DiRT 3 Patch 1.02
Own3r
Volt-Modder(in)
dirt3-jpg.456169
Vor wenigen Minuten ist der zweite Patch (Version 1.02) für das Spiel DiRT 3 veröffentlicht worden!
Er wird beim Start des Spiels automatische heruntergeladen und installiert.
Changelog:
  • Resolved an issue which could prevent the user successfully saving with profiles that contained unicode characters.
  • UI elements are no longer incorrectly displayed in Gymkhana
  • Improvements to input system, supporting multi-device action maps. The user can now set button configurations to span multiple devices; previously a bug would cause these settings to be lost upon game restart.
  • Corrected various spelling mistakes across all languages
  • Reset line corrections to prevent potential ‘out of world’ or ‘driving into crowd’ issues on several tracks
  • Corrected an issue which could, in rare circumstances, prevent the display from rendering in the event of 16xCSAA being selected.
  • Steering wheel no longer jolts to the left in the race reward screen
  • Removed an incorrect limitation which could cause VSync to lock the refresh rate to 60Hz on a 120Hz system.
  • Physics output to motion simulators is now correctly faded out at the end of a race, preventing some situations within which motion would continue after crossing the finish line.
  • Adjusted head camera configuration to avoid excessive vibration effects when VSync is disabled.
  • Front end menu improvements for multi-display systems, correcting a small number of visibility issues.
  • Improvements to GPU detection, correcting a potential issue which in some circumstances could prevent SLI scaling operating correctly with DirectX 11.
  • Implemented native stereoscopic support for compatible devices.
  • Inclusion of a benchmarking utility, simplifying the process of gathering performance statistics.
  • Various stability fixes.
Quelle: PC Patch List - Codemasters Forums
Ich habe die Steam Version, und bei mir wurde gerade beim Start kein Patch runtergeladen. Kommt doch vermutlich von GfWL oder? Steam selbst lädt auch nichts.
Habe gestern Dirt3 gekauft und installiert, einen 500mb patch "von hand" installiert konnte mich auch mit meinem live account anmelden, doch dann stand da was von neuer version verfuegbar. Habe auf ja, patch laden geklickt doch der mist wollte einfach nicht weiter laden! -.-
So macht spiele kaufen keinen spass mehr! Hab mir vorgenommen den mist heute wegzuschmeissen... Kann mit jemand hoffnung machen, dass ich noch heute in den rally genuss komme?
Edit: sitz noch auf arbeit, bin erst spaet zu spaet am rechner um alles auszuprobieren was so geht, deshlab um jeden tip dankbar ;)
Deinstalliere das Spiel nochmal komplett und dann installierst du es wieder und lässt es beim ersten Spielstart automatisch patchen. Je nach Internetverbindung kann das ein bisschen dauern.
Ok, wird so gemacht! Danke!
Kleine Rückmeldung. Bin zuhause, habe deine Anweisungen befolgt und jetzt läd das Spiel den Patch! Sehr Geil, danke nochmal!
Möcht nur hoffen, dass auch der zweite funktioniert.... ^^ Bei meinem DSL Light kann ich eh erst morgen testen -.-
