saphira33
Dann erklär mir wieso ich nie über 100 FPS habe ohne einen Framelimiter eingestellt zu haben?Nein, Gsync begrenzt garnix, das macht Vsync oder ein framelimiter.
Oder einfach um mal ein PcMonitors zu Zitieren.
It also locks the frame rate to a maximum equal to the monitor's refresh rate. Whilst this eliminates tearing, it also increases input lag as there is an inherent delay before frames are sent to the monitor. On a 120Hz monitor the input lag penalty is half that of a 60Hz monitor and on a 144Hz monitor is even lower.
Nvidia G-SYNC VRR Technology | PCMonitors.info
Nvidia G-SYNC is a Variable Refresh Rate (VRR) technology which removes tearing and stuttering from frame and refresh rate mismatches.
pcmonitors.info
