Memory runs at Dual-Channel interleaved Mode
* Dual channel (Interleaved) mode. This mode offers the highest throughput for real world applications. Dual channel mode is enabled when the installed memory capacities of both DIMM channels are equal. Technology and device width can vary from one channel to the other but the installed memory capacity for each channel must be equal. If different speed DIMMs are used between channels, the slowest memory timing will be used.
* Single channel (Asymmetric) mode. This mode is equivalent to single channel bandwidth operation for real world applications. This mode is used when only a single DIMM is installed or the memory capacities are unequal. Technology and device width can vary from one channel to the other. If different speed DIMMs are used between channels, the slowest memory timing will be used.
Stammt von hier
Da gibts auch Bilder bezgl. Bestückung
Wo hast du das denn hergezaubert, ich ab mir nen Wolf bei Google gesucht:(
Scheint ja alles in Ordnung zu sein:D
