Mein Arma 3 läuft 10 minuten mit 30-40 fps doch dann laggt es und es sind nur noch 1-2 fps fehler meldung:
Ich habe einen AmdFx4100 und eine gtx650ti boost 4gb ram und windows 7 32 bit [nichts übertaktet]
Client: Object 140:104 (type Type_88) not found.
Ref to nonnetwork object Agent 0x73208400
Ref to nonnetwork object Agent 0x734a2140
Ref to nonnetwork object Agent 0x72668780
Client: Object 140:104 (type Type_113) not found.
"Client time: Safety was true"
Client: Object 137:36 (type Type_124) not found.
Client: Object 137:36 (type Type_239) not found.
Virtual memory total 2047 MB (2147352576 B)
Virtual memory free 107 MB (112992256 B)
Physical memory free 837 MB (878632960 B)
Page file free 1781 MB (1868451840 B)
Process working set 1552 MB (1627987968 B)
Process page file used 1531 MB (1605861376 B)
Longest free VM region: 15073280 B
VM busy 2034606080 B (reserved 194260992 B, committed 1840345088 B, mapped 149868544 B), free 112746496 B
Small mapped regions: 53, size 307200 B
Ref to nonnetwork object Agent 0x29fd4080
Ref to nonnetwork object Agent 0x73208180
Ref to nonnetwork object Agent 0x7069e080
Virtual memory free 101 MB (105914368 B)
Physical memory free 838 MB (879579136 B)
Page file free 1795 MB (1882726400 B)
Process working set 1552 MB (1628250112 B)
Process page file used 1527 MB (1601720320 B)
Longest free VM region: 7999488 B
VM busy 2041683968 B (reserved 205500416 B, committed 1836183552 B, mapped 149868544 B), free 105668608 B
Physical memory free 838 MB (879271936 B)
Page file free 1795 MB (1882464256 B)
Virtual memory free 101 MB (106242048 B)
Physical memory free 836 MB (877068288 B)
Page file free 1792 MB (1879379968 B)
Process working set 1552 MB (1628110848 B)
Longest free VM region: 4194304 B
VM busy 2045616128 B (reserved 209670144 B, committed 1835945984 B, mapped 153800704 B), free 101736448 B
Physical memory free 836 MB (876965888 B)
Page file free 1792 MB (1879166976 B)
Process working set 1552 MB (1628217344 B)
VM busy 2041356288 B (reserved 205500416 B, committed 1835855872 B, mapped 149540864 B), free 105996288 B
Dieser abschnitt mit den VM busy wird gefühlte 1000 mal wiederholt.
Treiber hab ich einen alten nvidia treiber ausprobiert und den neuesten auch schon, übertaktet ist nichts.
