FINAL FANTASY XIV: Heavensward-Benchmark
Crank558
Willkommen zum
Hier der Download-Link: Final Fantasy XIV: Heavensward Benchmark Download
Verwendet bitte für den Benchmark folgende Settings:
Settings: Maximum DirectX11 1920x1080 Vollbild
[table=width:250]Multi GPU|1080p[/table]
[table=autonum=1] 22168 | crank558 | i7-4790K @ 4600MHz | 16GB DDR3-2400 CL 10-12-12-31-1T | 2x GTX980 Palit Jetstream @ 1480/2048MHz |Wasser,Luft | Link [/table]
[table=width:250]Single GPU|1080p[/table]
[table=autonum=1]21568 | hellr3aser | i7-5820k @ 4750MHz | 12GB DDR4-3000 Cl 17-17-17-36-2T| GTX Titan X @1550/3970Mhz |Wasser |Link
15349 | crank558 | i7-4790K @ 4600MHz | 16GB DDR3-2400 CL 10-12-12-31-1T | GTX980 Palit Jetstream @ 1480/2048MHz |Wasser,Luft | Link
15223 |simder | i7-4790K @ 4800MHz | 8GB DDR3-2400 CL 11-13-13-31-1T | GTX980 EVGA @ 1480/1977MHz |Luft|Link
14290|Eddyloveland | i7-4790K @ 4,5GHz | 32GB DDR3-2400MHz CL 11-13-13-31-2T |GTX 980 @ 1313/1825 |Luft H100|Link
6456 |0madmexx0 | AMD X6 1100T @ 3900MHz | 8GB DDR3-1333 CL 9-9-9-27-1T | AMD HD 7970 @ 1000/1400MHz|Luft|Link
3716|Tobi120789 | AMD X6 1090T @ 3200MHz | 16GB DDR3-1333 CL 9-9-9-24-2T | AMD HD 5850 @ 900/1200MHz |Luft |Link [/table]
1080p Multi Gpu:
21103 | | crank558 | i7-4790K @ 4600MHz | 16GB DDR3-2400 CL 10-12-12-31-1T | 2x GTX980 Palit Jetstream @ 1304/1800MHz |Wasser,Luft | Link
Single GPU
21568 | hellr3aser | i7 5820k 4,75 GHz | 12GB DDR4 @ 3000MHz Cl17-17-17-36| GTX Titan X 1550/3970Mhz |Wasser Link
15223 | | simder | i7-4790K @ 4800MHz | 8GB DDR3-2400 CL 11-13-13-31-1T | GTX980 EVGA @ 1480/1977MHz |Luft |
*Update*
1080p Multi Gpu:
22168 | | crank558 | i7-4790K @ 4600MHz | 16GB DDR3-2400 CL 10-12-12-31-1T | 2x GTX980 Palit Jetstream @ 1480/2048MHz |Wasser,Luft | Link
*Update*
1080p Single Gpu:
