Explosiv
Riva Tuner 2.24B verfügbar (MSI MOA 2009 edition) !
Download : Guru3D
Quelle : Guru3D.com
Riva Tuner 2.24B-MSI MOA 2009 edition
Heute wurde ein neues Update des Tools Riva Tuner in der Version 2.24b zum Download freigegeben.
Da Update wurde von der stattfindenden MSI MOA 2009 benötigt, um so zu ermöglichen, das auch NVIDIA-Treiber mit der Versionnummer 190.XXX genutzt werden können.
Change-Log (Bugfixes):
- Fixed bug in hardware monitoring module causing hardware monitoring based scheduled tasks to be ignored due to improper initialization on RivaTuner startup.
- Fixed erroneous 100MHz memory clock reading on G9x GPU series based display adapters caused by bug in memory clock frequency generator source clock detection code.
- File system redirection is no longer disabled when executing a patch script under 64-bit OS to prevent the issues with missing file system browser dialog when pressing the "Continue" button.
- Heights of sticky graphs in the group are now updated properly when manually editing fixed graph height settings in the properties of any graph of the group.
- Fixed bug into startup daemon routine of RivaTunerStatisticsServer and D3DOverrider utilities causing these tools to be started and reside in memory without displaying tray icon under certain conditions.
Download : Guru3D
Quelle : Guru3D.com
