XoHoX
ich hab mit diesem Thema zwar schon im Bereich "Mainboards und Arbeitsspeicher" angefangen, jedoch bekomme ich immer mehr die Befürchtung das es nicht an eben jenen Komponenten liegt sondern am CPU. Weiss einer vielleicht Rat bezüglich dieses Problemes?
Code:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Machine Name:
Kernel base = 0xfffff800`03013000 PsLoadedModuleList = 0xfffff800`03258670
Debug session time: Sat Aug 27 03:09:41.802 2011 (UTC + 2:00)
System Uptime: 0 days 0:03:32.332
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 00000000`7efdf018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa8007ca5028, b201a000, 175}
Probably caused by : hardware
Followup: MachineOwner
2: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8007ca5028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b201a000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000175, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_AuthenticAMD
[COLOR=black]DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: prime95.exe
CURRENT_IRQL: f
STACK_TEXT:
fffff880`0316ca88 fffff800`0360ea3b : 00000000`00000124 00000000`00000000 fffffa80`07ca5028 00000000`b201a000 : nt!KeBugCheckEx
fffff880`0316ca90 fffff800`031a0513 : 00000000`00000001 fffffa80`07ca6ea0 00000000`00000000 fffffa80`07ca6ef0 : hal!HalBugCheckSystem+0x1e3
fffff880`0316cad0 fffff800`0360e700 : 00000000`00000728 fffffa80`07ca6ea0 fffff880`0316ce30 00000000`0421da00 : nt!WheaReportHwError+0x263
fffff880`0316cb30 fffff800`0360e052 : fffffa80`07ca6ea0 fffff880`0316ce30 fffffa80`07ca6ea0 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`0316cc80 fffff800`03601e8f : 00000000`04229780 00000000`00000001 fffff880`0316ceb0 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`0316ccc0 fffff800`0308e52c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x47
fffff880`0316ccf0 fffff800`0308e393 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`0316ce30 00000000`00551ea8 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
00000000`02344100 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x551ea8
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_AuthenticAMD_PROCESSOR_CACHE
