HansOConner
EVGA Precision X Classified 3.0.3 vom 29.06.2012 verfügbar !!!
Hallo Leute,
EVGA hat eine neue Version des Precision X aufgelegt... Aktuelle Rev. 3.0.3 vom 29.06.2012:
U.a. mit Classified Skin
Hier ein Screenshot von meiner EVGA GeForce GTX 680:
Version 3.0.3 (published on 29.06.2012)
Version 3.0.2 (published on 10.04.2012)
· Added "Always on top" setting to the context menu of detached hardware monitor window. When this option is disabled, hardware monitoring window can be minimized to the taskbar when it is detached from the main window
· Added hardware monitoring history logging support. Now EVGA Precision is able to save history in native RivaTuner Hardware Monitoring Log file format. The log files captured with EVGA Precision can be viewed in any text editor like Notepad or in graphics form in RivaTuner's HML file viewer (RivaTuner must be installed for viewing log files in graphics form)
· Maximum framerate target increased to 120 FPS
· Maximum length of GPU name for GPU selection buttons has been increased to 10 symbols
· Added new "Force fan speed update on each period" option to the "Fan" tab. New option may improve compatibility of software automatic fan speed control mode with some bugged display drivers, overriding manually programmed fan speed under certain conditions
· Bundled EVGA EVTune utility has been replaced with brand new EVGA VoltageTuner utility
· Added bundled EVGA Bridge utility, allowing controlling EVGA Precision via Bluetooth from Android smartphones. The bridge utility is automatically started by EVGA Precision when “Enable external access to application via Bluetooth” is ticked in advanced settings
· Fixed issue in skin engine causing boost clock marker legend to be rendered improperly under certain conditions
· Includes new “EVGA Classified” skin
Version 3.0.1 (published on 22.03.2012)
· The first public release
Download als registrierter Nutzer auf der EVGA Homepage oder einfacher, ohne Anmeldung über folgenden ComputerBase-Link:
ComputerBase
... dort den 2. Download-Link - also Download (CB) - auswählen.
Hallo Leute,
- Increased upper allowed power limit for power limit adjustment slider on some extreme editions of NVIDIA GeForce GTX 600 series graphics cards
- Added minimum and maximum values to monitoring graphs (only in detached monitoring window mode)
- Fixed incorrect core clock monitoring on GeForce GT 640 series graphics cards
- Fixed incorrect clock monitoring and incorrect boost clock markers rendering after switching from pre-Kepler architecture card to Kepler architecture card on the fly
- Clock and voltage indicators are no longer rendered incorrectly after changing the skins on the fly
- Optimized fan speed indicator rendering on fanless systems
- EVGA On-Screen Display server has been upgraded to version 4.3.4. New version gives you the following improvements:
- Fixed framerate calculation for DirectX10/DirectX11 applications, which actively use presentation testing during rendering (e.g. Max Payne 3)
ComputerBase
