On the P5Q-E and some other Asus boards, there is no bios setting where you can turn intrusion detection off. Instead, you must locate the chassis intrusion pins and put a jumper on them. It is covered in the Asus manuals - download the manual for your motherboard.
Du musst anscheind einen Jumper auf die Chassis Intrusion Pins stecken.
