ich habe ein Problem mit meiner GPU und der neuen Version 7 des Clients.
Ich erhalte immer ein FAILED ("UNSTABLE MACHINE") beim Versuch die GPU (8800GTX@stock@80°C) zum Falten zu bewegen
Fehlerlog folgt:
Jemand eine Idee?
Edit: Habe mit der alten gpu2 console das selbe Problem
Edit2: Win7 x64 Prof, Treiber 266.58
Fehlerlog folgt:
Code:
08:39:10:Connecting to assign-GPU.stanford.edu:80
08:39:11:News: Welcome to Folding@Home
08:39:11:Assigned to work server 171.64.65.71
08:39:11:Requesting new work unit for slot 01: READY gpu:0:"G80 [GeForce 8800 GTX]" from 171.64.65.71
08:39:11:Connecting to 171.64.65.71:8080
08:39:12:Slot 01: Downloading 80.40KiB
08:39:13:Slot 01: Download complete
08:39:13:Received Unit: id:01 state:DOWNLOAD project:10111 run:819 clone:0 gen:336 core:0x11 unit:0x000001870a3b1e6b4cbcb7fba6119cd4
08:39:13:Downloading core from http://www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah
08:39:13:Connecting to www.stanford.edu:80
08:39:13:WARNING: FahCore type in core package seems to be in wrong byte order.
08:39:13:FahCore 11: Downloading 648.82KiB
08:39:18:FahCore 11: Download complete
08:39:18:Valid core signature
08:39:18:Unpacked 1.82MiB to cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe
08:39:18:Starting Unit 01
08:39:18:Running core: G:/folding/data/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -lifeline 3668 -version 701 -checkpoint 3 -gpu 0
08:39:18:Started core on PID 2368
08:39:18:FahCore 0x11 started
08:39:18:Unit 01:
08:39:18:Unit 01:*------------------------------*
08:39:18:Unit 01:Folding@Home GPU Core
08:39:18:Unit 01:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
08:39:18:Unit 01:
08:39:18:Unit 01:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
08:39:18:Unit 01:Build host: amoeba
08:39:18:Unit 01:Board Type: Nvidia
08:39:18:Unit 01:Core :
08:39:18:Unit 01:Preparing to commence simulation
08:39:18:Unit 01:- Looking at optimizations...
08:39:18:Unit 01:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
08:39:18:Unit 01:- Created dyn
08:39:18:Unit 01:- Files status OK
08:39:18:Unit 01:- Expanded 81813 -> 421543 (decompressed 515.2 percent)
08:39:18:Unit 01:Called DecompressByteArray: compressed_data_size=81813 data_size=421543, decompressed_data_size=421543 diff=0
08:39:18:Unit 01:- Digital signature verified
08:39:18:Unit 01:
08:39:18:Unit 01:Project: 10111 (Run 819, Clone 0, Gen 336)
08:39:18:Unit 01:
08:39:18:Unit 01:Assembly optimizations on if available.
08:39:18:Unit 01:Entering M.D.
08:39:24:Unit 01:Tpr hash 01/wudata_01.tpr: 4236874045 2571461049 2123862867 809055189 2129167020
08:39:24:Unit 01:
08:39:24:Unit 01:Calling fah_main args: 14 usage=100
08:39:24:Unit 01:
08:39:24:Unit 01:mdrun_gpu returned
08:39:24:Unit 01:Going to send back what have done -- stepsTotalG=0
08:39:24:Unit 01:Work fraction=0.0000 steps=0.
08:39:28:Unit 01:logfile size=0 infoLength=0 edr=0 trr=25
08:39:28:Unit 01:+ Opened results file
08:39:28:Unit 01:- Writing 635 bytes of core data to disk...
08:39:28:Unit 01:Done: 123 -> 120 (compressed to 97.5 percent)
08:39:28:Unit 01: ... Done.
08:39:28:Unit 01:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
08:39:28:Unit 01:
08:39:28:Unit 01:Folding@home Core Shutdown: UNSTABLE_MACHINE
08:39:28:FahCore, running Unit 01, returned: UNSTABLE_MACHINE (122)
08:39:28:Starting Unit 01
08:39:28:Running core: G:/folding/data/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -lifeline 3668 -version 701 -checkpoint 3 -gpu 0
08:39:28:Started core on PID 3972
08:39:28:FahCore 0x11 started
08:39:29:FahCore, running Unit 01, returned: MISSING_WORK_FILES (116)
08:39:29:WARNING: Unit 01 Fatal error, dumping
08:39:29:Sending unit results: id:01 state:SEND project:10111 run:819 clone:0 gen:336 core:0x11 unit:0x000001870a3b1e6b4cbcb7fba6119cd4
08:39:29:Unit 01: Uploading 632B
08:39:29:Connecting to assign-GPU.stanford.edu:80
08:39:29:Connecting to 171.64.65.71:8080
08:39:29:News: Welcome to Folding@Home
08:39:29:Assigned to work server 171.64.65.71
08:39:29:Requesting new work unit for slot 01: READY gpu:0:"G80 [GeForce 8800 GTX]" from 171.64.65.71
08:39:30:Unit 01: Upload complete
08:39:30:Server responded WORK_ACK (400)
08:39:30:Cleaning up Unit 01
08:39:30:Slot 01: Downloading 80.36KiB
08:39:31:Slot 01: Download complete
08:39:31:Received Unit: id:02 state:DOWNLOAD project:10120 run:69 clone:2 gen:71 core:0x11 unit:0x000000590a3b1e6b4d9113f624f97244
08:39:31:Starting Unit 02
08:39:31:Running core: G:/folding/data/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 02 -suffix 01 -lifeline 3668 -version 701 -checkpoint 3 -gpu 0
08:39:31:Started core on PID 2420
08:39:31:FahCore 0x11 started
08:39:32:Unit 02:
08:39:32:Unit 02:*------------------------------*
08:39:32:Unit 02:Folding@Home GPU Core
08:39:32:Unit 02:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
08:39:32:Unit 02:
08:39:32:Unit 02:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
08:39:32:Unit 02:Build host: amoeba
08:39:32:Unit 02:Board Type: Nvidia
08:39:32:Unit 02:Core :
08:39:32:Unit 02:Preparing to commence simulation
08:39:32:Unit 02:- Looking at optimizations...
08:39:32:Unit 02:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
08:39:32:Unit 02:- Created dyn
08:39:32:Unit 02:- Files status OK
08:39:32:Unit 02:- Expanded 81776 -> 421543 (decompressed 515.4 percent)
08:39:32:Unit 02:Called DecompressByteArray: compressed_data_size=81776 data_size=421543, decompressed_data_size=421543 diff=0
08:39:32:Unit 02:- Digital signature verified
08:39:32:Unit 02:
08:39:32:Unit 02:Project: 10120 (Run 69, Clone 2, Gen 71)
08:39:32:Unit 02:
08:39:32:Unit 02:Assembly optimizations on if available.
08:39:32:Unit 02:Entering M.D.
08:39:38:Unit 02:Tpr hash 02/wudata_01.tpr: 39394262 3729231909 752030893 1932571362 1003757422
08:39:38:Unit 02:
08:39:38:Unit 02:Calling fah_main args: 14 usage=100
08:39:38:Unit 02:
08:39:38:Unit 02:mdrun_gpu returned
08:39:38:Unit 02:Going to send back what have done -- stepsTotalG=0
08:39:38:Unit 02:Work fraction=0.0000 steps=0.
08:39:42:FahCore, running Unit 02, returned: UNSTABLE_MACHINE (122)
08:39:43:Starting Unit 02
08:39:43:Running core: G:/folding/data/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 02 -suffix 01 -lifeline 3668 -version 701 -checkpoint 3 -gpu 0
08:39:43:Started core on PID 4480
08:39:43:FahCore 0x11 started
08:39:43:FahCore, running Unit 02, returned: MISSING_WORK_FILES (116)
08:39:43:WARNING: Unit 02 Fatal error, dumping
08:39:43:Sending unit results: id:02 state:SEND project:10120 run:69 clone:2 gen:71 core:0x11 unit:0x000000590a3b1e6b4d9113f624f97244
08:39:43:Unit 02: Uploading 635B
08:39:43:Connecting to 171.64.65.71:8080
08:39:43:Connecting to assign-GPU.stanford.edu:80
08:39:44:Unit 02: Upload complete
08:39:44:Server responded WORK_ACK (400)
08:39:44:Cleaning up Unit 02
08:39:44:News: Welcome to Folding@Home
08:39:44:Assigned to work server 171.64.65.71
08:39:44:Requesting new work unit for slot 01: READY gpu:0:"G80 [GeForce 8800 GTX]" from 171.64.65.71
08:39:44:Connecting to 171.64.65.71:8080
08:39:45:Slot 01: Downloading 80.49KiB
08:39:46:Slot 01: Download complete
08:39:46:Received Unit: id:01 state:DOWNLOAD project:10111 run:329 clone:1 gen:351 core:0x11 unit:0x000001940a3b1e6b4cbcb57cffea29b9
08:39:46:Starting Unit 01
08:39:46:Running core: G:/folding/data/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -lifeline 3668 -version 701 -checkpoint 3 -gpu 0
08:39:46:Started core on PID 4024
08:39:46:FahCore 0x11 started
08:39:46:Unit 01:
08:39:46:Unit 01:*------------------------------*
08:39:46:Unit 01:Folding@Home GPU Core
08:39:46:Unit 01:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
08:39:46:Unit 01:
08:39:46:Unit 01:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
08:39:46:Unit 01:Build host: amoeba
08:39:46:Unit 01:Board Type: Nvidia
08:39:46:Unit 01:Core :
08:39:46:Unit 01:Preparing to commence simulation
08:39:46:Unit 01:- Looking at optimizations...
08:39:46:Unit 01:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
08:39:46:Unit 01:- Created dyn
08:39:46:Unit 01:- Files status OK
08:39:46:Unit 01:- Expanded 81914 -> 421543 (decompressed 514.6 percent)
08:39:46:Unit 01:Called DecompressByteArray: compressed_data_size=81914 data_size=421543, decompressed_data_size=421543 diff=0
08:39:46:Unit 01:- Digital signature verified
08:39:46:Unit 01:
08:39:46:Unit 01:Project: 10111 (Run 329, Clone 1, Gen 351)
08:39:46:Unit 01:
08:39:46:Unit 01:Assembly optimizations on if available.
08:39:46:Unit 01:Entering M.D.
08:39:52:Unit 01:Tpr hash 01/wudata_01.tpr: 4029314131 1985607673 3756137693 2931383815 1438525139
08:39:52:Unit 01:
08:39:52:Unit 01:Calling fah_main args: 14 usage=100
08:39:52:Unit 01:
08:39:52:Unit 01:mdrun_gpu returned
08:39:52:Unit 01:Going to send back what have done -- stepsTotalG=0
08:39:52:Unit 01:Work fraction=0.0000 steps=0.
08:39:56:Unit 01:logfile size=0 infoLength=0 edr=0 trr=25
08:39:56:Unit 01:+ Opened results file
08:39:56:Unit 01:- Writing 635 bytes of core data to disk...
08:39:56:Unit 01:Done: 123 -> 120 (compressed to 97.5 percent)
08:39:56:Unit 01: ... Done.
08:39:56:Unit 01:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
08:39:56:Unit 01:
08:39:56:Unit 01:Folding@home Core Shutdown: UNSTABLE_MACHINE
08:39:56:FahCore, running Unit 01, returned: UNSTABLE_MACHINE (122)
08:39:56:Starting Unit 01
08:39:56:Running core: G:/folding/data/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -lifeline 3668 -version 701 -checkpoint 3 -gpu 0
08:39:56:Started core on PID 4040
08:39:56:FahCore 0x11 started
08:39:57:FahCore, running Unit 01, returned: MISSING_WORK_FILES (116)
08:39:57:WARNING: Unit 01 Fatal error, dumping
08:39:57:Sending unit results: id:01 state:SEND project:10111 run:329 clone:1 gen:351 core:0x11 unit:0x000001940a3b1e6b4cbcb57cffea29b9
08:39:57:Unit 01: Uploading 632B
08:39:57:Connecting to 171.64.65.71:8080
08:39:57:Connecting to assign-GPU.stanford.edu:80
08:39:57:News: Welcome to Folding@Home
08:39:57:Assigned to work server 171.64.65.71
08:39:57:Requesting new work unit for slot 01: READY gpu:0:"G80 [GeForce 8800 GTX]" from 171.64.65.71
08:39:58:Unit 01: Upload complete
08:39:58:Server responded WORK_ACK (400)
08:39:58:Cleaning up Unit 01
08:39:58:Slot 01: Downloading 80.66KiB
08:39:59:Slot 01: Download complete
08:39:59:Received Unit: id:02 state:DOWNLOAD project:10112 run:643 clone:0 gen:358 core:0x11 unit:0x000001880a3b1e6b4ccf4f38e0e92fdf
08:39:59:Starting Unit 02
08:39:59:Running core: G:/folding/data/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 02 -suffix 01 -lifeline 3668 -version 701 -checkpoint 3 -gpu 0
08:39:59:Started core on PID 2312
08:39:59:FahCore 0x11 started
08:40:00:Unit 02:
08:40:00:Unit 02:*------------------------------*
08:40:00:Unit 02:Folding@Home GPU Core
08:40:00:Unit 02:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
08:40:00:Unit 02:
08:40:00:Unit 02:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
08:40:00:Unit 02:Build host: amoeba
08:40:00:Unit 02:Board Type: Nvidia
08:40:00:Unit 02:Core :
08:40:00:Unit 02:Preparing to commence simulation
08:40:00:Unit 02:- Looking at optimizations...
08:40:00:Unit 02:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
08:40:00:Unit 02:- Created dyn
08:40:00:Unit 02:- Files status OK
08:40:00:Unit 02:- Expanded 82084 -> 425170 (decompressed 517.9 percent)
08:40:00:Unit 02:Called DecompressByteArray: compressed_data_size=82084 data_size=425170, decompressed_data_size=425170 diff=0
08:40:00:Unit 02:- Digital signature verified
08:40:00:Unit 02:
08:40:00:Unit 02:Project: 10112 (Run 643, Clone 0, Gen 358)
08:40:00:Unit 02:
08:40:00:Unit 02:Assembly optimizations on if available.
08:40:00:Unit 02:Entering M.D.
08:40:06:Unit 02:Tpr hash 02/wudata_01.tpr: 1381251992 1208532241 3897506095 1507030035 4228842832
08:40:06:Unit 02:
08:40:06:Unit 02:Calling fah_main args: 14 usage=100
08:40:06:Unit 02:
08:40:06:Unit 02:mdrun_gpu returned
08:40:06:Unit 02:Going to send back what have done -- stepsTotalG=0
08:40:06:Unit 02:Work fraction=0.0000 steps=0.
08:40:10:Unit 02:logfile size=0 infoLength=0 edr=0 trr=25
08:40:10:Unit 02:+ Opened results file
08:40:10:Unit 02:- Writing 635 bytes of core data to disk...
08:40:10:Unit 02:Done: 123 -> 123 (compressed to 100.0 percent)
08:40:10:Unit 02: ... Done.
08:40:10:Unit 02:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
08:40:10:Unit 02:
08:40:10:Unit 02:Folding@home Core Shutdown: UNSTABLE_MACHINE
08:40:10:FahCore, running Unit 02, returned: UNSTABLE_MACHINE (122)
08:40:10:Starting Unit 02
08:40:10:Running core: G:/folding/data/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 02 -suffix 01 -lifeline 3668 -version 701 -checkpoint 3 -gpu 0
08:40:10:Started core on PID 3020
08:40:10:FahCore 0x11 started
08:40:11:FahCore, running Unit 02, returned: MISSING_WORK_FILES (116)
08:40:11:WARNING: Unit 02 Fatal error, dumping
08:40:11:Sending unit results: id:02 state:SEND project:10112 run:643 clone:0 gen:358 core:0x11 unit:0x000001880a3b1e6b4ccf4f38e0e92fdf
08:40:11:Unit 02: Uploading 635B
08:40:11:Connecting to 171.64.65.71:8080
08:40:11:Connecting to assign-GPU.stanford.edu:80
08:40:11:News: Welcome to Folding@Home
08:40:11:Assigned to work server 171.64.65.71
08:40:11:Requesting new work unit for slot 01: READY gpu:0:"G80 [GeForce 8800 GTX]" from 171.64.65.71
08:40:11:Unit 02: Upload complete
08:40:11:Server responded WORK_ACK (400)
08:40:12:Cleaning up Unit 02
08:40:12:Slot 01: Downloading 80.36KiB
08:40:13:Slot 01: Download complete
08:40:13:Received Unit: id:01 state:DOWNLOAD project:10111 run:773 clone:0 gen:296 core:0x11 unit:0x0000015e0a3b1e6b4cbcb7c053c337b0
08:40:13:Starting Unit 01
08:40:13:Running core: G:/folding/data/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -lifeline 3668 -version 701 -checkpoint 3 -gpu 0
08:40:13:Started core on PID 4632
08:40:13:FahCore 0x11 started
08:40:14:Unit 01:
08:40:14:Unit 01:*------------------------------*
08:40:14:Unit 01:Folding@Home GPU Core
08:40:14:Unit 01:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
08:40:14:Unit 01:
08:40:14:Unit 01:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
08:40:14:Unit 01:Build host: amoeba
08:40:14:Unit 01:Board Type: Nvidia
08:40:14:Unit 01:Core :
08:40:14:Unit 01:Preparing to commence simulation
08:40:14:Unit 01:- Looking at optimizations...
08:40:14:Unit 01:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
08:40:14:Unit 01:- Created dyn
08:40:14:Unit 01:- Files status OK
08:40:14:Unit 01:- Expanded 81774 -> 421543 (decompressed 515.4 percent)
08:40:14:Unit 01:Called DecompressByteArray: compressed_data_size=81774 data_size=421543, decompressed_data_size=421543 diff=0
08:40:14:Unit 01:- Digital signature verified
08:40:14:Unit 01:
08:40:14:Unit 01:Project: 10111 (Run 773, Clone 0, Gen 296)
08:40:14:Unit 01:
08:40:14:Unit 01:Assembly optimizations on if available.
08:40:14:Unit 01:Entering M.D.
08:40:19:Unit 01:Tpr hash 01/wudata_01.tpr: 804597839 2580901883 3010096066 1564626939 2534226499
08:40:19:Unit 01:
08:40:19:Unit 01:Calling fah_main args: 14 usage=100
08:40:19:Unit 01:
08:40:19:Unit 01:mdrun_gpu returned
08:40:19:Unit 01:Going to send back what have done -- stepsTotalG=0
08:40:19:Unit 01:Work fraction=0.0000 steps=0.
08:40:24:Unit 01:logfile size=0 infoLength=0 edr=0 trr=25
08:40:24:Unit 01:+ Opened results file
08:40:24:Unit 01:- Writing 635 bytes of core data to disk...
08:40:24:Unit 01:Done: 123 -> 120 (compressed to 97.5 percent)
08:40:24:Unit 01: ... Done.
08:40:24:Unit 01:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
08:40:24:FahCore, running Unit 01, returned: UNSTABLE_MACHINE (122)
