Release Notes for iCUE 5.12.97
CORSAIR_Marcus
Corsair Staff
Hallo zusammen!
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen, inkl. einem Link zum download.
iCUE 5.12.97 Issues Resolved
Software Enhancements
  • Resolved an issue that caused iCUE to unexpectedly quit when importing a profile on a system with a NVIDIA Founder’s Card GPU installed
  • Battery Status sensor widgets on the Dashboard will now properly show a graph in the background
  • Certain widgets will no longer be missing their context menus when added to the Dashboard
  • Lighting Effects will no longer be duplicated when dragging and dropping layers in the list
  • Resolved various issues with naming in Murals
  • HARPOON PRO will now properly show up as a device in Murals
HID Product Enhancements
  • Resolved an issue that causes KATAR PRO WIRELESS to stop responding if the polling rate is changed to 2000 Hz
  • Resolved an issue that prevented Imitate Holding Key from working properly with Hardware Key Assignments
  • Resolved various issues that may cause iCUE to unexpectedly quit when changing polling rates across various devices
  • Resolved various issues that caused keypress combinations from working properly with Japanese layouts on certain keyboards
  • The Brightness Control icon will no longer be missing for the K100 Control Wheel
  • Resolved an issue that caused K70 CORE RGB to show up as a CRP_DISABLED device after a firmware update
  • Resolved the following issues with iCUE NEXUS:
    • Background image will now display properly when using the 640x48 px window size
    • Image rescaling logic was improved
    • Profile switching issues were fixed so that all profiles will properly appear on the rotation list
    • Changing Lighting Link will no longer cause the name of the effect to disappear
    • Renaming an EQ preset will properly update the device screen
DIY Product Enhancements
  • GIPHY support has been added to all LCD devices – users can now browse, download, and add animated GIFs to their devices. To find this feature select 'Images/GIF' then click the 'GIPHY' tab:
  • Resolved an issue that caused a delay in DDR5 detection when creating a new user profile
  • Resolved an issue with VOYAGER Gaming Laptops battery widgets not updating their status properly after the charger is removed – the widget for this sensor can also now be properly added to the Home Screen
  • The brightness between the keyboard and the touch bar for VOYAGER Gaming Laptops will now be properly adjusted together when using the hotkey
  • An additional prompt has been added to the Performance Manager tab for DDR5
  • Resolved various issues with the customization of Alerts
  • Resolved a display issue when using custom fan curve names when a QX fan is connected
