Dann vll mal 1min lang Google bemühen? Da tauchen solche Lösungen auf:
Download Reset fix found!
Like a few of you with slow connections, i found that my Arkham Knight download had reset to 0% after pausing the download at well past 90%.
I searched google and found a fast fix. All credit to FreshFTGrave.
A small rant on Steam and how to salvage a reset download. - Steam Users' Forums
All you have to do after completely closing and exiting the steam client is:
1) Find the steam download folder for Arrkham Knight.
C:\Program Files (x86)\Steam\steamapps\downloading\208650
Check the folder to see what the size of all the files is. If it is around the size of your previously download amount, you are golden.
2) Copy all the the files in that folder to the game folder.
C:\Program Files (x86)\Steam\steamapps\common\Batman Arkham Knight
You will need to create the "Batman Arkham Knight" folder with that EXACT NAME.
3) Use the search box WHILE IN THE FOLDER C:\Program Files (x86)\Steam to find "208650"
The search will provide a list of results consisting of:
-one folder (The game download folder you just copied)
-one .acf file titled "appmanifest_208650"
-several .PATCH files starting with title "state_208650_"
- two .bin files starting with title "UserGameStats"
Remove all these files from the steam folder. You can either delete them or do what i did and move them into the new folder on your desktop to be safe. Just get them out of the steam folder.
4) Restart Steam. The Arkham Knight install will be gone. Go to the game in your library and click the "Install" button that should have returned. Steam will discover the files and then figure out what is missing. It should start you NEAR where you were.
I was at 31GB when I paused my download and after following this method, I am now at 29.5GB. WAY better than restarting from scratch.
Ich halte sie aber für absolut schief und krumm, da Steam so was eigenständig recht gut regelt.
Könnte helfen, aber meine Empfehlung ist die gleiche wie vom Steam-Client: neu saugen.
Und niemand will deine Leitung runtermachen, ich sage nur - es ist nicht der erste Fall wo du dich grün und blau ärgerst und das wird bestimmt nicht der letzte sein. Also lieber vorsorgen und ne gute Leitung holen, die Lebensqualität steigt dadurch.
Selbst wenn man sie 99% der Zeit nicht ausnutzt, es wird immer wieder Momente geben wo man sich in den Hintern kneift und sagt: da zahl ich lieber 20€ mehr und erspare mir das...
