The 4.11.2 Hotfix is now live! This is a big one that resolves over 40 issues!
Fixed in 4.11.2
Fixed! UE-28811 Get mouse X/ Get mouse Y returns zero after the user clicks the screen and mouse is shown
Fixed! UE-29148 Using "Show Mouse Cursor" breaks mouse axis movement
Fixed! UE-28378 Mouse is not captured when switching between clients when running PIE
Fixed! UE-29007 Construction script in parent blueprint cannot call function in child blueprint
Fixed! UE-29207 UMG Widgets aren't cleaned up when a player is removed
Fixed! UE-29208 Third Person C++ Template Doesn't use C++ Character
Fixed! UE-29300 CDO Constructor Error when opening C++ Third Person project
Fixed! UE-29136 Ensure starting PIE after editing character blueprint of a code based side scrollers
Fixed! UE-29046 Crash on exit PIE after editing character blueprint of a code based side scrollers
Fixed! UE-29209 Ensure 'Attaching instanced component to template component' in PIE in TP code project after reparenting character BP
Fixed! UE-29100 Disable spawanbles in 4.11 because they can cause scene corruption and won't be compatible with 4.12
Fixed! UE-28791 Crash smoothing landscape with foliage
Fixed! UE-28926 Editor crashes while sculpting landscape heavily covered in foliage
Fixed! UE-28999 UE 4.11 Project Containing vegetation_pack causes Engine to Crash
Fixed! UE-24725 Vehicle templates have jerky movement when turning due to SpringArmComponent
Fixed! UE-28753 SpringArm causes physics to fail for a character standing on the physics object
Fixed! UE-28991 Cannot manipulate morph targets unique to Slave Component through Master Component
Fixed! UE-29003 Manipulating Morph Target on Master Component distorts Slave Components
Fixed! UE-28789 Root motion has significant error when used in character movement
Fixed! UE-25343 Crash in SetRootBodyIndex ( ParentIndex is 0 but SpaceBases.Num() == 0)
Fixed! UE-29116 Animation CopyRecords need to calculate size at runtime
Fixed! UE-29422 Crash in FollowKnots when compiling Anim Blueprint
Fixed! UE-29326 [CrashReport] UE4Editor_Engine!FBlendedCurve::InitFrom() [animcurvetypes.cpp:590]
Fixed! UE-28011 Media Player assets do not play in packaged games or in standalone
Fixed! UE-29091 Sound Cues with Attenuation 'Override' Nodes break when Upgrading project to 4.11
Fixed! UE-29403 .wav files with max concurrency count data outside proper range will crash editor when played
Fixed! UE-29548 Crash in VoiceModuleWindows.cpp
Fixed! UE-29397 Sounds not Playing for 2nd Player Client when running in Local Multiplayer Splitscreen Mode
Fixed! UE-27646 Editor Crashes When Using Set Replicates in the Construction Script
Fixed! UE-25234 Bloom offset in right eye when rendering in stereoscopic
Fixed! UE-29513 Custom lighting channels ignored when object culled in stereoscopic
Fixed! UE-28609 R.ScreenPercentage and HMD SP commands do not work on Morpheus
Fixed! UE-29505 Wrong colors on Nexus 6 Devices
Fixed! UE-28805 HDR and Bloom not working on Mali Galaxy S7 (SM-G930F)
Fixed! UE-29420 [Metal][iOS] Memory spike caused by FMetalSurface in 4.11
Fixed! UE-29421 [Metal][iOS] Crash in FMetalDynamicRHI::RHIReadSurfaceFloatData since 4.11
Fixed! UE-29006 [CrashReport] UE4Editor-MetalRHI.dylib!FMetalCommandEncoder::RestoreRenderCommandEncoding()
Fixed! UE-29194 PS4 leaks memory in Shipping builds submission timestamp array
Fixed! UE-29390 Html 5 Launch Fails on Windows
Fixed! UE-29392 HTML5 broken load/save
Fixed! UE-28874 New Third Party Plugin does not compile on Mac and Linux and prevents project from opening
Fixed! UE-29158 4.11 regression: Stationary skylights no longer get bounce lighting after a lighting build
Fixed! UE-29255 IndirectLightingIntensity on skylights is broken - can cause level lighting to unexpectedly change after getting the new build
Fixed! UE-29297 Building Grass Map toast stays up forever
Fixed! UE-29332 [CrashReport] Crash When Switching from Lit to Light Complexity Mode
Fixed! UE-29322 [CrashReport] UE4Editor_CoreUObject!StaticFindObjectFastInternalThreadSafe() [uobjecthash.cpp:423]
Fixed! UE-29407 Editor process quits during start up in debug with debugger attached
REMEMBER: Please report any new bugs you find to the UE4 Answerhub
