Der neue Adobe Flash Player 11.4.402.265 ist da!
Außerdem ist Adobe AIR 3.4 da!
Fixed Issues
Quelle Adobe
mfg
Fixed Issues
- Netstream crashes intermittently on disconnect(3193417)
- Issue with stopping live audio streaming on AIR Android(3188340)
- drawWithQuality() does not render filters properly on Android devices(3224928)
- Clipborad.generalClipboard.setData doesn't work on iOS(3226045)
- Some FLV video content does not play in Flash Player on Windows (3187569)
- Only right side audio playing in Flash Player based apps in Firefox on Windows(3289279)
- Mouse Lock feature disabled after entering Full Screen Interactive mode(3174344)
- [iOS5] TextFields with embedded fonts garbled on mobile devices(3161138)
- First frame of some live streaming contents freezes(3207896)
- Application icons for 50X50, 100X100, 1024X1024 are now supported for iOS applications in the Application Descriptor(3217144)
- Applications using Native extensions sometimes crash on iOS when using certain external libraries.eg. Libxml2.dylib (3226974)
- Some deviation is observed when a launch image of resolution 768 x 1004 or 1024 x 748 is packaged in a full-screen iPad application. (3230762). The new guidelines for using launch images can be referred to here
- H264 videos on iOS crash when switching between two NetStreams attached to a StageVideo object(3206438)
- Issue with CameraRoll.browseForImage() causes transparency loss resulting in white color(3291312)
- ActionScript Workers (Flash Player)
- Sandbox Bridge support (Flash Player)
- Licensing support: Flash Player Premium Features for Gaming (Flash Player)
- Stage3D "constrained" profile for increased GPU reach (Flash Player and AIR)
- LZMA support for ByteArray (Flash Player and AIR)
- StageVideo attachCamera/Camera improvements (Flash Player and AIR)
- Compressed texture with alpha support for Stage3D (Flash Player and AIR)
- DXT Encoding(Flash Player and AIR)
- Deprecated Carbon APIs for AIR (AIR)
- Direct AIR deployment using ADT (AIR)
- Push Notifications for iOS (AIR)
- Ambient AudioPlaybackMode (AIR)
- Exception Support in Native Extensions for iOS (AIR)
- New option in ADT to list the attached mobile devices (AIR)
- ADT option to resolve ANE symbol conflicts on iOS (AIR)
- Matrix3D's transformVector() incorrectly transforms w component(3190677)
- [iOS] On iOS 4.3, Compressed Cubemaps with Alpha does not properly render(3282166)
- navigateToURL issues with high-ascii characters does not properly work for AIR Desktop Applications(3161093)
- [iOS] On some content, Installing an .ipa file with AIR 3.4 occasionally fails with Installation Error: PackageExtractionFailed(3220974)
- When using –hideAneLibSymbols flag while packaging an application for iOS, only the framework and library linking linker options, and options such as -ios_version_min should be used in the ANEs platform.xml file
- Geo-location permission dialog doesn't show up on iOS 6 Beta(3291688)
- AIR applications packaged with AIR 3.4 SDK & iOS 6 Beta SDK don’t support AutoOrients for Upside down on iPod and iPhone(3286288)
- Any application packaged with AIR 3.4 SDK and iOS 6 Beta SDK does not support aspectRatio tag on iOS 5.1 device(3286320)
Quelle Adobe
mfg
