AW: Duke Nukem Forever - directx problem/nicht spielbar
Hab mir jetzt den Webinstaller runtergeladen - direkt von Microsoft.
Wenn ich es installieren will kommt die Fehlermeldung:
"Interner Systemfehler. Weitere Informationen zum Ermitteln des Problems finden Sie in den Dateien "dxerror.log" und "directx.log" im Ordner "Windows"."
DXERROR.LOG
[06/20/11 04:13:39] module: dxupdate(Sep 28 2005), file: dxupdate.cpp, line: 178, function: GetDXVersion
Failed API: RegQueryValueEx()
Error: (2) - Das System kann die angegebene Datei nicht finden.
Current DirectX may be a older version which does not have the version value in the registry.
[06/20/11 04:13:39] module: dxupdate(Sep 28 2005), file: dxupdate.cpp, line: 3937, function: DirectXUpdateGetSetupInformation
GetDXVersion() failed.
[06/20/11 04:13:39] module: dsetup32(Sep 28 2005), file: dxupdate.cpp, line: 244, function: CSetup::InstallPlugIn
DirectXUpdateInstallPlugIn() failed.
[06/20/11 04:14:56] module: dxupdate(Sep 28 2005), file: dxupdate.cpp, line: 178, function: GetDXVersion
[06/20/11 04:14:56] module: dxupdate(Sep 28 2005), file: dxupdate.cpp, line: 3937, function: DirectXUpdateGetSetupInformation
[06/20/11 04:14:56] module: dsetup32(Sep 28 2005), file: dxupdate.cpp, line: 244, function: CSetup::InstallPlugIn
DIRECTX.LOG
06/12/11 16:36:10: DSETUP: DirectXSetupA(): hWnd: 00010094 dwFlags: 00010018
06/12/11 16:36:10: dsetup32: === SetupForDirectX() start ===
06/12/11 16:36:10: dsetup32: Jul 28 2006 08:45:06
06/12/11 16:36:10: dsetup32: SetupForDirectX(): query dxsetup command: result = 2.
06/12/11 16:36:10: dsetup32: DXSetupCommand = 0.
06/12/11 16:36:10: dsetup32: Installing on Windows 6.0.6000
06/12/11 16:36:10: dsetup32: DirectXSetupIsJapanese == 0
06/12/11 16:36:10: dsetup32: DirectXSetupIsJapanNec == 0
06/12/11 16:36:35: dsetup32: IsIA64(): not IA64.
06/12/11 16:36:35: dsetup32: CLR version number = 2.0.50727
06/12/11 16:36:36: dsetup32: DXCheckTrust(): F:\Users\Fabian\AppData\Local\Temp\NERO14766\Data\Redist\DirectX\dxupdate.cab is trusted.
06/12/11 16:36:36: dsetup32: GetCDXUpdate(): Extracting dxupdate.dll from F:\Users\Fabian\AppData\Local\Temp\NERO14766\Data\Redist\DirectX\dxupdate.cab.
06/12/11 16:36:36: dsetup32: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\dxupdate.inf from cab
06/12/11 16:36:36: dsetup32: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\dxupdate.cif from cab
06/12/11 16:36:36: dsetup32: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\dxupdate.dll from cab
06/12/11 16:36:36: dsetup32: GetCDXUpdate(): Loading dxupdate.dll in F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\.
06/12/11 16:36:37: dsetup32: DirectXSetupIsJapanese == 0
06/12/11 16:36:37: dsetup32: DirectXSetupIsJapanNec == 0
06/12/11 16:36:37: dsetup32: IsWow64(): not Wow64 process.
06/12/11 16:36:37: dxupdate: -----
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In dxdllreg_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In RGB9Rast_1_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In RGB9Rast_1_x64.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In RGB9Rast_2_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In RGB9Rast_2_x64.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2902.0_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2903.0_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2904.0_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2905.0_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2906.0_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2907.0_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2908.0_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2909.0_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2910.0_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2005_d3dx9_24_x86.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2005_d3dx9_24_x64.cab does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2005_MDX_x86.MSI does not exist.
06/12/11 16:36:37: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2005_d3dx9_25_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: -----
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2005_d3dx9_25_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2005_MDX_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Jun2005_d3dx9_26_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Jun2005_d3dx9_26_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Jun2005_MDX_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Aug2005_d3dx9_27_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Aug2005_d3dx9_27_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Aug2005_MDX_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Oct2005_d3dx9_27_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Oct2005_d3dx9_27_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Oct2005_MDX_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Oct2005_xinput_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Oct2005_xinput_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Checking for Dec2005_d3dx9_28_x86.cab...
06/12/11 16:36:38: dxupdate: DXCheckTrust(): F:\Users\Fabian\AppData\Local\Temp\NERO14766\Data\Redist\DirectX\Dec2005_d3dx9_28_x86.cab is trusted.
06/12/11 16:36:38: dxupdate: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\dec2005_d3dx9_28_x86.inf from cab
06/12/11 16:36:38: dxupdate: DirectXUpdateGetSetupInformation(): DirectX Version: 4.09.00.0904.0
06/12/11 16:36:38: dxupdate: CheckDependency(): no dependency.
06/12/11 16:36:38: dxupdate: DirectXUpdateGetSetupInformation(): Section [4.09.00.0904.0-4.09.00.0904.0_WinNT] is being installed.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Dec2005_d3dx9_28_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Dec2005_MDX1_x86_Archive.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Dec2005_MDX1_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2006_d3dx9_29_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2006_d3dx9_29_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2006_MDX1_x86_Archive.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2006_MDX1_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2006_XACT_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2006_XACT_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Checking for Apr2006_d3dx9_30_x86.cab...
06/12/11 16:36:38: dxupdate: DXCheckTrust(): F:\Users\Fabian\AppData\Local\Temp\NERO14766\Data\Redist\DirectX\Apr2006_d3dx9_30_x86.cab is trusted.
06/12/11 16:36:38: dxupdate: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\apr2006_d3dx9_30_x86.inf from cab
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_d3dx9_30_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_MDX1_x86_Archive.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_MDX1_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_XACT_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_XACT_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_xinput_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_xinput_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Jun2006_XACT_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Jun2006_XACT_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Aug2006_xinput_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Aug2006_xinput_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Aug2006_XACT_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Aug2006_XACT_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Jun2005_xinput_x86.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Jun2005_xinput_x64.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Oct2005_XACT_x86.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Oct2005_MDX_x86.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Dec2005_XACT_x86.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Dec2005_MDX2_x86.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Dec2005_MDX2_x64.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Dec2005_d3dx10_x86.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Dec2005_d3dx10_x64.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Feb2006_MDX2_x86.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Feb2006_MDX2_x64.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Feb2006_d3dx10_x86.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Feb2006_d3dx10_x64.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Apr2006_MDX2_x86.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Apr2006_MDX2_x64.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Apr2006_d3dx10_x86.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Apr2006_d3dx10_x64.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Jun2006_d3dx10_x86.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Jun2006_d3dx10_x64.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Aug2006_d3dx10_x86.cab] is skipped.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Aug2006_d3dx10_x64.cab] is skipped.
06/12/11 16:36:38: dxupdate: Total Files: 8
06/12/11 16:36:38: dxupdate: Total Size: 4460544
06/12/11 16:36:38: dxupdate: Total Progress: 2
06/12/11 16:36:38: dsetup32: GetCDXUpdate(): Loading dxupdate.dll in F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\.
06/12/11 16:36:38: dsetup32: DirectXSetupIsJapanese == 0
06/12/11 16:36:38: dsetup32: DirectXSetupIsJapanNec == 0
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In dxdllreg_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In RGB9Rast_1_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In RGB9Rast_1_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In RGB9Rast_2_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In RGB9Rast_2_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2902.0_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2903.0_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2904.0_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2905.0_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2906.0_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2907.0_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2908.0_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2909.0_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In MDX_1.0.2910.0_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2005_d3dx9_24_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2005_d3dx9_24_x64.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2005_MDX_x86.MSI does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2005_d3dx9_25_x86.cab does not exist.
06/12/11 16:36:38: dxupdate: DirectXUpdateInstallPlugIn(): Installing Dec2005_d3dx9_28_x86.cab...
06/12/11 16:36:39: dxupdate: DXCheckTrust(): F:\Users\Fabian\AppData\Local\Temp\NERO14766\Data\Redist\DirectX\Dec2005_d3dx9_28_x86.cab is trusted.
06/12/11 16:36:39: dxupdate: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\dec2005_d3dx9_28_x86.inf from cab
06/12/11 16:36:39: dxupdate: GetDXVersion(): Unable to get RC string from registry, now RC is 0.
06/12/11 16:36:39: dxupdate: DirectXUpdateGetSetupInformation(): DirectX Version: 4.09.00.0904.0
06/12/11 16:36:39: dxupdate: CheckDependency(): no dependency.
06/12/11 16:36:39: dxupdate: DirectXUpdateGetSetupInformation(): Section [4.09.00.0904.0-4.09.00.0904.0_WinNT] is being installed.
06/12/11 16:36:39: dxupdate: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\d3dx9_28_x86.cat from cab
06/12/11 16:36:39: dxupdate: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\d3dx9_28.dll from cab
06/12/11 16:36:39: dxupdate: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\d3dx9_28_w9x.inf from cab
06/12/11 16:36:39: dxupdate: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\d3dx9_28_x86.inf from cab
06/12/11 16:36:39: dxupdate: Files: 4
06/12/11 16:36:39: dxupdate: Size: 2230272
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Installing: d3dx9_28_x86.inf - [x86_install]
06/12/11 16:36:39: dxupdate: Installed file F:\Windows\system32\d3dx9_28.dll
06/12/11 16:36:39: dxupdate: -----
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Dec2005_d3dx9_28_x64.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Dec2005_MDX1_x86_Archive.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Dec2005_MDX1_x86.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2006_d3dx9_29_x86.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2006_d3dx9_29_x64.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2006_MDX1_x86_Archive.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2006_MDX1_x86.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2006_XACT_x86.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Feb2006_XACT_x64.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Installing Apr2006_d3dx9_30_x86.cab...
06/12/11 16:36:39: dxupdate: DXCheckTrust(): F:\Users\Fabian\AppData\Local\Temp\NERO14766\Data\Redist\DirectX\Apr2006_d3dx9_30_x86.cab is trusted.
06/12/11 16:36:39: dxupdate: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\apr2006_d3dx9_30_x86.inf from cab
06/12/11 16:36:39: dxupdate: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\d3dx9_30_x86.cat from cab
06/12/11 16:36:39: dxupdate: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\d3dx9_30.dll from cab
06/12/11 16:36:39: dxupdate: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\d3dx9_30_w9x.inf from cab
06/12/11 16:36:39: dxupdate: Extracted file F:\Users\Fabian\AppData\Local\Temp\DXC8A5.tmp\d3dx9_30_x86.inf from cab
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Installing: d3dx9_30_x86.inf - [x86_install]
06/12/11 16:36:39: dxupdate: Installed file F:\Windows\system32\d3dx9_30.dll
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_d3dx9_30_x64.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_MDX1_x86_Archive.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_MDX1_x86.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_XACT_x86.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_XACT_x64.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_xinput_x86.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Apr2006_xinput_x64.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Jun2006_XACT_x86.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Jun2006_XACT_x64.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Aug2006_xinput_x86.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Aug2006_xinput_x64.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Aug2006_XACT_x86.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In Aug2006_XACT_x64.cab does not exist.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Jun2005_xinput_x86.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Jun2005_xinput_x64.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Oct2005_XACT_x86.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Oct2005_MDX_x86.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Dec2005_XACT_x86.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Dec2005_MDX2_x86.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Dec2005_MDX2_x64.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Dec2005_d3dx10_x86.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Dec2005_d3dx10_x64.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Feb2006_MDX2_x86.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Feb2006_MDX2_x64.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Feb2006_d3dx10_x86.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Feb2006_d3dx10_x64.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Apr2006_MDX2_x86.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Apr2006_MDX2_x64.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Apr2006_d3dx10_x86.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Apr2006_d3dx10_x64.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Jun2006_d3dx10_x86.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Jun2006_d3dx10_x64.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Aug2006_d3dx10_x86.cab] is skipped.
06/12/11 16:36:39: dxupdate: DirectXUpdateInstallPlugIn(): folder does not exist, [Beta_Aug2006_d3dx10_x64.cab] is skipped.
06/12/11 16:36:39: dsetup32: SetupForDirectX: InstallPlugIn() Succeeded.
06/12/11 16:36:39: dsetup32: start finalizing: phase: 2 - 2, total: 0 - 2
06/12/11 16:36:40: dsetup32: Installation ended with value 0 = Installation succeeded
06/19/11 17:47:25: DXSetup: No command line switch
06/19/11 17:47:25: DXSetup: StartWizard()
06/19/11 17:47:28: DXSetup: CDXWSetup()
06/19/11 17:47:29: DXSetup: start installation
06/19/11 17:47:29: DSETUP: DirectXSetupA(): hWnd: 00070344 dwFlags: 02010098
06/19/11 17:47:29: dsetup32: === SetupForDirectX() start ===
06/19/11 17:47:29: dsetup32: DXSetupCommand = 0.
06/19/11 17:47:29: DXSetup: DSetupCallback(): Phase = 0, Steps = 0
06/19/11 17:47:29: dsetup32: Installing on Windows 6.1.7601
06/19/11 17:47:29: dsetup32: DirectXSetupIsJapanese == 0
06/19/11 17:47:29: dsetup32: DirectXSetupIsJapanNec == 0
06/19/11 17:47:29: dsetup32: Installation ended with value 0 = Installation succeeded
06/19/11 17:47:29: DXSetup: WM_APP_ENDINSTALL
06/19/11 17:47:29: DXSetup: ~CDXWSetup()
06/19/11 17:47:39: DXSetup: No command line switch
06/19/11 17:47:39: DXSetup: StartWizard()
06/19/11 17:47:42: DXSetup: CDXWSetup()
06/19/11 17:47:43: DXSetup: start installation
06/19/11 17:47:43: DSETUP: DirectXSetupA(): hWnd: 0012032A dwFlags: 02010098
06/19/11 17:47:43: dsetup32: === SetupForDirectX() start ===
06/19/11 17:47:43: dsetup32: DXSetupCommand = 0.
06/19/11 17:47:43: DXSetup: DSetupCallback(): Phase = 0, Steps = 0
06/19/11 17:47:43: dsetup32: Installing on Windows 5.1.2600
06/19/11 17:47:43: dsetup32: DirectXSetupIsJapanese == 0
06/19/11 17:47:43: dsetup32: DirectXSetupIsJapanNec == 0
06/19/11 17:47:43: dsetup32: Installation ended with value 0 = Installation succeeded
06/19/11 17:47:43: DXSetup: WM_APP_ENDINSTALL
06/19/11 17:47:43: DXSetup: ~CDXWSetup()
06/20/11 04:13:10: DXSetup: No command line switch
06/20/11 04:13:10: DXSetup: StartWizard()
06/20/11 04:13:11: dsetup32: IsWow64(): not Wow64 process.
06/20/11 04:13:13: DXSetup: CDXWSetup()
06/20/11 04:13:14: DXSetup: start installation
06/20/11 04:13:14: DSETUP: DirectXSetupA(): hWnd: 000304E0 dwFlags: 02010098
