Bluescreen
Gamer6767
Seit einiger Zeit , nachdem ich mein pc formatiert habe, erscheint jetzt immer ein Bluescreen . Meistens wenn ich Videos im Internet gucke oder Emulatoren spiele erscheint er immer .
Alles erstarrt und der Bluescreen erscheint. Ich hoffe ihr könnt mir behilflich sein, im folgenden findet ihr eine Analyse der Meldung.
Crash Dump Analysis provided by OSR Open Systems Resources, Inc. (OSR Homepage | OSR)
Online Crash Dump Analysis Service
See OSR Online - The Home Page for Windows Driver Developers for more information
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.23153.amd64fre.win7sp1_ldr.150804-0600
Machine Name:
Kernel base = 0xfffff800`0301e000 PsLoadedModuleList = 0xfffff800`03260730
Debug session time: Fri Sep 25 10:16:27.179 2015 (UTC - 4:00)
System Uptime: 0 days 0:36:25.944
* Bugcheck Analysis *
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800a07b028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000bf800000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000200401, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_WHEA_ERROR_RECORD_HEADER ***
*** work. ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
*** work. ***
*** work. ***
BUGCHECK_STR: 0x124_GenuineIntel
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`0337cb58 fffff800`03617a37 : 00000000`00000124 00000000`00000000 fffffa80`0a07b028 00000000`bf800000 : nt!KeBugCheckEx
fffff880`0337cb60 fffff800`031a784f : 00000000`00000001 fffffa80`07938a60 00000000`00000000 fffffa80`07938ab0 : hal!HalBugCheckSystem+0x1e3
fffff880`0337cba0 fffff800`036176fc : 00000000`00000728 fffffa80`07938a60 fffff880`0337cf30 fffff880`0337cf00 : nt!WheaReportHwError+0x26f
fffff880`0337cc00 fffff800`0361704e : fffffa80`07938a60 fffff880`0337cf30 fffffa80`07938a60 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`0337cd50 fffff800`03616f09 : 00000000`00000008 00000000`00000001 fffff880`0337cfb0 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`0337cd90 fffff800`0360ae88 : 00000000`00000000 00000000`00000010 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x55
fffff880`0337cdc0 fffff800`0308cbac : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
fffff880`0337cdf0 fffff800`0308ca13 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`0337cf30 fffff800`03084eb8 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
fffff880`09128638 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!memmove+0x208
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: GenuineIntel
IMAGE_NAME: GenuineIntel
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_MAE
Followup: MachineOwner
Sry weiß nicht wie es geht
Hier :
Das ist jetzt nur die CPU.
Wie sieht der Rest aus? Kannst du wie die Temperaturen mit Speccy auslesen. Nur das Netzteil müsstest du so herausfinden.
____________________________________________
Spoiler-Box findest du in der erweiterten Post-Bearbeitung in der 3. Werkzeugleiste mit einem S: Spoiler.png
Sieht dann z.B. so aus:
Sehr langer Text ...
