trevormacro
Hinweis der Moderation!
Wir haben mit dem Threadersteller eine Ausnahmeregelung getroffen, weswegen hier auch Diskussionen in Englisch geführt werden können.
Hello,
After have done my Voodoo5 6000 Gold Second Edtion I have a new project : Voodoo5 6000 rev.3700A WaterCooling edition. (with a special hard work of an excellent man)
http://img15.hostingpics.net/pics/773068Voodoo5k6twelftha.jpg
http://img15.hostingpics.net/pics/541930Voodoo5k6twelfthg.jpg
Step by step :
- Waterblocks :
That is the coding that allows the machine to make that logo on front waterblock
http://img11.hostingpics.net/pics/5080113dfxlogoproto.jpg
Delrin + Copper
http://img15.hostingpics.net/pics/261386delrincopper.jpg
Voodoo5 6000 heatsinks removed
http://img15.hostingpics.net/pics/974503v5k6heatsinksoff.jpg
Just a quick sketch up of the card and what needs to be cooled.
the green is the pcb, the bright red is the HiNT chip, and the 4 squares are the GPU's.
http://img15.hostingpics.net/pics/780325sketchup.jpg
The whole back of the card will be cooled.* One large block.* a large single piece of thermal tape will be used.
The one large sheet will touch every inch of the board and pull the heat off.
the chips themselves get hot. The back of the chips were probably getting hot from the lack of cooling on the top of them.
This rear block will take off any heat the top block will produce.* It will pull any heat off of every component that it touches.
http://img11.hostingpics.net/pics/236569Voodoo02.jpg
A CAD model of the card.* Things to cool in black, and things to avoid in red, and the very limited holes in the board.
http://img11.hostingpics.net/pics/533799Voodoo01.jpg
Basic overall shape :
http://img15.hostingpics.net/pics/798457Voodoo03.jpg
http://img15.hostingpics.net/pics/715695Voodoo04.jpg
The blue outline that is the funny shape is the copper
the black outline is the overall card.
The copper is what needs to be touching the chips, so I will avoid all those red areas.
The plastic is thick enough to just mill out depressions for the components.
So the black plastic will cover the entire card
giving you the sleek appearance of a seamless block.
A copper plate that touches the HiNT chip, GPU's and Ram.
Then the black plastic is a much larger piece that covers most of the card.
Each block will be 19mm thick.
V5k6 card is 1.6mm thick, and 19mm of copper and plastic on each side
All of my stuff (WaterCooling kit).
I can't put into words, how powerful just one of those fans are.
I will have to screw this thing to a table.
I firmly believe that the radiator will levitate if all three are on.
I am still speechless from the power of a single fan.
I have all the power imaginable, and it sounds like a jet starting up
http://img15.hostingpics.net/pics/315915list.jpg
http://img15.hostingpics.net/pics/241372watercoolingkit.jpg
Delta Fans 120 mm * 38 mm - 252 CFM ai capacity* :
http://img15.hostingpics.net/pics/138184watercoolingkitfans.jpg
http://img11.hostingpics.net/pics/404139Machine.jpg
Here is a print to scale (I hope) version of the copper section of the waterblock.
http://img11.hostingpics.net/pics/306626printoscale.jpg
The plastic top part will have the same top and left boundaries.
Cut a prototype out of aluminum
Here is a basic prototype of the copper board that will touch all the chips.
http://img11.hostingpics.net/pics/356098proto.jpg
A few minor improvements to a few lines of code and it will be ready to cut.
Block progress :
The backside blocks initial outer shape is cut. Fits like a charm.
http://img11.hostingpics.net/pics/252793blockprogress1.jpg
http://img15.hostingpics.net/pics/169861milling1.jpg
http://img15.hostingpics.net/pics/921631milling2.jpg
http://img15.hostingpics.net/pics/855447milling3.jpg
http://img15.hostingpics.net/pics/708993milling4.jpg
http://img15.hostingpics.net/pics/719926milling5.jpg
http://img15.hostingpics.net/pics/881878milling6.jpg
http://img15.hostingpics.net/pics/750424blockprogress2.jpg
http://img15.hostingpics.net/pics/204079blockprogress3.jpg
http://img15.hostingpics.net/pics/545242blockprogress4.jpg
http://img15.hostingpics.net/pics/665902blockprogressa.jpg
http://img15.hostingpics.net/pics/294454blockprogress5.jpg
http://img15.hostingpics.net/pics/841920blockprogress6.jpg
http://img15.hostingpics.net/pics/491491blockprogress7.jpg
Milling of the Vram section:
http://img15.hostingpics.net/pics/292564blockprogress8.jpg
I have good news and bad news. The bad news is the O-ring sealing didnt work. Thats a simple fix-i will seal it with a silicone gasket sealant along with the O-rings. So thats really not a big issue. It will never ever leak.
The good news is the block is very effective. when i was doing the leak test i pumped some cold water and the block instantly got very cold. The performance of these blocks are very good!
http://img11.hostingpics.net/pics/612373blockprogress9.jpg
Your reactions?
...Still In Development...
Hello,
Step by step :
- Waterblocks :
Delrin + Copper
Block progress :
Your reactions?
Go Voodoo, go!
