Teutonnen
Lötkolbengott/-göttin
Regelmässige Bluescreens bei Medieval 2 Total War Mod - Third Age Total War
Kann mir vielleicht jemand beim "Lesen" des Minidumps dazu helfen? Das System ist ansonsten ausreichend stabil (sprich, keines der sonst verwendeten Programme haben bisher einen BSOD verursacht), der BSOD tritt wirklich NUR bei M2TW-TATW auf.
Das System steht in der Signatur.
Hier der WinDbg-Minidump:
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\072413-12682-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\Windows\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7601.18113.amd64fre.win7sp1_gdr.130318-1533
Machine Name:
Kernel base = 0xfffff800`0305c000 PsLoadedModuleList = 0xfffff800`0329f670
Debug session time: Wed Jul 24 17:52:51.989 2013 (UTC + 2:00)
System Uptime: 0 days 5:20:12.848
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1E, {0, 0, 0, 0}
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: ExceptionRecord ***
*** work. ***
*** Type referenced: ContextRecord ***
*** work. ***
*** work. ***
Probably caused by : ntkrnlmp.exe ( nt!KiKernelCalloutExceptionHandler+e )
Followup: MachineOwner
0: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: 0000000000000000, Parameter 1 of the exception
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0x1E
PROCESS_NAME: System
CURRENT_IRQL: 0
TAG_NOT_DEFINED_c000000f: FFFFF80000BA2FB0
EXCEPTION_RECORD: fffff80000b9c928 -- (.exr 0xfffff80000b9c928)
ExceptionAddress: fffff800030da408 (nt!PoIdle+0x0000000000000238)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
TRAP_FRAME: fffff80000b9c9d0 -- (.trap 0xfffff80000b9c9d0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000000
rdx=fffff8000305c000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800030da408 rsp=fffff80000b9cb60 rbp=0000000000000000
r8=0000000000000001 r9=0000000b51651fe7 r10=00000000000001d3
r11=fffff80000b9cb80 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up di pl zr na po nc
nt!PoIdle+0x238:
fffff800`030da408 488b84c2e0c81e00 mov rax,qword ptr [rdx+rax*8+1EC8E0h] ds:fffff800`032488e0=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff800030c95fe to fffff800030d1bd0
STACK_TEXT:
fffff800`00b9ba08 fffff800`030c95fe : fffffa80`08599340 fffff800`00b9bb60 fffff800`00b9c180 fffff800`030fca90 : nt!KeBugCheck
fffff800`00b9ba10 fffff800`030fc75d : fffff800`032e00bc fffff800`0321ead8 fffff800`0305c000 fffff800`00b9c928 : nt!KiKernelCalloutExceptionHandler+0xe
fffff800`00b9ba40 fffff800`030fb535 : fffff800`03221038 fffff800`00b9bab8 fffff800`00b9c928 fffff800`0305c000 : nt!RtlpExecuteHandlerForException+0xd
fffff800`00b9ba70 fffff800`0310c4d1 : fffff800`00b9c928 fffff800`00b9c180 fffff800`00000000 fffff800`0325acc0 : nt!RtlDispatchException+0x415
fffff800`00b9c150 fffff800`030d1282 : fffff800`00b9c928 00000000`00000001 fffff800`00b9c9d0 fffff800`0324ce80 : nt!KiDispatchException+0x135
fffff800`00b9c7f0 fffff800`030cfb8a : fffffa80`081da000 fffffa80`07f3b000 fffffa80`00000000 00000000`00000000 : nt!KiExceptionDispatch+0xc2
fffff800`00b9c9d0 fffff800`030da408 : 00000000`0032aa46 fffffa80`074fedd0 00000000`00000000 3c160000`3ba10000 : nt!KiGeneralProtectionFault+0x10a
fffff800`00b9cb60 fffff800`030c98dc : fffff800`0324ce80 fffff800`0325acc0 00000000`00000000 fffff880`08392e48 : nt!PoIdle+0x238
fffff800`00b9cc40 00000000`00000000 : fffff800`00b9d000 fffff800`00b97000 fffff800`00b9cc00 00000000`00000000 : nt!KiIdleLoop+0x2c
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff800`030c95fe 90 nop
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt!KiKernelCalloutExceptionHandler+e
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 5147d9c6
FAILURE_BUCKET_ID: X64_0x1E_nt!KiKernelCalloutExceptionHandler+e
Machine Name:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
0: kd> !analyze -v
Arguments:
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
BUGCHECK_STR: 0x1E
CURRENT_IRQL: 0
NumberParameters: 2
nt!PoIdle+0x238:
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: nt
. Bei den Grafikkarten hab ich einfach den Afterburner aus dem Autostart genommen und neu hochgefahren, das ist es wohl auch nicht.
