Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\061114-16005-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\localymbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.17273.amd64fre.win7_gdr.130318-1532
Machine Name:
Kernel base = 0xfffff800`0285b000 PsLoadedModuleList = 0xfffff800`02a97e70
Debug session time: Wed Jun 11 04:06:27.815 2014 (UTC + 2:00)
System Uptime: 0 days 0:00:27.735
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa8004929038, f6000000, 181}
Probably caused by : AuthenticAMD
Followup: MachineOwner
1: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8004929038, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000f6000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000181, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_AuthenticAMD
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: f
STACK_TEXT:
fffff880`009eea08 fffff800`02824903 : 00000000`00000124 00000000`00000000 fffffa80`04929038 00000000`f6000000 : nt!KeBugCheckEx
fffff880`009eea10 fffff800`029e0543 : 00000000`00000001 fffffa80`049082b0 00000000`00000000 fffffa80`04908300 : hal!HalBugCheckSystem+0x1e3
fffff880`009eea50 fffff800`028245c8 : 00000000`00000728 fffffa80`049082b0 fffff880`009eedb0 00000000`00018600 : nt!WheaReportHwError+0x263
fffff880`009eeab0 fffff800`02823f1a : fffffa80`049082b0 fffff880`009eedb0 fffffa80`049082b0 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`009eec00 fffff800`02817e8f : fffff880`009e6180 00000000`00000001 fffff880`009eee30 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`009eec40 fffff800`028c912c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x47
fffff880`009eec70 fffff800`028c8f93 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`009eedb0 fffff800`028d77bc : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
fffff880`02f1bad0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeUpdateRunTime+0x9c
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: AuthenticAMD
IMAGE_NAME: AuthenticAMD
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_AuthenticAMD_PROCESSOR_CACHE
kd> !errrec fffffa8004929038
Common Platform Error Record @ fffffa8004929038
Record Id : 01cf8519b18da382
Severity : Fatal (1)
Length : 928
Creator : Microsoft
Notify Type : Machine Check Exception
Timestamp : 6/11/2014 2:06:27 (UTC)
Flags : 0x00000000
Section 0 : Processor Generic
Descriptor @ fffffa80049290b8
Section @ fffffa8004929190
Offset : 344
Length : 192
Flags : 0x00000001 Primary
Severity : Fatal
Proc. Type : x86/x64
Instr. Set : x64
Error Type : Cache error
Operation : Generic
Flags : 0x00
Level : 1
CPU Version : 0x0000000000040f32
Processor ID : 0x0000000000000001
Section 1 : x86/x64 Processor Specific
Descriptor @ fffffa8004929100
Section @ fffffa8004929250
Offset : 536
Length : 128
Flags : 0x00000000
Severity : Fatal
Local APIC Id : 0x0000000000000001
CPU Id : 32 0f 04 00 00 08 02 01 - 01 20 00 00 ff fb 8b 17
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00
Proc. Info 0 @ fffffa8004929250
Section 2 : x86/x64 MCA
Descriptor @ fffffa8004929148
Section @ fffffa80049292d0
Offset : 664
Length : 264
Flags : 0x00000000
Severity : Fatal
Error : ICACHEL1_SNOOP_ERR (Proc 1 Bank 1)
Status : 0xf600000000000181
Address : 0x000000000020ba80
Misc. : 0x0000000000000000
