[Sammelthread] Asus Crosshair V Formula
ro0ki
Spezifikationen:
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Bios-Versionen:
  • Version 1301(Aktuellste Version)
  • Version 1102
  • Version 1003
  • Version 0903
  • Version 0813
  • Version 0705
  • Version 0506
  • Version 0404
Testberichte:
Hartware.net
AwardFabrik
Planet 3DNow!
Guru3d.com
TE
TE
ro0ki
ro0ki
Puh das ist eine gute Frage, ich selber habe die Soundkarte vom Board nie benutzt. Ich habe eine Creative X-Fi Titanium. Aber ich denke mal, dass du die Soundqualität mit einer richtigen Soundkarte nicht vergleichen kannst.
Aber vielleicht hilft dir das bei der Entscheidung ob Onboard oder SoKa:
Spiele-Hardware: Soundkarte oder Onboard-Sound? (1)
altenburg
Ich habe eine Frage zum aktuellen Bios- update. Dort gibt es bei Cool n Quite die Einstellung "Disabled by CPU" was bedeutet das?
TE
TE
ro0ki
ro0ki
Ich bin mir jetzt nicht ganz sicher weil ich diese Funktion bei mir immer deaktivieren, aber ich meine das die Funktion "Cool n Quiet" dann von der CPU gesteuert wird.
Bei der im Screenshot gezeigten Einstellung.
altenburg
Wie sol das gehen? Wenn CPU arbeitet taktet er hoch und wenn nicht runter? Dann währe es ja genau so wie vorher wenn CnQ auf enabled gestellt ist. Ich finde darüber auch keinen Eintrag bei google.
Zanza
kann mir einer sagen warum bei der CPU der multi immer von 20 auf 17 runter geht kurz wenn es unter last läuft,
Pleusch
Ich vesteh zwar die frage nicht so richtig aber wenn du möchtest das die CPU immer mit voller Power läuft dann stell einfach den Turbo Core auf Disable und den Multiplikator auf 21.
Dann hast du durchgehend 4200Mhz und musst dich mit solchen Fragen nicht mehr Plagen. ( Ich nehme mal an das du nen FX-8350 hast, wobei es keine rolle spielt)
Pleusch
Hat jemand von euch den FX-8350 auf stabielen 4800Mhz laufen???
Wenn ja könnte mir der jenige seine Bios settings per Screenshot posten?
