[Sammelthread] Rocket League
Gestern in einem Match. Es geht hin und her. Dann ein Bogenball des Gegners auf unser Tor. Ich zurück und den Plan von der Seite kommend den Ball kurz vorm Tor abzufangen. Der Ball ist also über mir. Und dann. Ja also dann.
Eine dezente Meldung (sehr wichtig)
NUR NOCH 60 SEKUNDEN :lol:
Danke für die Info aber den Ball konnte ich nicht mehr fixieren danke danke danke.
Neuer Patch gestern erschienen - Patch Notes V1.36:
BUG FIXES
GENERAL
Casual Matches will no longer cancel if the server does not have enough players. Bots will once again fill slots for missing players
The “Find Match” button on the Matchmaking menu can now be selected/highlighted, allowing you to search for a match by pressing A (Xbox) or Cross (PS4) when the button is selected
Further optimized Supersonic Trails that were causing FPS and performance issues on some hardware
Fixed a bug with Quick Chat that caused players to automatically say “Great Pass!” or other options instead of being able to select an intended chat option
Fixed a bug where typing in Party Chat in the Main Menu would skip songs in the selected Playlist
Reverted a change that caused Controller Vibration to be weaker since the Anniversary update
The “Hide Competitive Divisions” option will now work correctly with the new Find Match menu
Corrected a suspension issue with the Batmobile and Mantis that caused them to be more visually elevated than pre-Anniversary Update
Fixed issues with the grass on Champions Field on Low and Medium Graphics settings
Fixed a bug with Spectator cameras focusing on the center of the field after a goal is scored
Fixed issue where an item’s quality was not being verified during a trade
Reduced Car Engine volume relative to other sounds and made distant cars less audible
Corrected timing on Champions Field Announcer narration
Moin...ich versuch es mal hier. Ich suche nach einem Team/Partner für "Standard" (3vs3), welches/welcher mir hilft endlich dahin zu kommen wo ich hin will bzw. mMn auch sein sollte: Diamant.
Leider gibt es unter meinen bisherigen Spielekollegen niemanden der an RL so "kompetetiv" rangeht wie ich. Und mit Randoms spielen ist halt...naja...Random. :ugly:
Somit kämpfe ich mich seit langem im Bereich um Platin2 herum ab und muss mich entweder mit den genannten Kollegen (alle max. Gold2) oder eben mit Randoms zufrieden geben.
So kommt man aber leider nicht wirklich weiter...mal läuft es und es geht ne Liga hoch...dann bekommt man wieder nur solche "was macht der in Platin!?"-Spieler und verliert alles vorher hart erspielte.
Und leider fährt der Fahrstuhl schneller abwärts als nach aufwärts (zumindest habe ich das Gefühl).
Wenn also jemand Bock oder noch einen Platz frei hat würde ich mich über eine Rückmeldung freuen. Headset und so weiter ist bei Bedarf natürlich alles vorhanden. :daumen:
