AW: Welche Grafikkarte für E8400?
Hier ist ein teil der excel liste von 3d mark 06^^
File Name
Benchmark
Version 1.1.0
Width 1280
Height 1024
Anti-Aliasing None
Anti-Aliasing Quality 0
Texture Filtering Optimal
Anisotropic Level 1
VS Profile 3_0
PS Profile 3_0
Force full precision No
Disable HW shadow mapping No
Disable post-processing No
Force software vertex shader No
Color mipmaps No
Force software FP filtering No
Repeat tests Off
Fixed framerate Off
Comment
3DMark Score 16826 3DMarks
SM2.0 Score 8 K
HDR/SM3.0 Score 9 K
CPU Score 3135
Game Score N/A N/A
GT1 - Return To Proxycon 61,155 FPS
SM2.0 Graphics Tests
GT2 - Firefly Forest 65,300 FPS
CPU1 - Red Valley 0,994 FPS
CPU Tests
CPU2 - Red Valley 1,581 FPS
CPU Tests
HDR1 - Canyon Flight 104,826 FPS
HDR/SM3.0 Graphics Tests
HDR2 - Deep Freeze 80,984 FPS
Fill Rate - Single-Texturing 0,000 operations/s N/A Feature Tests
Fill Rate - Multi-Texturing 0,000 operations/s N/A Feature Tests
Pixel Shader 0,000 operations/s N/A Feature Tests
Vertex Shader - Simple 0,000 operations/s N/A Feature Tests
Vertex Shader - Complex 0,000 operations/s N/A Feature Tests
Shader Particles (SM3.0) 0,000 operations/s N/A Feature Tests
Perlin Noise (SM3.0) 0,000 operations/s N/A Feature Tests
8 Triangles 0,000 operations/s N/A Batch Size Tests
32 Triangles 0,000 operations/s N/A Batch Size Tests
128 Triangles 0,000 operations/s N/A Batch Size Tests
512 Triangles 0,000 operations/s N/A Batch Size Tests
2048 Triangles 0,000 operations/s N/A Batch Size Tests
32768 Triangles 0,000 operations/s N/A Batch Size Tests
System Info
Version 3,2
File Version Infos File ID File Name File Version
EntechDirecpll C:\Windows\system32\Futuremark\MSC\Direcpll.dll 4.10.01.94
EntechDirecpllSys C:\Windows\system32\Drivers\Entech.sys 1
FMSIDLL C:\Program Files\Common Files\Futuremark Shared\Futuremark SystemInfo\FMSI.dll 3, 20, 1, 1
FMSIXDLL C:\Program Files\Common Files\Futuremark Shared\Futuremark SystemInfo\FMSIX.dll 3, 20, 1, 1
CPUIDSDKDLL C:\Program Files\Common Files\Futuremark Shared\Futuremark SystemInfo\cpuidsdk.dll 1, 0, 5, 3
Statistics
Components ID Enabled Notes
CPU 1 Finished OK.
DirectX 1 Finished OK.
Memory 1 Finished OK.
Motherboard 1 Finished OK.
Monitor 1 Finished OK.
Power Supply 1 Finished OK.
Windows 1 Finished OK.
Storage Device 1 Finished OK.
CPUID 1 Finished OK.
CPU Info
Physical Processors 1
Logical Processors 2
Central Processing Units
Manufacturer Intel
Family Intel(R) Core(TM)2 Duo CPU E8500 @ 3.16GHz
Architecture 64-bit
Internal Clock 3524 MHz
Internal Clock Maximum 3524 MHz
allerdings ist das ergebnis nicht so toll^^
