[Sammelthread] ASUS Rampage II Extreme
D!str(+)yer
PCGHX-HWbot-Member (m/w)
rog_white-jpg.95907
Specifications
CPU:
Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor Supports Intel® Dynamic Speed Technology
Support List
Chipset:
  • Intel® X58 /ICH10R
System Bus:
  • Up to 6400 MT/s with QuickPath Interconnection
Memory:
6 x DIMM, Max. 24 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 Non-ECC,Un-buffered Memory
Triple channel memory architecture
* Supports Intel® Extreme Memory Profile (XMP)
**Due to Intel spec definition, DIMMs of DDR3-1333 or above are out of spec.
Support List
Expansion Slots:
  • 3 x PCIe 2.0 x16 support at x16, x8, x8, or dual x16 speed
  • 2 x PCIe 2.0 x1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 1 x PCI 2.2
Multi-GPU Support:
Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
* We recommend that you use full tower chassis for building a 3-Way SLI system.
Storage:
-> Intel ICH10R controller
6 xSATA 3 Gb/s ports
Intel Matrix Storage Technology Support RAID 0,1,5,10
-> JMicron® JMB363 PATA and SATA controller
1 xUltraDMA 133/100/66/33 for up to 2 PATA devices
1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
1 xSATA 3.0 Gb/s port
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2 Support Teaming Technology
Audio:
SupremeFX X-Fi Audio Card
- ADI® AD2000B 8 -Channel High Definition Audio CODEC
- EAX® Advanced™ HD 4.0
- X-Fi CMSS®-3D
- X-Fi Crystalizer™
- Creative ALchemy
- Supports 1 x S/PDIF out header
- Supports Coaxial/Optical S/PDIF out ports on rear
IEEE 1394:
  • 2 x 1394a ports (1 port at back I/O, 1 port onboard)
USB:
  • 12 USB 2.0 ports (6 ports at mid-board, 6 ports at back panel)
Overclocking Features
TweakIt
ProbeIt
Extreme Engine with ML Cap
- 16-phase CPU power
- 3-phase QPI/DRAM power
- 3-phase NB power
- 3-phase Memory power
- ML Caps on CPU, memory and NB respectively
CPU Level Up
iROG
Extreme Tweaker
BIOS Flashback
Loadline Calibration
Intelligent overclocking tools:
- AI Gear 4™
- ASUS AI Booster Utility
- O.C Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
  • External LCD Poster
  • Onboard Switches: Power / Reset / Clr CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ROG BIOS Wallpaper
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Back Panel I/O Ports:
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Internal I/O Connectors:
  • 3 x USB connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector
  • 7 x SATA connectors
  • 1 x IEEE 1394a connector
  • 1 x Chassis Fan connector
  • 1 x 8-pin ATX 12V Power connector
  • 24-pin ATX Power connector
  • 1 x EL I/O Shield Connector
  • 3 x thermal sensor connector
  • 1 x En/Dis-able Clr CMOS connector
  • System Panel
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 8 x ProbeIt connectors
  • 1 x LCD Poster connector
  • 1 x BIOS FlashBack boot up selection header
  • 1 x ROG light connector
BIOS:
16 Mb Flash ROM
AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.4, ACPI2.0a Multi-Language BIOS
Accessories:
  • ProbeIt Cable
  • 3-Way SLI Cable
  • SLI Cable
  • ASUS Optional Fan
  • SupremeFX X-Fi Audio Card
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
Support Disc
  • Drivers and applications
  • Sound Blaster X-Fi Utility
  • Futuremark® 3DMark® Vantage Advanced Edition
  • Kaspersky® Anti-Virus
  • ASUS TurboV utility
  • ASUS PC Probe II
  • ASUS Update
  • ASUS AI Suite
Aktuellste Treiber
ASUSTeK Computer Inc.-Support-
Bios Versionen
0407
0503
0602
0705
0804
0805
0903
1001
1104
1204
1306
1406
1504
1639
1704
Neu!
Deutsches Handbuch
Link
User Review von McZonk
http://extreme.pcgameshardware.de/l...9-review-asus-rampage-ii-extreme-im-test.html
Bilder vom Layout folgen :daumen:
Changelog:
17.04.2009 - Sammelthread geht online
24.04.2009 - Bios Bilder gehen online
Cool, danke für den Thread.
Wenn ich bei meinem Freund benche, kann ich hier mögliche Frage reinstellen und hoffen, dass jemand hilft, der auch ein R2E hat.
mfg Eiswolf93
nabend
also folgendes
läuft ein Asus Rampage II Extreme mit DDR3-1800 bzw mit DDR3-1866 bzw mit DDR3-2000 Speicher?
darauf würde mir gesagt
"Ja, tut es. Allerdings musst du den BLCK anheben."
und deshalb meine frage: was ist BLCK :huh:? und wie mach ich das und wo etc.:huh::huh:
thx schonmal
Würde mich über eine schnelle Antwort freuen weil ich den kram so schnell wie möglich kaufen möchte.
mfg flashback830
ok, dann gehts hier weiter^^
erst mal würde ich eher niedrigeren Latenzen wählen, statt einem höheren takt. das bringt etwas mehr.
Ich hab @ time DDR3-1600 mit CL8 am laufen, statt DDR3-1800 Cl9 ;)
Dann zitiere ich mich mal selber aus meinem Tagebuch.
Teil 3
Overclocking
Vorweg ein paar infos um erfolgreich einen i7 zu übertakten.
Mit dem i7 gibt es keinen FSB mehr. Dadurch gestaltet sich das Übertakten etwas schwieriger. Zumindest auf den ersten blick. Bedenkt man ein paar regeln, ist das alles halb so wild.
Ausschlaggebend ist hier der BCLK (Base Clock). Von diesem Takt, der aktuellen bei allen i7 CPUs noch bei 133MHz liegt, errechnen sich alle wichtigen Taktraten durch teiler.
BCLK x Multiplikator ergibt den Gesamttakt ( 20x133 = 2,66GHz beim i7-920).
Ganz so einfach ist es aber nicht, das man einfach den BCLK anheben kann.
Besonders wichtig sind "UCLK Frequency" und "QPI Frequency".
UCLK ist der Uncore takt der zum beispiel auch mit dem cache zusammen hängt.
Der ULCK takt muss mindestens doppelt so hoch wie der effektive speichertakt sein!!
Das ist noch nicht alles. Dazu kommt noch der QPI takt. Dieser muss größer sein als der ULCK takt!
Also noch mal anschaulich:
UCLK takt > 2x effektiver Ramtakt
QPI takt > ULCK
2x effektiver Ramtakt < UCLK takt < QPI takt
Beim Rampage II Extrem bekommt man Glücklicherweise überall die effektiven Taktraten angezeigt und muss nicht mit teilern arbeiten. Das erleichtert das Arbeiten ungemein!
Wenn du dabei den CPU nicht übertakten willst, musst du den Multiplikator einfach senken.
Alle Klarheiten beseitigt :D
Ich hoffe das Hilft dir erst mal weiter. Am Wochenende werd ich den thread noch was ergänzen, auch mit Bildern vom Bios etc pp., aber jetzt brauch ich dringend Schlaf :ugly:
sorry aber ich peil jetzt garichts mehr ....
also hatte mir gedacht das board zuholen nen i7-920 ( den dann so [voarsgestzt ich find ne gscheite anleitung was wo im bios eingestellt werden muss] auf 3,6-3,8 hoch) und dazu nen 1866er oder 2000er -12gb arbeitsspeicher
hatte vor mir den kram so am freitag oder spätestens montag zu bestellen aber ich hab beim besten willen nich den plan von dem was da steht aber immerhin weiß ich jetzt was BCLK is :lol:
Dann hab ich mein ziel ja erreicht^^
Die Anleitung kann ich noch mal was ausschmücken das man es was besser versteht.
3,6-3,8GHz sollten kein Größeres Problem sein, bei entsprechender Kühlung.
Denn speicher kannst du ruhig hohlen.
Selbst wenn du nicht den passenden teiler für DDR3-2000 hast, kannst du im Gegenzug einfach die Latenzen schärfer stellen ;)
kk sind in meiem warenkorb xD - jetzt brauch ich nur noch nen kühler >>
http://extreme.pcgameshardware.de/wasserkuehlung/51433-zalman-reserator-xt.html#post736803 << wenn de mir da noch helfen könntest. und dann müsst ich noch wiessen wie ich das dann alles einstellen muss - und vorall wie was ich wo im bios machen muss um auf die 3,8 oder evtl sogar mehr zu kommen xD
Von WaKü hab ich nicht so den plan. Aber hier im Forum gibts da genug How-to's und beispiel Zusammenstellungen. Das musst du dir ma anschauen.
ok kram bestellt Paketgewicht: ca. 48 kg :lol::lol::lol:denk und hoffe ma so montag bis dienstag sollte der kram da sein und dann kommt das schwierige - takten xD
48kg :wow:
Haste nen Panzer mit bestellt :ugly:
*update*
Bilder vom Bios online.
Speziell zur Ram Frage noch mal:
Teiler bei 133MHz BLCK (Standard)
Und bei 200MHz
ahh ok danke - dann kann ich das ja bald versuchen
- und zum panzer naja da is noch n tower fürn kumpel und einer für mich jeweils 18kg und der kühlkerper wiegt auch noch ma 3kg wie der rest zusammen kommt weiß ich auch nich so genau , vlt weil alternate immer so großzügig verpackt
so board is da und rest zum teila uch nur die kühlung kommt erst morgen - trozdem schon die erste frage. da sind 6 blaue SATA solts und ein schwarzer - wo isn da der unterschied zwischen dem schawrzen und den blauen ?
