Unregelmäßige Bluescreens Vista x64
takan
Guten Abend,
da meine test version von windows 7 abgelaufen ist, habe ich wieder mein altes vista x64 installiert.
mit windows 7 hatte ich keine probleme oder bluescreens, jetzt bekomm ich in unregelmäßigen abständen bluescreens, größtenteils bekomm ich die bluescreens wenn ich zocke.
Lg takan
hier ist der erste minidump, ich will nicht alle hinzufügen da es sonst zu groß wird.
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\Mini020210-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by:                                    *
*   using the _NT_SYMBOL_PATH environment variable.                 *
*   using the -y <symbol_path> argument when starting the debugger. *
*   using .sympath and .sympath+                                    *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0xfffff800`01c4c000 PsLoadedModuleList = 0xfffff800`01e10dd0
Debug session time: Tue Feb  2 20:36:45.821 2010 (GMT+1)
System Uptime: 0 days 1:34:18.228
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck FC, {fffff88010b76bc0, f28000006273f963, fffffa6005b62300, 2}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
***    Your debugger is not using the correct symbols                 ***
***    In order for this command to work properly, your symbol path   ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: nt!_KPRCB                                     ***
***    work.                                                          ***
***    Type referenced: nt!KPRCB                                      ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
Probably caused by : ntoskrnl.exe ( nt+5a450 )
Followup: MachineOwner
AW: Unregelmäßige Bluescreens Vista x64
Hast du schon komplett alle Updates und Service Packs für Vista geladen?
Das einzige was ich aus deiner Fehlermeldung rauslesen konnte ist das er Probleme hat gewisse Systemdateien zu laden. Also wenn du an der Hardware nichts verändert hast, solltest du ne neu Installation versuchen wenn das auch nicht hilft wird ein Problem mit der Hardware immer warscheinlicher. Aber ne wirklich Idee habe ich nicht mehr, Sorry, vieleicht meldet sich ja noch jemand anderes.
Hi, du nutzt den Debugger, um die Minidump Datei auszulesen. Jedoch ist der Symbol-path für den Debugger nicht erreichbar. Damit man mit dem Debugger wirklich sinnvoll Arbeiten kann, werden die sog. Symboldateien benötigt. Da die aber vollständig mit ca. 170 MByte zu Buch schlagen, aber du sicherlich nicht täglich solche Dumpdateien auswerten willst, soll sich WinDbg lieber selber die benötigten Dateien aus dem Internet holen.
Dafür im Debugger folgendes einstellen:
Im Menü "File" -> "Symbol File Path" in die Eingabebox eintragen:
"SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols". (ohne "")
einen Haken bei 'Reload' (sofern es nicht ausgegraut ist) und OK drücken. Jetzt können alle notwendigen Informationen zum Debuggen von MS geladen werden, das geschieht automatisch.
Anschließend über Files, das Speicherabbild für den Debugger öffnen: Files -> Open Crash Dump
Memory.dmp auswählen und öffnen.
Im letzten Schritt in die untere Befehlszeile "!analyze –v" eingeben und Entertaste drücken.
Der Debugger werkelt dann etwas und nach kurzer wird als Ausgabe eine eindeutige Zuweisung der Datei, die den Bluescreens hervorgerufen hat, gegeben.
Den Text der Auswertung kannst du dann uns dann erst mal posten.
Eine entscheidende Mitteilung wurde jedoch schon gemacht: "Probably caused by : ntoskrnl.exe"
Würde aber gerne noch die Minidumpauswertung dazu sehen.
hier die analyse
//edit
zur der zeit hab ich wohl die beta zu bad company 2 gezockt x)
Code:
3: kd> !analyze -v
ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY (fc)
An attempt was made to execute non-executable memory.  The guilty driver
is on the stack trace (and is typically the current instruction pointer).
When possible, the guilty driver's name (Unicode string) is printed on
the bugcheck screen and saved in KiBugCheckDriver.
Arguments:
Arg1: fffff88010b76bc0, Virtual address for the attempted execute.
Arg2: f28000006273f963, PTE contents.
Arg3: fffffa6005b62300, (reserved)
Arg4: 0000000000000002, (reserved)
Debugging Details:
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0xFC
PROCESS_NAME:  BFBC2Game.exe
CURRENT_IRQL:  0
TRAP_FRAME:  fffffa6005b62300 -- (.trap 0xfffffa6005b62300)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffffa600260acf8 rbx=0000000000000000 rcx=fffffa6009030000
rdx=00000000178f0000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88010b76bc0 rsp=fffffa6005b62498 rbp=fffffa6009030000
 r8=000000000001061c  r9=000000000001061c r10=00000000178f0000
r11=fffffa6009030000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl nz na pe nc
fffff880`10b76bc0 0000            add     byte ptr [rax],al ds:fffffa60`0260acf8=??
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80001d075c8 to fffff80001ca6450
STACK_TEXT:
fffffa60`05b62218 fffff800`01d075c8 : 00000000`000000fc fffff880`10b76bc0 f2800000`6273f963 fffffa60`05b62300 : nt!KeBugCheckEx
fffffa60`05b62220 fffff800`01ca4fd9 : 00000000`00000008 fffffa60`05b62348 00000000`00000500 fffffa60`09030000 : nt! ?? ::FNODOBFM::`string'+0x2d114
fffffa60`05b62300 fffff880`10b76bc0 : fffff880`11964a10 00000000`00000000 fffff880`111c7380 fffffa60`05b62640 : nt!KiPageFault+0x119
fffffa60`05b62498 fffff880`11964a10 : 00000000`00000000 fffff880`111c7380 fffffa60`05b62640 fffffa60`02628df7 : 0xfffff880`10b76bc0
fffffa60`05b624a0 00000000`00000000 : fffff880`111c7380 fffffa60`05b62640 fffffa60`02628df7 fffffa60`05ab0000 : 0xfffff880`11964a10
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt! ?? ::FNODOBFM::`string'+2d114
fffff800`01d075c8 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+2d114
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4a7801eb
FAILURE_BUCKET_ID:  X64_0xFC_nt!_??_::FNODOBFM::_string_+2d114
Das hat ja schon mal geklappt.
Wenn du zwischenzeitlich die beta zu bad company 2 nicht mehr drauf hast, hätte ich gerne noch das aktuellste minidump des letzten Bluescreens gesehen. Kannst du das noch mal auslesen und hier rein posten? Ursächlich war (oder ist?) ein Treiber, der einen Konflikt mit dem Windows-Prozess ntkrnlmp.exe verursacht hat, aufgetreten ist der Bluescreen beim bad company zocken. Insofern wäre es gut eine aktuelle Auswertung zu haben, ob ein generelles Problem mit der ntkrnlmp.exe besteht.
Des weiteren schreibe mal die Hardwarekomponenten auf, die in deinem PC stecken und mache ein paar Screenshots mit CPU-Z (Reiter CPU, Mainboard, Memory und SPD).
Bilder im Anhang.
System:
Intel Q9450
Corsair Dominator 1066 8GB (atm 6GB drinnen)
Gigabyte GA-X48-DS5
MSI HD4870-OC 512MB
Velociraptor 300GB
Be-Quiet Straigt Power 600W
Habe die Beta noch aufn PC, bekam ein bluescreen im idle.
Code:
BugCheck A, {28, 2, 0, fffff80001c4a1b4}
Probably caused by : memory_corruption ( nt!MiFindNodeOrParent+0 )
2: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000028, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
	bit 0 : value 0 = read operation, 1 = write operation
	bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80001c4a1b4, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80001e3a080
 0000000000000028
CURRENT_IRQL:  2
FAULTING_IP:
fffff800`01c4a1b4 48f7412800ffffff test    qword ptr [rcx+28h],0FFFFFFFFFFFFFF00h
CUSTOMER_CRASH_COUNT:  9
DEFAULT_BUCKET_ID:  COMMON_SYSTEM_FAULT
BUGCHECK_STR:  0xA
PROCESS_NAME:  svchost.exe
TRAP_FRAME:  fffffa60069475c0 -- (.trap 0xfffffa60069475c0)
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80001c4a1b4 rsp=fffffa6006947758 rbp=0000000000000002
 r8=fffffa60069477a0  r9=fffffa80090f9560 r10=0000058000000000
r11=000000000002eb29 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na po nc
nt!MiFindNodeOrParent:
fffff800`01c4a1b4 48f7412800ffffff test    qword ptr [rcx+28h],0FFFFFFFFFFFFFF00h ds:07ff:00000000`00000028=????????????????
LAST_CONTROL_TRANSFER:  from fffff80001c6d1ee to fffff80001c6d450
STACK_TEXT:
fffffa60`06947478 fffff800`01c6d1ee : 00000000`0000000a 00000000`00000028 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffffa60`06947480 fffff800`01c6c0cb : 00000000`00000000 00000000`00000000 00000000`00000000 fffffa80`090f95a8 : nt!KiBugCheckDispatch+0x6e
fffffa60`069475c0 fffff800`01c4a1b4 : fffff800`01c4a217 00000000`000018c0 fffff800`01da5160 00000000`00000200 : nt!KiPageFault+0x20b
fffffa60`06947758 fffff800`01c4a217 : 00000000`000018c0 fffff800`01da5160 00000000`00000200 fffff800`01d47f07 : nt!MiFindNodeOrParent
fffffa60`06947760 fffff800`01c485af : 00000000`02d3ef01 00000000`001adc0f fffffa80`0740f000 fffff800`01c371e3 : nt!MiLocateAddressInTree+0x17
fffffa60`06947790 fffff800`01cf5080 : fffff880`0c730218 fffffa80`090f9560 fffffa80`07410360 fffff800`01da5160 : nt!MiGetSharedProtos+0x4f
fffffa60`069477c0 fffff800`01d0f60c : 00000000`0002eb29 fffffa80`07410360 fffffa80`08e7ebb0 00000000`00000000 : nt!MiIdentifyPfn+0x820
fffffa60`06947860 fffff800`02000c05 : fffffa80`0740f000 fffffa60`06947ca0 fffffa60`06947928 00000000`00000000 : nt!MmQueryPfnList+0x13c
fffffa60`069478a0 fffff800`01f45d1c : fffffa80`00000000 00000000`00000000 fffffa80`0740f000 00000000`0377af01 : nt!PfpPfnPrioRequest+0x115
fffffa60`069478f0 fffff800`01edcf9b : 00000000`00000000 00000000`0377aff0 00000000`02d3ef10 fffff800`02000c01 : nt! ?? ::NNGAKEGL::`string'+0x4af1a
fffffa60`06947960 fffff800`01c6cef3 : fffffa80`08e7ebb0 00000000`0377aff0 00000000`02d30071 00000000`00000000 : nt!NtQuerySystemInformation+0xe4b
fffffa60`06947c20 00000000`7700707a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`02d3ee68 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7700707a
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!MiFindNodeOrParent+0
MODULE_NAME: nt
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0xA_nt!MiFindNodeOrParent+0
Hi takan,
überprüfe bitte die Speicherriegel auf Fehler mit Memtest86+. Hierfür jeden Speicherriegel einzeln testen (die anderen zum Test ausbauen). Sind das drei identische Riegel? Und hast du die bereits bei Win7 drin gehabt?
Nach dem Test alle drei Riegel wieder rein und im Bios die DDR2 Voltage und die FSB Voltage um 0,1V erhöhen. Die Memory Frequenz auf den nächst kleineren Teiler veringern.
Prüfen ob Bluescreens auftreten.
Viele Grüße
Edit: Beim Memtest die iso runterladen, auf CD Brennen (Disk-Image brennen) und von der CD booten.
vielleicht hatter nicht richtig ?
also HDD Platt machen Format C:
dann erst Vista installieren,
bei Vista kann man auch mit der Boot CD eine Voll
Formatierung der HDD machen und solltest du,
damit evtl. Reste von anderem OS komplett
entfernt sind und nichts drüber gebraten wird
was u.a. nicht überschrieben wurde bei der Installation
>weil Vista kennt Windows 7 nicht, aber dafür XP<
daher wohl der Blau Screen.
man geht wohl davon aus das man ein Neues OS
nach einem alten OS Installiert und nicht umgekehrt ,
das ist der Fehler ?
alle 4 riegel sind gleich, einer is draußen, den riegel hab ich nen freund geliehen, mach ich morgen wenn ich zeit habe den memtest.
formatiert habe ich, nach 10 jahren windows erfahrung sollte man das ausn ff kennen *gg
Ok. :daumen:
Wenn zwischenzeitlich Bluescreens kommen, bitte die Auswertung(en) dazu posten.
habe nur noch 2gb drinne, 3 riegel sind draußen habe keine mehr bekommen, komischer lässt sich memtest nicht brennen o0, muss ich mal an einen anderen pc ran, ich hab die timings wieder eingestellt und dann hat windows automatisch den ram nach fehler durchsucht aber keine gefunden, mein letzter bluescreen hier
Code:
BugCheck 1A, {8884, fffffa800008ccd0, fffffa800004e900, 1}
Probably caused by : memory_corruption ( nt!MiRelinkStandbyPage+a2 )
0: kd> !analyze -v
MEMORY_MANAGEMENT (1a)
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000008884, The subtype of the bugcheck.
Arg2: fffffa800008ccd0
Arg3: fffffa800004e900
Arg4: 0000000000000001
Debugging Details:
BUGCHECK_STR:  0x1a_8884
CUSTOMER_CRASH_COUNT:  8
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff80001d22102 to fffff80001cb4450
STACK_TEXT:
fffffa60`06ff78c8 fffff800`01d22102 : 00000000`0000001a 00000000`00008884 fffffa80`0008ccd0 fffffa80`0004e900 : nt!KeBugCheckEx
fffffa60`06ff78d0 fffff800`01d78b6d : fffffa80`0738b060 fffffa80`06efc138 fffffa80`0738b060 fffffa80`06efc138 : nt!MiRelinkStandbyPage+0xa2
fffffa60`06ff7910 fffff800`02047b74 : 00000000`00000000 fffffa60`00000000 00000000`00000000 fffffa80`06efb000 : nt!MmSetPfnListPriorities+0x28d
fffffa60`06ff7980 fffff800`02087f32 : fffffa80`058bbd00 00000000`00000000 fffffa80`078f1000 00000000`00000001 : nt!PfpPfnPrioRequest+0x84
fffffa60`06ff79d0 fffff800`0209a948 : 00000000`00000000 00000000`00000004 fffffa80`0471d000 00000000`00000001 : nt!PfSetSuperfetchInformation+0x191
fffffa60`06ff7ab0 fffff800`01cb3ef3 : fffffa80`0738b060 00000000`03acf7f0 00000000`030bed01 00000000`00000000 : nt!NtSetSystemInformation+0x8fb
fffffa60`06ff7c20 00000000`770d838a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`030bf1f8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x770d838a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`01d22102 cc              int     3
SYMBOL_NAME:  nt!MiRelinkStandbyPage+a2
MODULE_NAME: nt
FAILURE_BUCKET_ID:  X64_0x1a_8884_nt!MiRelinkStandbyPage+a2
Auch hier ist wieder als Übeltäter IMAGE_NAME: memory_corruption genannt.
Memtest gibt es unter dem Link, den ich dir gepostet habe auch für den USB-Stick oder für Floppy.
Die windowseigene RAM Fehlersuche ist nicht so zuverlässig wie Memtest, das dort keine Fehler gefunden wurde, ist keine Sicherheit.
Heißt das, dass du mit nur einem Riegel keine Bluescreens mehr bekommst?
Teste mal alle vier Riegel einzeln durch, ob mit einem (oder mehr) bestimmten Riegeln die Bluescreens auftauchen.
