TWOFISH2.C -- Optimized C API calls for TWOFISH AES submission
Submitters:
Bruce Schneier, Counterpane Systems
Doug Whiting, Hi/fn
John Kelsey, Counterpane Systems
Chris Hall, Counterpane Systems
David Wagner, UC Berkeley
Code Author: Doug Whiting, Hi/fn
Version 1.00 April 1998
Copyright 1998, Hi/fn and Counterpane Systems. All rights reserved.
Notes:
* Optimized version
* Tab size is set to 4 characters in this file
#include "AES.h"
#include "TABLE.h"
#include <memory.h>
#include <assert.h>
[COLOR=royalblue][B]#define HandleError(x) HandleErrorImpl(x, __FILE__, __LINE__)[/B]
#if defined(min_key) && !defined(MIN_KEY)
#define MIN_KEY 1 /* toupper() */
#elif defined(part_key) && !defined(PART_KEY)
#define PART_KEY 1
#elif defined(zero_key) && !defined(ZERO_KEY)
#define ZERO_KEY 1
#endif
#ifdef USE_ASM
extern int useAsm; /* ok to use ASM code? */
typedef int cdecl CipherProc
(cipherInstance *cipher, keyInstance *key,BYTE *input,int inputLen,BYTE *outBuffer);
typedef int cdecl KeySetupProc(keyInstance *key);
extern CipherProc *blockEncrypt_86; /* ptr to ASM functions */
extern CipherProc *blockDecrypt_86;
extern KeySetupProc *reKey_86;
extern DWORD cdecl TwofishAsmCodeSize(void);
#endif
* Constants/Macros/Tables
#define CONST /* help syntax from C++, NOP here */
CONST fullSbox MDStab; /* not actually const. Initialized ONE time */
int needToBuildMDS=1; /* is MDStab initialized yet? */
#define BIG_TAB 0
#if BIG_TAB
BYTE bigTab[4][256][256]; /* pre-computed S-box */
#endif
/* number of rounds for various key sizes: 128, 192, 256 */
/* (ignored for now in optimized code!) */
CONST int numRounds[4]= {0,ROUNDS_128,ROUNDS_192,ROUNDS_256};
#if REENTRANT
#define _sBox_ key->sBox8x32
#else
static fullSbox _sBox_; /* permuted MDStab based on keys */
#endif
#define _sBox8_(N) (((BYTE *) _sBox_) + (N)*256)
/*------- see what level of S-box precomputation we need to do -----*/
#if defined(ZERO_KEY)
#define MOD_STRING "(Zero S-box keying)"
#define Fe32_128(x,R) \
( MDStab[0][p8(01)[p8(02)[_b(x,R )]^b0(SKEY[1])]^b0(SKEY[0])] ^ \
MDStab[1][p8(11)[p8(12)[_b(x,R+1)]^b1(SKEY[1])]^b1(SKEY[0])] ^ \
MDStab[2][p8(21)[p8(22)[_b(x,R+2)]^b2(SKEY[1])]^b2(SKEY[0])] ^ \
MDStab[3][p8(31)[p8(32)[_b(x,R+3)]^b3(SKEY[1])]^b3(SKEY[0])] )
#define Fe32_192(x,R) \
( MDStab[0][p8(01)[p8(02)[p8(03)[_b(x,R )]^b0(SKEY[2])]^b0(SKEY[1])]^b0(SKEY[0])] ^ \
MDStab[1][p8(11)[p8(12)[p8(13)[_b(x,R+1)]^b1(SKEY[2])]^b1(SKEY[1])]^b1(SKEY[0])] ^ \
MDStab[2][p8(21)[p8(22)[p8(23)[_b(x,R+2)]^b2(SKEY[2])]^b2(SKEY[1])]^b2(SKEY[0])] ^ \
MDStab[3][p8(31)[p8(32)[p8(33)[_b(x,R+3)]^b3(SKEY[2])]^b3(SKEY[1])]^b3(SKEY[0])] )
#define Fe32_256(x,R) \
( MDStab[0][p8(01)[p8(02)[p8(03)[p8(04)[_b(x,R )]^b0(SKEY[3])]^b0(SKEY[2])]^b0(SKEY[1])]^b0(SKEY[0])] ^ \
MDStab[1][p8(11)[p8(12)[p8(13)[p8(14)[_b(x,R+1)]^b1(SKEY[3])]^b1(SKEY[2])]^b1(SKEY[1])]^b1(SKEY[0])] ^ \
MDStab[2][p8(21)[p8(22)[p8(23)[p8(24)[_b(x,R+2)]^b2(SKEY[3])]^b2(SKEY[2])]^b2(SKEY[1])]^b2(SKEY[0])] ^ \
MDStab[3][p8(31)[p8(32)[p8(33)[p8(34)[_b(x,R+3)]^b3(SKEY[3])]^b3(SKEY[2])]^b3(SKEY[1])]^b3(SKEY[0])] )
#define GetSboxKey DWORD SKEY[4]; /* local copy */ \
memcpy(SKEY,key->sboxKeys,sizeof(SKEY));
#elif defined(MIN_KEY)
#define MOD_STRING "(Minimal keying)"
#define Fe32_(x,R)(MDStab[0][p8(01)[_sBox8_(0)[_b(x,R )]] ^ b0(SKEY0)] ^ \
MDStab[1][p8(11)[_sBox8_(1)[_b(x,R+1)]] ^ b1(SKEY0)] ^ \
MDStab[2][p8(21)[_sBox8_(2)[_b(x,R+2)]] ^ b2(SKEY0)] ^ \
MDStab[3][p8(31)[_sBox8_(3)[_b(x,R+3)]] ^ b3(SKEY0)])
#define sbSet(N,i,J,v) { _sBox8_(N)[i+J] = v; }
#define GetSboxKey DWORD SKEY0 = key->sboxKeys[0] /* local copy */
#elif defined(PART_KEY)
#define MOD_STRING "(Partial keying)"
#define Fe32_(x,R)(MDStab[0][_sBox8_(0)[_b(x,R )]] ^ \
MDStab[1][_sBox8_(1)[_b(x,R+1)]] ^ \
MDStab[2][_sBox8_(2)[_b(x,R+2)]] ^ \
MDStab[3][_sBox8_(3)[_b(x,R+3)]])
#define GetSboxKey
#else /* default is FULL_KEY */
#ifndef FULL_KEY
#define FULL_KEY 1
#endif
#if BIG_TAB
#define TAB_STR " (Big table)"
#else
#define TAB_STR
#endif
#ifdef COMPILE_KEY
#define MOD_STRING "(Compiled subkeys)" TAB_STR
#else
#define MOD_STRING "(Full keying)" TAB_STR
#endif
/* Fe32_ does a full S-box + MDS lookup. Need to #define _sBox_ before use.
Note that we "interleave" 0,1, and 2,3 to avoid cache bank collisions
in optimized assembly language.
#define Fe32_(x,R) (_sBox_[0][2*_b(x,R )] ^ _sBox_[0][2*_b(x,R+1)+1] ^ \
_sBox_[2][2*_b(x,R+2)] ^ _sBox_[2][2*_b(x,R+3)+1])
/* set a single S-box value, given the input byte */
#define sbSet(N,i,J,v) { _sBox_[N&2][2*i+(N&1)+2*J]=MDStab[N][v]; }
#define GetSboxKey
#endif
CONST char *moduleDescription ="Optimized C ";
CONST char *modeString =MOD_STRING;
/* macro(s) for debugging help */
#define CHECK_TABLE 0 /* nonzero --> compare against "slow" table */
#define VALIDATE_PARMS 0 /* disable for full speed */
#include "DEBUG.h" /* debug display macros */
/* end of debug macros */
#ifdef GetCodeSize
extern DWORD Here(DWORD x); /* return caller's address! */
DWORD TwofishCodeStart(void) { return Here(0); }
#endif
* Function Name: TableOp
* Function: Handle table use checking
* Arguments: op = what to do (see TAB_* defns in AES.H)
* Return: TRUE --> done (for TAB_QUERY)
* Notes: This routine is for use in generating the tables KAT file.
* For this optimized version, we don't actually track table usage,
* since it would make the macros incredibly ugly. Instead we just
* run for a fixed number of queries and then say we're done.
int TableOp(int op)
static int queryCnt=0;
switch (op)
case TAB_DISABLE:
break;
case TAB_ENABLE:
break;
case TAB_RESET:
queryCnt=0;
break;
case TAB_QUERY:
queryCnt++;
if (queryCnt < TAB_MIN_QUERY)
return FALSE;
return TRUE;
* Function Name: ParseHexDword
* Function: Parse ASCII hex nibbles and fill in key/iv dwords
* Arguments: bit = # bits to read
* srcTxt = ASCII source
* d = ptr to dwords to fill in
* dstTxt = where to make a copy of ASCII source
* (NULL ok)
* Return: Zero if no error. Nonzero --> invalid hex or length
* Notes: Note that the parameter d is a DWORD array, not a byte array.
* This routine is coded to work both for little-endian and big-endian
* architectures. The character stream is interpreted as a LITTLE-ENDIAN
* byte stream, since that is how the Pentium works, but the conversion
* happens automatically below.
int ParseHexDword(int bits,CONST char *srcTxt,DWORD *d,char *dstTxt)
int i;
char c;
DWORD b;
union /* make sure LittleEndian is defined correctly */
BYTE b[4];
DWORD d[1];
} v;
v.d[0]=1;
if (v.b[0 ^ ADDR_XOR] != 1)
return BAD_ENDIAN; /* make sure compile-time switch is set ok */
#if VALIDATE_PARMS
#if ALIGN32
if (((int)d) & 3)
return BAD_ALIGN32;
#endif
#endif
for (i=0;i*32<bits;i++)
d[i]=0; /* first, zero the field */
for (i=0;i*4<bits;i++) /* parse one nibble at a time */
{ /* case out the hexadecimal characters */
c=srcTxt[i];
if (dstTxt) dstTxt[i]=c;
if ((c >= '0') && (c <= '9'))
b=c-'0';
else if ((c >= 'a') && (c <= 'f'))
b=c-'a'+10;
else if ((c >= 'A') && (c <= 'F'))
b=c-'A'+10;
else
return BAD_KEY_MAT; /* invalid hex character */
/* works for big and little endian! */
d[i/8] |= b << (4*((i^1)&7));
return 0; /* no error */
#if CHECK_TABLE
* Function Name: f32
* Function: Run four bytes through keyed S-boxes and apply MDS matrix
* Arguments: x = input to f function
* k32 = pointer to key dwords
* keyLen = total key length (k32 --> keyLey/2 bits)
* Return: The output of the keyed permutation applied to x.
* Notes:
* This function is a keyed 32-bit permutation. It is the major building
* block for the Twofish round function, including the four keyed 8x8
* permutations and the 4x4 MDS matrix multiply. This function is used
* both for generating round subkeys and within the round function on the
* block being encrypted.
* This version is fairly slow and pedagogical, although a smartcard would
* probably perform the operation exactly this way in firmware. For
* ultimate performance, the entire operation can be completed with four
* lookups into four 256x32-bit tables, with three dword xors.
* The MDS matrix is defined in TABLE.H. To multiply by Mij, just use the
* macro Mij(x).
DWORD f32(DWORD x,CONST DWORD *k32,int keyLen)
BYTE b[4];
/* Run each byte thru 8x8 S-boxes, xoring with key byte at each stage. */
/* Note that each byte goes through a different combination of S-boxes.*/
*((DWORD *)b) = Bswap(x); /* make b[0] = LSB, b[3] = MSB */
switch (((keyLen + 63)/64) & 3)
case 0: /* 256 bits of key */
b[0] = p8(04)[b[0]] ^ b0(k32[3]);
b[1] = p8(14)[b[1]] ^ b1(k32[3]);
b[2] = p8(24)[b[2]] ^ b2(k32[3]);
b[3] = p8(34)[b[3]] ^ b3(k32[3]);
/* fall thru, having pre-processed b[0]..b[3] with k32[3] */
case 3: /* 192 bits of key */
b[0] = p8(03)[b[0]] ^ b0(k32[2]);
b[1] = p8(13)[b[1]] ^ b1(k32[2]);
b[2] = p8(23)[b[2]] ^ b2(k32[2]);
b[3] = p8(33)[b[3]] ^ b3(k32[2]);
/* fall thru, having pre-processed b[0]..b[3] with k32[2] */
case 2: /* 128 bits of key */
b[0] = p8(00)[p8(01)[p8(02)[b[0]] ^ b0(k32[1])] ^ b0(k32[0])];
b[1] = p8(10)[p8(11)[p8(12)[b[1]] ^ b1(k32[1])] ^ b1(k32[0])];
b[2] = p8(20)[p8(21)[p8(22)[b[2]] ^ b2(k32[1])] ^ b2(k32[0])];
b[3] = p8(30)[p8(31)[p8(32)[b[3]] ^ b3(k32[1])] ^ b3(k32[0])];
/* Now perform the MDS matrix multiply inline. */
return ((M00(b[0]) ^ M01(b[1]) ^ M02(b[2]) ^ M03(b[3])) ) ^
((M10(b[0]) ^ M11(b[1]) ^ M12(b[2]) ^ M13(b[3])) << 8) ^
((M20(b[0]) ^ M21(b[1]) ^ M22(b[2]) ^ M23(b[3])) << 16) ^
((M30(b[0]) ^ M31(b[1]) ^ M32(b[2]) ^ M33(b[3])) << 24) ;
#endif /* CHECK_TABLE */
* Function Name: RS_MDS_encode
* Function: Use (12,8) Reed-Solomon code over GF(256) to produce
* a key S-box dword from two key material dwords.
* Arguments: k0 = 1st dword
* k1 = 2nd dword
* Return: Remainder polynomial generated using RS code
* Notes:
* Since this computation is done only once per reKey per 64 bits of key,
* the performance impact of this routine is imperceptible. The RS code
* chosen has "simple" coefficients to allow smartcard/hardware implementation
* without lookup tables.
DWORD RS_MDS_Encode(DWORD k0,DWORD k1)
int i,j;
DWORD r;
for (i=r=0;i<2;i++)
r ^= (i) ? k0 : k1; /* merge in 32 more key bits */
for (j=0;j<4;j++) /* shift one byte at a time */
RS_rem(r);
return r;
* Function Name: BuildMDS
* Function: Initialize the MDStab array
* Arguments: None.
* Return: None.
* Notes:
* Here we precompute all the fixed MDS table. This only needs to be done
* one time at initialization, after which the table is "CONST".
void BuildMDS(void)
int i;
DWORD d;
BYTE m1[2],mX[2],mY[4];
for (i=0;i<256;i++)
m1[0]=P8x8[0][i]; /* compute all the matrix elements */
mX[0]=(BYTE) Mul_X(m1[0]);
mY[0]=(BYTE) Mul_Y(m1[0]);
m1[1]=P8x8[1][i];
mX[1]=(BYTE) Mul_X(m1[1]);
mY[1]=(BYTE) Mul_Y(m1[1]);
#undef Mul_1 /* change what the pre-processor does with Mij */
#undef Mul_X
#undef Mul_Y
#define Mul_1 m1 /* It will now access m01[], m5B[], and mEF[] */
#define Mul_X mX
#define Mul_Y mY
#define SetMDS(N) \
b0(d) = M0##N[P_##N##0]; \
b1(d) = M1##N[P_##N##0]; \
b2(d) = M2##N[P_##N##0]; \
b3(d) = M3##N[P_##N##0]; \
MDStab[N][i] = d;
SetMDS(0); /* fill in the matrix with elements computed above */
SetMDS(1);
SetMDS(2);
SetMDS(3);
#undef Mul_1
#undef Mul_X
#undef Mul_Y
#define Mul_1 Mx_1 /* re-enable true multiply */
#define Mul_X Mx_X
#define Mul_Y Mx_Y
#if BIG_TAB
int j,k;
BYTE *q0,*q1;
for (i=0;i<4;i++)
switch (i)
case 0: q0=p8(01); q1=p8(02); break;
case 1: q0=p8(11); q1=p8(12); break;
case 2: q0=p8(21); q1=p8(22); break;
case 3: q0=p8(31); q1=p8(32); break;
for (j=0;j<256;j++)
for (k=0;k<256;k++)
bigTab[i][j][k]=q0[q1[k]^j];
#endif
needToBuildMDS=0; /* NEVER modify the table again! */
* Function Name: ReverseRoundSubkeys
* Function: Reverse order of round subkeys to switch between encrypt/decrypt
* Arguments: key = ptr to keyInstance to be reversed
* newDir = new direction value
* Return: None.
* Notes:
* This optimization allows both blockEncrypt and blockDecrypt to use the same
* "fallthru" switch statement based on the number of rounds.
* Note that key->numRounds must be even and >= 2 here.
void ReverseRoundSubkeys(keyInstance *key,BYTE newDir)
DWORD t0,t1;
register DWORD *r0=key->subKeys+ROUND_SUBKEYS;
register DWORD *r1=r0 + 2*key->numRounds - 2;
for (;r0 < r1;r0+=2,r1-=2)
t0=r0[0]; /* swap the order */
t1=r0[1];
r0[0]=r1[0]; /* but keep relative order within pairs */
r0[1]=r1[1];
r1[0]=t0;
r1[1]=t1;
key->direction=newDir;
* Function Name: Xor256
* Function: Copy an 8-bit permutation (256 bytes), xoring with a byte
* Arguments: dst = where to put result
* src = where to get data (can be same asa dst)
* b = byte to xor
* Return: None
* Notes:
* BorlandC's optimization is terrible! When we put the code inline,
* it generates fairly good code in the *following* segment (not in the Xor256
* code itself). If the call is made, the code following the call is awful!
* The penalty is nearly 50%! So we take the code size hit for inlining for
* Borland, while Microsoft happily works with a call.
#if defined(__BORLANDC__) /* do it inline */
#define Xor32(dst,src,i) { ((DWORD *)dst)[i] = ((DWORD *)src)[i] ^ tmpX; }
#define Xor256(dst,src,b) \
register DWORD tmpX=0x01010101u * b;\
for (i=0;i<64;i+=4) \
{ Xor32(dst,src,i ); Xor32(dst,src,i+1); Xor32(dst,src,i+2); Xor32(dst,src,i+3); } \
#else /* do it as a function call */
void Xor256(void *dst,void *src,BYTE b)
register DWORD x=b*0x01010101u; /* replicate byte to all four bytes */
register DWORD *d=(DWORD *)dst;
register DWORD *s=(DWORD *)src;
#define X_8(N) { d[N]=s[N] ^ x; d[N+1]=s[N+1] ^ x; }
#define X_32(N) { X_8(N); X_8(N+2); X_8(N+4); X_8(N+6); }
X_32(0 ); X_32( 8); X_32(16); X_32(24); /* all inline */
d+=32; /* keep offsets small! */
s+=32;
#endif
* Function Name: reKey
* Function: Initialize the Twofish key schedule from key32
* Arguments: key = ptr to keyInstance to be initialized
* Return: TRUE on success
* Notes:
* Here we precompute all the round subkeys, although that is not actually
* required. For example, on a smartcard, the round subkeys can
* be generated on-the-fly using f32()
int reKey(keyInstance *key)
int i,j,k64Cnt,keyLen;
int subkeyCnt;
DWORD A=0,B=0,q;
DWORD sKey[MAX_KEY_BITS/64],k32e[MAX_KEY_BITS/64],k32o[MAX_KEY_BITS/64];
BYTE L0[256],L1[256]; /* small local 8-bit permutations */
#if VALIDATE_PARMS
#if ALIGN32
if (((int)key) & 3)
return BAD_ALIGN32;
if ((key->keyLen % 64) || (key->keyLen < MIN_KEY_BITS))
return BAD_KEY_INSTANCE;
#endif
#endif
if (needToBuildMDS) /* do this one time only */
BuildMDS();
#define F32(res,x,k32) \
DWORD t=x; \
switch (k64Cnt & 3) \
case 0: /* same as 4 */ \
b0(t) = p8(04)[b0(t)] ^ b0(k32[3]); \
b1(t) = p8(14)[b1(t)] ^ b1(k32[3]); \
b2(t) = p8(24)[b2(t)] ^ b2(k32[3]); \
b3(t) = p8(34)[b3(t)] ^ b3(k32[3]); \
/* fall thru, having pre-processed t */ \
case 3: b0(t) = p8(03)[b0(t)] ^ b0(k32[2]); \
b1(t) = p8(13)[b1(t)] ^ b1(k32[2]); \
b2(t) = p8(23)[b2(t)] ^ b2(k32[2]); \
b3(t) = p8(33)[b3(t)] ^ b3(k32[2]); \
case 2: /* 128-bit keys (optimize for this case) */ \
res= MDStab[0][p8(01)[p8(02)[b0(t)] ^ b0(k32[1])] ^ b0(k32[0])] ^ \
MDStab[1][p8(11)[p8(12)[b1(t)] ^ b1(k32[1])] ^ b1(k32[0])] ^ \
MDStab[2][p8(21)[p8(22)[b2(t)] ^ b2(k32[1])] ^ b2(k32[0])] ^ \
MDStab[3][p8(31)[p8(32)[b3(t)] ^ b3(k32[1])] ^ b3(k32[0])] ; \
#if !CHECK_TABLE
#if defined(USE_ASM) /* only do this if not using assember */
if (!(useAsm & 4))
#endif
#endif
subkeyCnt = ROUND_SUBKEYS + 2*key->numRounds;
keyLen=key->keyLen;
k64Cnt=(keyLen+63)/64; /* number of 64-bit key words */
for (i=0,j=k64Cnt-1;i<k64Cnt;i++,j--)
{ /* split into even/odd key dwords */
k32e[i]=key->key32[2*i ];
k32o[i]=key->key32[2*i+1];
/* compute S-box keys using (12,8) Reed-Solomon code over GF(256) */
sKey[j]=key->sboxKeys[j]=RS_MDS_Encode(k32e[i],k32o[i]); /* reverse order */
#ifdef USE_ASM
if (useAsm & 4)
#if defined(COMPILE_KEY) && defined(USE_ASM)
key->keySig = VALID_SIG; /* show that we are initialized */
key->codeSize = sizeof(key->compiledCode); /* set size */
#endif
reKey_86(key);
else
#endif
for (i=q=0;i<subkeyCnt/2;i++,q+=SK_STEP)
{ /* compute round subkeys for PHT */
F32(A,q ,k32e); /* A uses even key dwords */
F32(B,q+SK_BUMP,k32o); /* B uses odd key dwords */
B = ROL(B,8);
key->subKeys[2*i ] = A+B; /* combine with a PHT */
B = A + 2*B;
key->subKeys[2*i+1] = ROL(B,SK_ROTL);
#if !defined(ZERO_KEY)
switch (keyLen) /* case out key length for speed in generating S-boxes */
case 128:
#if defined(FULL_KEY) || defined(PART_KEY)
#if BIG_TAB
#define one128(N,J) sbSet(N,i,J,L0[i+J])
#define sb128(N) { \
BYTE *qq=bigTab[N][b##N(sKey[1])]; \
Xor256(L0,qq,b##N(sKey[0])); \
for (i=0;i<256;i+=2) { one128(N,0); one128(N,1); } }
#else
#define one128(N,J) sbSet(N,i,J,p8(N##1)[L0[i+J]]^k0)
Xor256(L0,p8(N##2),b##N(sKey[1])); \
{ register DWORD k0=b##N(sKey[0]); \
for (i=0;i<256;i+=2) { one128(N,0); one128(N,1); } } }
#endif
#define sb128(N) Xor256(_sBox8_(N),p8(N##2),b##N(sKey[1]))
#endif
sb128(0); sb128(1); sb128(2); sb128(3);
break;
case 192:
#define one192(N,J) sbSet(N,i,J,p8(N##1)[p8(N##2)[L0[i+J]]^k1]^k0)
#define sb192(N) { \
Xor256(L0,p8(N##3),b##N(sKey[2])); \
register DWORD k1=b##N(sKey[1]); \
for (i=0;i<256;i+=2) { one192(N,0); one192(N,1); } } }
#define one192(N,J) sbSet(N,i,J,p8(N##2)[L0[i+J]]^k1)
{ register DWORD k1=b##N(sKey[1]); \
#endif
sb192(0); sb192(1); sb192(2); sb192(3);
break;
case 256:
#define one256(N,J) sbSet(N,i,J,p8(N##1)[p8(N##2)[L0[i+J]]^k1]^k0)
#define sb256(N) { \
Xor256(L1,p8(N##4),b##N(sKey[3])); \
for (i=0;i<256;i+=2) {L0[i ]=p8(N##3)[L1[i]]; \
L0[i+1]=p8(N##3)[L1[i+1]]; } \
Xor256(L0,L0,b##N(sKey[2])); \
for (i=0;i<256;i+=2) { one256(N,0); one256(N,1); } } }
#define one256(N,J) sbSet(N,i,J,p8(N##2)[L0[i+J]]^k1)
#endif
sb256(0); sb256(1); sb256(2); sb256(3);
break;
#endif
#if CHECK_TABLE /* sanity check vs. pedagogical code*/
GetSboxKey;
for (i=0;i<subkeyCnt/2;i++)
A = f32(i*SK_STEP ,k32e,keyLen); /* A uses even key dwords */
B = f32(i*SK_STEP+SK_BUMP,k32o,keyLen); /* B uses odd key dwords */
B = ROL(B,8);
assert(key->subKeys[2*i ] == A+ B);
assert(key->subKeys[2*i+1] == ROL(A+2*B,SK_ROTL));
#if !defined(ZERO_KEY) /* any S-boxes to check? */
for (i=q=0;i<256;i++,q+=0x01010101)
assert(f32(q,key->sboxKeys,keyLen) == Fe32_(q,0));
#endif
DebugDumpKey(key);
if (key->direction == DIR_ENCRYPT)
ReverseRoundSubkeys(key,DIR_ENCRYPT); /* reverse the round subkey order */
return TRUE;
* Function Name: makeKey
* direction = DIR_ENCRYPT or DIR_DECRYPT
* keyLen = # bits of key text at *keyMaterial
* keyMaterial = ptr to hex ASCII chars representing key bits
* else error code (e.g., BAD_KEY_DIR)
* Notes: This parses the key bits from keyMaterial. Zeroes out unused key bits
int makeKey(keyInstance *key, BYTE direction, int keyLen,CONST char *keyMaterial)
#if VALIDATE_PARMS /* first, sanity check on parameters */
if (key == NULL)
return BAD_KEY_INSTANCE;/* must have a keyInstance to initialize */
if ((direction != DIR_ENCRYPT) && (direction != DIR_DECRYPT))
return BAD_KEY_DIR; /* must have valid direction */
if ((keyLen > MAX_KEY_BITS) || (keyLen < 8) || (keyLen & 0x3F))
return BAD_KEY_MAT; /* length must be valid */
#if ALIGN32
if ((((int)key) & 3) || (((int)key->key32) & 3))
return BAD_ALIGN32;
#endif
#endif
key->direction = direction;/* set our cipher direction */
key->keyLen = (keyLen+63) & ~63; /* round up to multiple of 64 */
key->numRounds = numRounds[(keyLen-1)/64];
memset(key->key32,0,sizeof(key->key32)); /* zero unused bits */
key->keyMaterial[MAX_KEY_SIZE]=0; /* terminate ASCII string */
if ((keyMaterial == NULL) || (keyMaterial[0]==0))
return TRUE; /* allow a "dummy" call */
if (ParseHexDword(keyLen,keyMaterial,key->key32,key->keyMaterial))
return BAD_KEY_MAT;
return reKey(key); /* generate round subkeys */
* Function Name: cipherInit
* Function: Initialize the Twofish cipher in a given mode
* Arguments: cipher = ptr to cipherInstance to be initialized
* mode = MODE_ECB, MODE_CBC, or MODE_CFB1
* IV = ptr to hex ASCII test representing IV bytes
* else error code (e.g., BAD_CIPHER_MODE)
int cipherInit(cipherInstance *cipher, BYTE mode,CONST char *IV)
int i;
if (cipher == NULL)
return BAD_PARAMS; /* must have a cipherInstance to initialize */
if ((mode != MODE_ECB) && (mode != MODE_CBC) && (mode != MODE_CFB1))
return BAD_CIPHER_MODE; /* must have valid cipher mode */
cipher->cipherSig = VALID_SIG;
#if ALIGN32
if ((((int)cipher) & 3) || (((int)cipher->IV) & 3) || (((int)cipher->iv32) & 3))
return BAD_ALIGN32;
#endif
#endif
if ((mode != MODE_ECB) && (IV)) /* parse the IV */
if (ParseHexDword(BLOCK_SIZE,IV,cipher->iv32,NULL))
return BAD_IV_MAT;
for (i=0;i<BLOCK_SIZE/32;i++) /* make byte-oriented copy for CFB1 */
((DWORD *)cipher->IV)[i] = Bswap(cipher->iv32[i]);
cipher->mode = mode;
return TRUE;
* Function Name: blockEncrypt
* Function: Encrypt block(s) of data using Twofish
* Arguments: cipher = ptr to already initialized cipherInstance
* key = ptr to already initialized keyInstance
* input = ptr to data blocks to be encrypted
* inputLen = # bits to encrypt (multiple of blockSize)
* outBuffer = ptr to where to put encrypted blocks
* Return: # bits ciphered (>= 0)
* else error code (e.g., BAD_CIPHER_STATE, BAD_KEY_MATERIAL)
* Notes: The only supported block size for ECB/CBC modes is BLOCK_SIZE bits.
* If inputLen is not a multiple of BLOCK_SIZE bits in those modes,
* an error BAD_INPUT_LEN is returned. In CFB1 mode, all block
* sizes can be supported.
[COLOR=royalblue][B]__device__[/B] int blockEncrypt(cipherInstance *cipher, keyInstance *key,CONST BYTE *input,
int inputLen, BYTE *outBuffer)
int i,n; /* loop counters */
DWORD x[BLOCK_SIZE/32]; /* block being encrypted */
DWORD t0,t1; /* temp variables */
int rounds=key->numRounds; /* number of rounds */
BYTE bit,bit0,ctBit,carry; /* temps for CFB */
/* make local copies of things for faster access */
int mode = cipher->mode;
DWORD sk[TOTAL_SUBKEYS];
DWORD IV[BLOCK_SIZE/32];
GetSboxKey;
#if VALIDATE_PARMS
if ((cipher == NULL) || (cipher->cipherSig != VALID_SIG))
return BAD_CIPHER_STATE;
if ((key == NULL) || (key->keySig != VALID_SIG))
if ((rounds < 2) || (rounds > MAX_ROUNDS) || (rounds&1))
if ((mode != MODE_CFB1) && (inputLen % BLOCK_SIZE))
return BAD_INPUT_LEN;
#if ALIGN32
if ( (((int)cipher) & 3) || (((int)key ) & 3) ||
(((int)input ) & 3) || (((int)outBuffer) & 3))
return BAD_ALIGN32;
#endif
#endif
if (mode == MODE_CFB1)
{ /* use recursion here to handle CFB, one block at a time */
cipher->mode = MODE_ECB; /* do encryption in ECB */
for (n=0;n<inputLen;n++)
blockEncrypt(cipher,key,cipher->IV,BLOCK_SIZE,(BYTE *)x);
bit0 = 0x80 >> (n & 7);/* which bit position in byte */
ctBit = (input[n/8] & bit0) ^ ((((BYTE *) x)[0] & 0x80) >> (n&7));
outBuffer[n/8] = (outBuffer[n/8] & ~ bit0) | ctBit;
carry = ctBit >> (7 - (n&7));
for (i=BLOCK_SIZE/8-1;i>=0;i--)
bit = cipher->IV[i] >> 7; /* save next "carry" from shift */
cipher->IV[i] = (cipher->IV[i] << 1) ^ carry;
carry = bit;
cipher->mode = MODE_CFB1; /* restore mode for next time */
return inputLen;
/* here for ECB, CBC modes */
if (key->direction != DIR_ENCRYPT)
#ifdef USE_ASM
if ((useAsm & 1) && (inputLen))
#ifdef COMPILE_KEY
if (key->keySig == VALID_SIG)
return ((CipherProc *)(key->encryptFuncPtr))(cipher,key,input,inputLen,outBuffer);
#else
return (*blockEncrypt_86)(cipher,key,input,inputLen,outBuffer);
#endif
#endif
/* make local copy of subkeys for speed */
memcpy(sk,key->subKeys,sizeof(DWORD)*(ROUND_SUBKEYS+2*rounds));
if (mode == MODE_CBC) {
BlockCopy(IV,cipher->iv32);
} else {
IV[0]=IV[1]=IV[2]=IV[3]=0;
for (n=0;n<inputLen;n+=BLOCK_SIZE,input+=BLOCK_SIZE/8,outBuffer+=BLOCK_SIZE/8)
#ifdef DEBUG
DebugDump(input,"\n",-1,0,0,0,1);
if (cipher->mode == MODE_CBC)
DebugDump(cipher->iv32,"",IV_ROUND,0,0,0,0);
#endif
#define LoadBlockE(N) x[N]=Bswap(((DWORD *)input)[N]) ^ sk[INPUT_WHITEN+N] ^ IV[N]
LoadBlockE(0); LoadBlockE(1); LoadBlockE(2); LoadBlockE(3);
DebugDump(x,"",0,0,0,0,0);
#define EncryptRound(K,R,id) \
t0 = Fe32##id(x[K ],0); \
t1 = Fe32##id(x[K^1],3); \
x[K^3] = ROL(x[K^3],1); \
x[K^2]^= t0 + t1 + sk[ROUND_SUBKEYS+2*(R) ]; \
x[K^3]^= t0 + 2*t1 + sk[ROUND_SUBKEYS+2*(R)+1]; \
x[K^2] = ROR(x[K^2],1); \
DebugDump(x,"",rounds-(R),0,0,1,0);
#define Encrypt2(R,id) { EncryptRound(0,R+1,id); EncryptRound(2,R,id); }
switch (key->keyLen)
case 128:
for (i=rounds-2;i>=0;i-=2)
Encrypt2(i,_128);
break;
case 192:
Encrypt2(i,_192);
break;
case 256:
Encrypt2(i,_256);
break;
#else
Encrypt2(14,_);
Encrypt2(12,_);
Encrypt2(10,_);
Encrypt2( 8,_);
Encrypt2( 6,_);
Encrypt2( 4,_);
Encrypt2( 2,_);
Encrypt2( 0,_);
#endif
/* need to do (or undo, depending on your point of view) final swap */
#if LittleEndian
#define StoreBlockE(N) ((DWORD *)outBuffer)[N]=x[N^2] ^ sk[OUTPUT_WHITEN+N]
#else
#define StoreBlockE(N) { t0=x[N^2] ^ sk[OUTPUT_WHITEN+N]; ((DWORD *)outBuffer)[N]=Bswap(t0); }
#endif
StoreBlockE(0); StoreBlockE(1); StoreBlockE(2); StoreBlockE(3);
IV[0]=Bswap(((DWORD *)outBuffer)[0]);
IV[1]=Bswap(((DWORD *)outBuffer)[1]);
IV[2]=Bswap(((DWORD *)outBuffer)[2]);
IV[3]=Bswap(((DWORD *)outBuffer)[3]);
#ifdef DEBUG
DebugDump(outBuffer,"",rounds+1,0,0,0,1);
#endif
BlockCopy(cipher->iv32,IV);
return inputLen;
* Function Name: blockDecrypt
* Function: Decrypt block(s) of data using Twofish
* input = ptr to data blocks to be decrypted
* outBuffer = ptr to where to put decrypted blocks
[COLOR=royalblue][B]__device__[/B] int blockDecrypt(cipherInstance *cipher, keyInstance *key,CONST BYTE *input,
GetSboxKey;
#if VALIDATE_PARMS
if ((cipher->mode != MODE_CFB1) && (inputLen % BLOCK_SIZE))
#if ALIGN32
(((int)input) & 3) || (((int)outBuffer) & 3))
return BAD_ALIGN32;
#endif
#endif
if (cipher->mode == MODE_CFB1)
{ /* use blockEncrypt here to handle CFB, one block at a time */
ctBit = input[n/8] & bit0;
(ctBit ^ ((((BYTE *) x)[0] & 0x80) >> (n&7)));
carry = bit;
return inputLen;
if (key->direction != DIR_DECRYPT)
ReverseRoundSubkeys(key,DIR_DECRYPT); /* reverse the round subkey order */
#ifdef USE_ASM
if ((useAsm & 2) && (inputLen))
#ifdef COMPILE_KEY
return ((CipherProc *)(key->decryptFuncPtr))(cipher,key,input,inputLen,outBuffer);
#else
return (*blockDecrypt_86)(cipher,key,input,inputLen,outBuffer);
#endif
#endif
} else {
DebugDump(input,"\n",rounds+1,0,0,0,1);
#define LoadBlockD(N) x[N^2]=Bswap(((DWORD *)input)[N]) ^ sk[OUTPUT_WHITEN+N]
LoadBlockD(0); LoadBlockD(1); LoadBlockD(2); LoadBlockD(3);
#define DecryptRound(K,R,id) \
DebugDump(x,"",(R)+1,0,0,1,0); \
x[K^2] = ROL (x[K^2],1); \
x[K^3] = ROR (x[K^3],1); \
#define Decrypt2(R,id) { DecryptRound(2,R+1,id); DecryptRound(0,R,id); }
case 128:
Decrypt2(i,_128);
break;
case 192:
Decrypt2(i,_192);
break;
case 256:
Decrypt2(i,_256);
break;
#else
Decrypt2(14,_);
Decrypt2(12,_);
Decrypt2(10,_);
Decrypt2( 8,_);
Decrypt2( 6,_);
Decrypt2( 4,_);
Decrypt2( 2,_);
Decrypt2( 0,_);
#endif
if (cipher->mode == MODE_ECB)
#if LittleEndian
#define StoreBlockD(N) ((DWORD *)outBuffer)[N] = x[N] ^ sk[INPUT_WHITEN+N]
#else
#define StoreBlockD(N) { t0=x[N]^sk[INPUT_WHITEN+N]; ((DWORD *)outBuffer)[N] = Bswap(t0); }
#endif
StoreBlockD(0); StoreBlockD(1); StoreBlockD(2); StoreBlockD(3);
#undef StoreBlockD
DebugDump(outBuffer,"",-1,0,0,0,1);
continue;
else
#define StoreBlockD(N) x[N] ^= sk[INPUT_WHITEN+N] ^ IV[N]; \
IV[N] = Bswap(((DWORD *)input)[N]); \
((DWORD *)outBuffer)[N] = Bswap(x[N]);
#undef StoreBlockD
if (mode == MODE_CBC) /* restore iv32 to cipher */
return inputLen;
#ifdef GetCodeSize
DWORD TwofishCodeSize(void)
DWORD x= Here(0);
#ifdef USE_ASM
if (useAsm & 3)
return TwofishAsmCodeSize();
#endif
return x - TwofishCodeStart();
#endif
__global__ void encrypt(cipherInstance *cipher, keyInstance *key, CONST BYTE *input, int inputLen, BYTE *outBuffer) {
int b = blockIdx.x*blockDim.x + threadIdx.x;
blockEncrypt(cipher, key, input + 16*b, inputLen, outBuffer);
__global__ void decrypt(cipherInstance *cipher, keyInstance *key, CONST BYTE *input, int inputLen, BYTE *outBuffer) {
blockDecrypt(cipher, key, input + 16*b, inputLen, outBuffer);
inline void HandleErrorImpl(cudaError error, const char* file, int line) {
if (error != cudaSuccess) {
printf("%s: %d %s", file, line, cudaGetErrorString(error));
exit(1);
int main(void) {
char* initKey = "meingeheimespasswort";
int threads = 512;
int blocks = 12800;
cipherInstance *cipher;
keyInstance *key;
int inputLen = 16*threads*blocks;
CONST BYTE *input;
HandleError(cudaMalloc(&input, 16*threads*blocks));
HandleError(cudaMemset(input, 0, 16*threads*blocks));
BYTE *outBuffer;
HandleError(cudaMalloc(&outBuffer, 16*threads*blocks));
char *test1 = (char*)malloc(16*threads*blocks);
HandleError(cudaMemcpy(test1, input, 16*threads*blocks, cudaMemcpyDeviceToHost));
printf("First 16 bytes of input data: ");
for (int i=0; i<16; i++) {
printf("%d, ", test1[i]);
cudaEvent_t start, stop;
HandleError(cudaEventCreate(&start));
HandleError(cudaEventCreate(&stop));
HandleError(cudaEventRecord( start, 0 ));
encrypt<<<blocks,threads>>>(cipher, key, input, inputLen, outBuffer);
decrypt<<<blocks,threads>>>(cipher, key, outBuffer, inputLen, input);
HandleError(cudaGetLastError());
HandleError(cudaEventRecord( stop, 0 ));
HandleError(cudaEventSynchronize( stop ));
float elapsedTime;
HandleError(cudaEventElapsedTime( &elapsedTime, start, stop ));
printf("\nPerformance: %.6f MB/sec\n", 2*((16*threads*blocks)/1048576)/(elapsedTime/1000));
HandleError(cudaEventDestroy( start ));
HandleError(cudaEventDestroy( stop ));
char *test2 = (char*)malloc(16*threads*blocks);
HandleError(cudaMemcpy(test2, outBuffer, 16*threads*blocks, cudaMemcpyDeviceToHost));
printf("After decryption: ");
printf("%d, ", test2[i]);
free(test1);
free(test2);
HandleError(cudaFree(input));
HandleError(cudaFree(outBuffer));
return 0;
}[/B]
