 38 , 1500 , 142 , 1 , 1 , 0 , 13.9 , 16 , 0.9870 ,
2014-06-09 20:31:26 , 731.6 , 405.0 , 52.0 , 38 , 1530 , 142 , 0 , 1 , 0 , 13.9 , 16 , 0.9870 ,
2014-06-09 20:31:27 , 731.6 , 405.0 , 52.0 , 37 , 1530 , 142 , 0 , 1 , 0 , 14.1 , 16 , 0.9870 ,
2014-06-09 20:31:27 , 731.6 , 405.0 , 51.0 , 37 , 1530 , 142 , 0 , 1 , 0 , 13.8 , 16 , 0.9870 ,
2014-06-09 20:31:28 , 324.0 , 162.0 , 51.0 , 37 , 1470 , 142 , 0 , 1 , 0 , 13.9 , 16 , 0.9870 ,
2014-06-09 20:31:28 , 324.0 , 162.0 , 51.0 , 37 , 1470 , 142 , 1 , 3 , 0 , 13.9 , 16 , 0.9870 ,
2014-06-09 20:31:29 , 324.0 , 162.0 , 51.0 , 37 , 1500 , 142 , 1 , 3 , 0 , 7.8 , 16 , 0.9870 ,
2014-06-09 20:31:29 , 324.0 , 162.0 , 51.0 , 37 , 1500 , 142 , 2 , 3 , 0 , 7.8 , 16 , 0.9870 ,
2014-06-09 20:31:30 , 324.0 , 162.0 , 51.0 , 37 , 1470 , 142 , 0 , 3 , 0 , 7.7 , 16 , 0.9870 ,
2014-06-09 20:31:30 , 324.0 , 162.0 , 51.0 , 37 , 1470 , 142 , 1 , 3 , 0 , 7.7 , 16 , 0.9870 ,
2014-06-09 20:31:31 , 324.0 , 162.0 , 51.0 , 37 , 1470 , 142 , 1 , 3 , 0 , 7.9 , 16 , 0.9870 ,
2014-06-09 20:31:31 , 324.0 , 162.0 , 50.0 , 36 , 1470 , 142 , 0 , 3 , 0 , 7.9 , 16 , 0.9870 ,
2014-06-09 20:31:32 , 324.0 , 162.0 , 50.0 , 36 , 1470 , 142 , 0 , 3 , 0 , 8.0 , 16 , 0.9870 ,
2014-06-09 20:31:33 , 324.0 , 162.0 , 51.0 , 36 , 1470 , 142 , 0 , 3 , 0 , 8.0 , 16 , 0.9870 ,
2014-06-09 20:31:33 , 324.0 , 162.0 , 50.0 , 36 , 1470 , 142 , 6 , 7 , 0 , 8.0 , 16 , 0.9870 ,
2014-06-09 20:31:34 , 324.0 , 162.0 , 50.0 , 36 , 1440 , 142 , 4 , 6 , 0 , 8.0 , 16 , 0.9870 ,
2014-06-09 20:31:34 , 324.0 , 162.0 , 50.0 , 36 , 1440 , 142 , 1 , 3 , 0 , 8.0 , 16 , 0.9870 ,
2014-06-09 20:31:35 , 324.0 , 162.0 , 50.0 , 36 , 1470 , 142 , 1 , 3 , 0 , 7.5 , 16 , 0.9870 ,
2014-06-09 20:31:35 , 324.0 , 162.0 , 50.0 , 36 , 1470 , 142 , 0 , 3 , 0 , 7.5 , 16 , 0.9870 ,
2014-06-09 20:31:36 , 324.0 , 162.0 , 50.0 , 36 , 1470 , 143 , 0 , 3 , 0 , 7.5 , 16 , 0.9870 ,
2014-06-09 20:31:37 , 324.0 , 162.0 , 50.0 , 36 , 1470 , 143 , 1 , 3 , 0 , 7.5 , 16 , 0.9870 ,
2014-06-09 20:31:37 , 324.0 , 162.0 , 50.0 , 36 , 1440 , 143 , 0 , 3 , 0 , 7.5 , 16 , 0.9870 ,
2014-06-09 20:31:38 , 324.0 , 162.0 , 50.0 , 36 , 1440 , 143 , 3 , 6 , 0 , 7.5 , 16 , 0.9870 ,
2014-06-09 20:31:38 , 324.0 , 162.0 , 50.0 , 36 , 1440 , 143 , 1 , 4 , 0 , 7.4 , 16 , 0.9870 ,
2014-06-09 20:31:39 , 324.0 , 162.0 , 50.0 , 36 , 1440 , 143 , 7 , 8 , 0 , 7.4 , 16 , 0.9870 ,
2014-06-09 20:31:39 , 914.5 , 1502.3 , 52.0 , 36 , 1470 , 144 , 0 , 0 , 0 , 28.4 , 16 , 1.0370 ,
2014-06-09 20:31:40 , 914.5 , 1502.3 , 52.0 , 38 , 1470 , 145 , 0 , 0 , 0 , 28.3 , 16 , 1.0370 ,
2014-06-09 20:31:40 , 914.5 , 1502.3 , 52.0 , 38 , 1470 , 145 , 0 , 0 , 0 , 28.4 , 16 , 1.0370 ,
2014-06-09 20:31:41 , 914.5 , 1502.3 , 53.0 , 38 , 1470 , 145 , 0 , 0 , 0 , 28.3 , 16 , 1.0370 ,
2014-06-09 20:31:41 , 914.5 , 1502.3 , 53.0 , 38 , 1500 , 146 , 1 , 0 , 0 , 28.6 , 16 , 1.0370 ,
2014-06-09 20:31:42 , 914.5 , 1502.3 , 53.0 , 38 , 1500 , 146 , 0 , 0 , 0 , 28.4 , 16 , 1.0370 ,
2014-06-09 20:31:42 , 914.5 , 1502.3 , 53.0 , 38 , 1500 , 146 , 0 , 0 , 0 , 28.5 , 16 , 1.0370 ,
2014-06-09 20:31:43 , 914.5 , 1502.3 , 53.0 , 38 , 1500 , 146 , 0 , 0 , 0 , 28.5 , 16 , 1.0370 ,
2014-06-09 20:31:43 , 914.5 , 1502.3 , 53.0 , 38 , 1530 , 146 , 0 , 0 , 0 , 28.4 , 16 , 1.0370 ,
2014-06-09 20:31:44 , 914.5 , 1502.3 , 53.0 , 38 , 1530 , 146 , 0 , 0 , 0 , 28.4 , 16 , 1.0370 ,
2014-06-09 20:31:44 , 914.5 , 1502.3 , 53.0 , 38 , 1500 , 146 , 1 , 0 , 0 , 28.4 , 16 , 1.0370 ,
2014-06-09 20:31:45 , 914.5 , 1502.3 , 53.0 , 38 , 1500 , 146 , 0 , 0 , 0 , 28.4 , 16 , 1.0370 ,
2014-06-09 20:31:45 , 914.5 , 1502.3 , 53.0 , 38 , 1530 , 146 , 0 , 0 , 0 , 28.4 , 16 , 1.0370 ,
2014-06-09 20:31:46 , 914.5 , 1502.3 , 53.0 , 38 , 1530 , 146 , 0 , 0 , 0 , 28.5 , 16 , 1.0370 ,
2014-06-09 20:31:46 , 914.5 , 1502.3 , 53.0 , 38 , 1500 , 146 , 0 , 0 , 0 , 28.4 , 16 , 1.0370 ,
2014-06-09 20:31:47 , 914.5 , 1502.3 , 53.0 , 39 , 1500 , 156 , 3 , 2 , 0 , 28.6 , 16 , 1.0370 ,
2014-06-09 20:34:13 , 731.6 , 1502.3 , 73.0 , 58 , 2220 , 138 , 0 , 0 , 0 , 28.6 , 16 , 0.9870 ,
deine karte läuft da nur mit ~350mhz oder interpretier ich das jetzt iwie falsch?
das würde auch die ruckler erklären...
Hab mich auch eben gewundert? Aber EVGA Precision X zeigt 1084MhZ an...komisch, komisch
Achso und tut mir leid, das ich das hier so oll ranklatschen musste, der Dateihochlade Dienst hat die .txt nicht akzeptiert
Und welchen Wert stellt man da bei nehm Sli System ein ?
... naja das meinte ich ja nicht ... aber wenn ich da an/aus stelle ... passiert nix mit bildrändern... vieleicht nur bei zwischenfilmchen ?
Für was gibts den ein Forum mit schlauen Leuten die google ersetzen können ; )
Ich bin nach wie vor davon überzeugt das SLI das Spiel nicht interessiert, das es, es nicht unterstützt. Mit deaktiviertem SLI meiner GTX690 bekomme ich genau die gleichen FPS wie im aktivierten SLI Modus.
Kann jemand diese Beobachtung auch bestätigen?
