also ich habe mir die Tage nen pc selber zusammen gestellt..
Wenn ich nun anfangen will zu spielen, (nur dann!), bekomm ich nach ca 3-5 Minuten nen Bluescreen..
Meinte Daten:
Prozessor: Intel i7 2600k, 3,40 GHZ
RAM: 8 gig
grafik: nvidia gtx 460 gs
und windows 7 64bit..
Meine Minidumpmeldung:
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000007E, {ffffffffc000001d, fffff88010020e00, fffff88004048668, fffff88004047ed0}
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : memory_corruption
Followup: memory_corruption
6: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc000001d, The exception code that was not handled
Arg2: fffff88010020e00, The address that the exception occurred at
Arg3: fffff88004048668, Exception Record Address
Arg4: fffff88004047ed0, Context Record Address
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc000001d - {AUSNAHME} Ung ltige Anweisung Es wurde versucht, eine ung ltige Anweisung auszuf hren.
FAULTING_IP:
dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+134
fffff880`10020e00 ea ???
EXCEPTION_RECORD: fffff88004048668 -- (.exr 0xfffff88004048668)
ExceptionAddress: fffff88010020e00 (dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+0x0000000000000134)
ExceptionCode: c000001d (Illegal instruction)
ExceptionFlags: 00000000
NumberParameters: 0
CONTEXT: fffff88004047ed0 -- (.cxr 0xfffff88004047ed0)
rax=00000000c0000001 rbx=fffff8a003d765e0 rcx=0000000000000000
rdx=fffffa8006bec650 rsi=fffffa800b3d0000 rdi=fffffa800b3d0000
rip=fffff88010020e00 rsp=fffff880040488a0 rbp=fffffa800724d2d8
r8=fffffa8006d55900 r9=0000000000000000 r10=0000000000000000
r11=00000000000000c4 r12=fffffa8006bec650 r13=0000000000000000
r14=0000000000000000 r15=0000000000000001
iopl=0 nv up ei pl nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010206
dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+0x134:
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: CODE_CORRUPTION
BUGCHECK_STR: 0x7E
PROCESS_NAME: System
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc000001d - {AUSNAHME} Ung ltige Anweisung Es wurde versucht, eine ung ltige Anweisung auszuf hren.
LAST_CONTROL_TRANSFER: from fffff8801001ded3 to fffff88010020e00
FAILED_INSTRUCTION_ADDRESS:
STACK_TEXT:
fffff880`040488a0 fffff880`1001ded3 : 00000000`00000000 fffffa80`070060f0 00000000`000000a6 00000000`00000000 : dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+0x134
fffff880`040488d0 fffff880`1003865d : 00000000`00000000 fffff8a0`013d7e10 fffffa80`00000000 fffffa80`06d55930 : dxgmms1!VIDMM_GLOBAL:
repareDmaBuffer+0x43f
fffff880`04048aa0 fffff880`10038398 : fffff800`00b96080 fffff880`10037d00 fffffa80`00000000 fffffa80`00000000 : dxgmms1!VidSchiSubmitRenderCommand+0x241
fffff880`04048c90 fffff880`10037e96 : 00000000`00000000 fffffa80`094cb9a0 00000000`00000080 fffffa80`0b29f410 : dxgmms1!VidSchiSubmitQueueCommand+0x50
fffff880`04048cc0 fffff800`0336a7c6 : 00000000`0349e4c1 fffffa80`0b2ae620 fffffa80`0670e5f0 fffffa80`0b2ae620 : dxgmms1!VidSchiWorkerThread+0xd6
fffff880`04048d00 fffff800`030a5c26 : fffff800`03241e80 fffffa80`0b2ae620 fffff800`0324fc40 fffff880`01658534 : nt!PspSystemThreadStartup+0x5a
fffff880`04048d40 00000000`00000000 : fffff880`04049000 fffff880`04043000 fffff880`04048650 00000000`00000000 : nt!KxStartSystemThread+0x16
CHKIMG_EXTENSION: !chkimg -lo 50 -d !dxgmms1
fffff88010020e00 - dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+134
[ eb:ea ]
1 error : !dxgmms1 (fffff88010020e00)
MODULE_NAME: memory_corruption
IMAGE_NAME: memory_corruption
FOLLOWUP_NAME: memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MEMORY_CORRUPTOR: ONE_BIT
STACK_COMMAND: .cxr 0xfffff88004047ed0 ; kb
FAILURE_BUCKET_ID: X64_MEMORY_CORRUPTION_ONE_BIT
Hoffe es kann mir einer weiterhelfen.
der pc ist 2 tage alt, kb dass das jetzt nicht alles klappt.
Vielen Dank,
coonan
Meinte Daten:
RAM: 8 gig
6: kd> !analyze -v
happening.
Arguments:
Debugging Details:
FAULTING_IP:
NumberParameters: 0
BUGCHECK_STR: 0x7E
CURRENT_IRQL: 0
STACK_TEXT:
repareDmaBuffer+0x43ffffff880`04048aa0 fffff880`10038398 : fffff800`00b96080 fffff880`10037d00 fffffa80`00000000 fffffa80`00000000 : dxgmms1!VidSchiSubmitRenderCommand+0x241
[ eb:ea ]
Vielen Dank,
coonan
