S0l4ris451
Hallo alle zusammen,
nerve mich schon des längeren mit dem Fehler Distributed COM 10016 herum. Hab alle möglichen Workarounds probiert.
Mein System AMD Ryzen 5 5600x @ 3,70 Ghz
Windows 11
Rtx 2080 Super
16 Gb Ballistix RAM
B550 Plus TUF Gaming
BeQuiet 800Watt
Hier die Fehlermeldung
Log Name: System
Source: Microsoft-Windows-DistributedCOM
Date: 02/08/2022 18:37:22
Event ID: 10016
Task Category: None
Level: Warning
Keywords: Classic
User: MANULHOMEPC\manue
Computer: ManulHomePC
Description:
The Anwendungsspezifisch permission settings do not grant Lokal Aktivierung permission for the COM Server application with CLSID
{2593F8B9-4EAF-457C-B68A-50F6B8EA6B54}
and APPID
{15C20B67-12E7-4BB6-92BB-7AFF07997402}
to the user MANULHOMEPC\manue SID (S-1-5-21-3532220067-668475093-2706778715-1001) from address LocalHost (unter Verwendung von LRPC) running in the application container Nicht verfügbar SID (Nicht verfügbar). This security permission can be modified using the Component Services administrative tool.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
<EventID Qualifiers="0">10016</EventID>
<Version>0</Version>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2022-08-02T16:37:22.9412135Z" />
<EventRecordID>2204</EventRecordID>
<Correlation ActivityID="{f8bb255d-a676-0006-74c4-c5f876a6d801}" />
<Execution ProcessID="1344" ThreadID="15420" />
<Channel>System</Channel>
<Computer>ManulHomePC</Computer>
<Security UserID="S-1-5-21-3532220067-668475093-2706778715-1001" />
</System>
<EventData>
<Data Name="param1">Anwendungsspezifisch</Data>
<Data Name="param2">Lokal</Data>
<Data Name="param3">Aktivierung</Data>
<Data Name="param4">{2593F8B9-4EAF-457C-B68A-50F6B8EA6B54}</Data>
<Data Name="param5">{15C20B67-12E7-4BB6-92BB-7AFF07997402}</Data>
<Data Name="param6">MANULHOMEPC</Data>
<Data Name="param7">manue</Data>
<Data Name="param8">S-1-5-21-3532220067-668475093-2706778715-1001</Data>
<Data Name="param9">LocalHost (unter Verwendung von LRPC)</Data>
<Data Name="param10">Nicht verfügbar</Data>
<Data Name="param11">Nicht verfügbar</Data>
</EventData>
</Event>
Bitte um Hilfe und freue mich auf Antworten!
Leider hängt der Cursor und der Sound ist für sekundenbruchteile verzerrt ansonsten wäre mir das egal. Bitte um Rückmeldung! Danke!
Windows 11
Rtx 2080 Super
16 Gb Ballistix RAM
BeQuiet 800Watt
Log Name: System
Event ID: 10016
Task Category: None
Level: Warning
Keywords: Classic
Description:
and APPID
Event Xml:
<System>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
</System>
<EventData>
</EventData>
</Event>
