Bluescreen wirklich Memory kaputt?
Nerto
Hi,
ich habe folgenden Bluescreen.
Code:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
FAULTING_IP:
dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+1e
fffff880`0fd4b4ba 488b30          mov     rsi,qword ptr [rax]
CONTEXT:  fffff8800b065990 -- (.cxr 0xfffff8800b065990;r)
rax=fff7f8a00b321760 rbx=fffff8a00c15fc50 rcx=fffffa800e534000
rdx=fffffa801106f120 rsi=fffffa800e534000 rdi=fffff8a00c15fc50
rip=fffff8800fd4b4ba rsp=fffff8800b066370 rbp=0000000000000001
 r8=0000000000000000  r9=fffff8800fd418c0 r10=0000000000000000
r11=fffff880019d9120 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=fffff8a0013d67f0
iopl=0         nv up ei pl zr na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010246
dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+0x1e:
fffff880`0fd4b4ba 488b30          mov     rsi,qword ptr [rax] ds:002b:fff7f8a0`0b321760=????????????????
Last set context:
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  WIN7_DRIVER_FAULT
BUGCHECK_STR:  0x3B
PROCESS_NAME:  Wow-64.exe
CURRENT_IRQL:  0
ANALYSIS_VERSION: 6.3.9600.16384 (debuggers(dbg).130821-1623) amd64fre
LAST_CONTROL_TRANSFER:  from fffff8800fd31ecc to fffff8800fd4b4ba
STACK_TEXT:
fffff880`0b066370 fffff880`0fd31ecc : fffff880`0f8fad66 fffffa80`0e513000 00000000`00000000 fffff880`0b0664a0 : dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+0x1e
fffff880`0b066440 fffff880`0fc73ccc : 00000000`00000000 fffff8a0`02a06000 fffff8a0`02a06000 00000000`00000001 : dxgmms1!VidMmCloseAllocation+0x44
fffff880`0b066470 fffff880`0fc868b8 : 00000000`00000001 00000000`00000000 00000000`00000000 fffff8a0`00000799 : dxgkrnl!DXGDEVICE::DestroyAllocations+0x248
fffff880`0b066560 fffff880`0fc6b815 : 00000000`fffffeda fffff8a0`015454d0 fffff8a0`02a06000 fffffa80`0e513000 : dxgkrnl!DXGDEVICE::~DXGDEVICE+0x19c
fffff880`0b0665d0 fffff880`0fca9ffa : 00000000`00000001 fffffa80`0e513000 fffff8a0`015454d0 fffff8a0`01545550 : dxgkrnl!DXGADAPTER::DestroyDevice+0x1c9
fffff880`0b066600 fffff880`0fca9990 : fffff900`c3a642f0 00000000`00000000 00000000`00000001 fffff900`c3a642f0 : dxgkrnl!DXGPROCESS::Destroy+0xba
fffff880`0b0666b0 fffff960`000f6e24 : 00000000`00000468 fffff900`c3a642f0 00000000`00000000 fffff900`c3a642f0 : dxgkrnl!DxgkProcessCallout+0x268
fffff880`0b066740 fffff960`000f6527 : 00000000`00000000 fffff880`0b066ae0 fffffa80`0f53db50 00000000`00000000 : win32k!GdiProcessCallout+0x244
fffff880`0b0667c0 fffff800`02d990c1 : 00000000`00000000 00000000`00000000 00000000`00000000 fffffa80`0f53db00 : win32k!W32pProcessCallout+0x6b
fffff880`0b0667f0 fffff800`02d7f2ed : 00000000`00000000 00000000`00000001 fffffa80`78457300 fffffa80`0f950060 : nt!PspExitThread+0x4d1
fffff880`0b0668f0 fffff800`02ab76fa : 00000000`00000100 fffffa80`0f53dc10 00000000`00000001 fffff800`02aba7fd : nt!PsExitSpecialApc+0x1d
fffff880`0b066920 fffff800`02ab7a40 : 00000000`00000000 fffff880`0b0669a0 fffff800`02d7f260 00000000`00000001 : nt!KiDeliverApc+0x2ca
fffff880`0b0669a0 fffff800`02ac3ef7 : fffffa80`0f53db50 00000000`ffffffff 00000000`00000000 fffffa80`0ec854a0 : nt!KiInitiateUserApc+0x70
fffff880`0b066ae0 00000000`771312fa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9c
00000000`0656fb68 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x771312fa
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+1e
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: dxgmms1
IMAGE_NAME:  dxgmms1.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  5164dc13
IMAGE_VERSION:  6.1.7601.18126
STACK_COMMAND:  .cxr 0xfffff8800b065990 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+1e
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:x64_0x3b_dxgmms1!vidmm_global::closeoneallocation+1e
FAILURE_ID_HASH:  {55543292-3910-545d-e461-12f9e62ab019}
Followup: MachineOwner
Ich habe gegooglet, meistens soll der Bluescreen von kaputten Arbeitsspeicher verursacht. Deswegen habe ich gestern 9 Stunden Memory Test laufen und das hat keinen Fehler "gefunden". Deswegen bin ich ein bisschen überfragt,ob es nun wirklich der Speicher ist?
mem test runter laden und jeden riegel einzeln testen..meist kommt die fehlermeldung direkt am anfang..hatte ich auch vor par tagen...
DirectX aktuell ?
Schaut so aus als würde sich der Starter von Warcraft aufhängen (wow-64.exe).Reparieren Funktion vielleicht mal durchlaufen lassen.
der bluecreen besagt nach meiner Erfahrung NICHT das der Arbeitsspeicher defekt ist sondern der Speicher deiner Grafikkarte. Im Bluescreen steht VidMM (VideoMeMory) und verweist nochmals auf einen DirektX fehler hin. Also entweder ist deine Grafikkarte hinüber oder es bestehen fehler im DirekX das die Graka Daten falsch gesendet bekommen oder falsch zurücksendet
PS wie bussard auch richtig sagt besteht ein weiterer Treiberkonflikt mit WOW
