Release Notes for iCUE 5.11.95
CORSAIR_Marcus
Corsair Staff
Hallo zusammen!
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen, inkl. einem Link zum download.
iCUE 5.11.95 Issues Resolved
Software Enhancements
  • iCUE will no longer crash when switching presets in Murals
  • Improved tooltips for better consistency and placement in iCUE
  • When Lighting Layers are toggled, the last layer in the list will no longer be auto-selected
  • Naming a Murals effect with a long name will no longer cause the Go To Murals button to disappear
  • Resolved an issue that causes the device image to increase in size briefly when trying to downsize
  • Hovering over shortened text on a sensor in Dashboard will now properly show the full text as a tooltip
  • Resolved an issue that caused graphs to still appear for sensor widgets in Dashboard even after hiding them
  • Improved the responsiveness of the Color Wheel
HID Product Enhancements
  • Resolved an issue with French language that affected Macro – Copy Event and Macro – Delete Event
  • Copying “Switching Profile” as an assignment will now be possible even without a key being assigned
  • Cancelling the firmware update on Void RGB ELITE Wireless will no longer cause it to disappear from the device list
  • Resolved various lighting effects issues with NIGHTSABRE, DARKSTAR, and K70 PRO Wireless
  • Resolved an issue with NEXUS battery status widgets that prevented certain devices from reporting their battery levels
  • A background image will now properly be displayed when a screen on NEXUS is imported
DIY Product Enhancements
  • Resolved an issue that affected Time Warp lighting after a device’s firmware update is completed
  • Resolved an issue that affected Fan Curves with Fixed % and Fixed RPM when used with Fahrenheit units
  • Resolved an issue that caused profile 4 in Performance Manager for DDR5 to not appear unless iCUE is restarted
  • VOYAGER battery widget will now properly report its battery level
  • Rotary Stack and Spiral Rainbow will now play properly on the Hydro X XG7 RGB
  • Resolved an issue that caused the iCUE LINK HUB to display an improper text string when the language is changed
  • Resolved an issue with the 1000D in Murals that prevented some options from appearing during configuration
  • LT100 tower adjustment now works properly when changing the device tower arrangement
