kress
Volt-Modder(in)
mehrere Bluescreens, jedoch verschiedene Gründe
Hallo Leute,
mein HTPC läuft seit einiger Zeit nichtmehr stabil.
Athlon II x2 2x3ghz
2gb Kingston Value
Asus M4A88T-M/USB3
HD5450 passiv
Er bekommt immer wieder Bluescreens, die nicht reproduzierbar sind.
Diese hab ich mal ausgewertet nach Simple1970's Anleitung.
Herrausgekommen ist Folgendes:
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 00000403, The subtype of the bugcheck.
Arg2: c00985a0
Arg3: 3d45e867
Arg4: c000d2b8
Debugging Details:
BUGCHECK_STR: 0x1a_403
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: dllhost.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 82af1bfc to 82adf6b8
STACK_TEXT:
8525fb7c 82af1bfc c00985a0 c0098ff8 84a07d40 nt!MiDeletePteRun+0x663
8525fc84 82aebf69 12f70000 138f4fff acb7f065 nt!MiDeleteVirtualAddresses+0x3c1
8525fd1c 82a7b41a ffffffff 0356dc9c 0356dc98 nt!NtFreeVirtualMemory+0x60b
8525fd1c 77526344 ffffffff 0356dc9c 0356dc98 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
0356dbd0 00000000 00000000 00000000 00000000 0x77526344
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!MiDeletePteRun+663
82adf6b8 cc int 3
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt!MiDeletePteRun+663
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4d9fd915
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: 0x1a_403_nt!MiDeletePteRun+663
Followup: MachineOwner
CACHE_MANAGER (34)
See the comment for FAT_FILE_SYSTEM (0x23)
Arguments:
Arg1: 00050830
Arg2: 8ab038b0
Arg3: 8ab03490
Arg4: 53dbf826
Debugging Details:
EXCEPTION_RECORD: 8ab038b0 -- (.exr 0xffffffff8ab038b0)
ExceptionAddress: 53dbf826
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 00000008
Parameter[1]: 53dbf826
Attempt to execute non-executable address 53dbf826
CONTEXT: 8ab03490 -- (.cxr 0xffffffff8ab03490)
eax=8545dad8 ebx=84df3de0 ecx=00000003 edx=85070570 esi=86221020 edi=00000000
eip=53dbf826 esp=8ab03978 ebp=8ab0398c iopl=0 nv up ei ng nz ac pe cy
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010297
53dbf826 ?? ???
Resetting default scope
PROCESS_NAME: System
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
EXCEPTION_PARAMETER1: 00000008
EXCEPTION_PARAMETER2: 53dbf826
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 82b76718
Unable to read MiSystemVaType memory at 82b56160
53dbf826
FOLLOWUP_IP:
nt!IofCallDriver+63
82a4a48c 5e pop esi
FAULTING_IP:
+5cd52faf030ddbfc
53dbf826 ?? ???
FAILED_INSTRUCTION_ADDRESS:
+5cd52faf030ddbfc
53dbf826 ?? ???
BUGCHECK_STR: 0x34
TRAP_FRAME: 8ab03b54 -- (.trap 0xffffffff8ab03b54)
ErrCode = 00000010
eax=8545dad8 ebx=84df3de0 ecx=00000006 edx=84dda210 esi=86221020 edi=00000000
eip=a470283c esp=8ab03bc8 ebp=8ab03bdc iopl=0 nv up ei ng nz na pe cy
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010287
a470283c ?? ???
LAST_CONTROL_TRANSFER: from 82a4a48c to 53dbf826
STACK_TEXT:
8ab03974 82a4a48c 86221020 85070570 85070570 0x53dbf826
8ab0398c 8899f20c 8571dbf0 85070570 00000000 nt!IofCallDriver+0x63
8ab039b0 8899f3cb 8ab039d0 8571dbf0 00000000 fltmgr!FltpLegacyProcessingAfterPreCallbacksCompleted+0x2aa
8ab039e8 82a4a48c 8571dbf0 85070570 85070570 fltmgr!FltpDispatch+0xc5
8ab03a00 82ab3138 84d81378 848bbd48 84d81348 nt!IofCallDriver+0x63
8ab03a1c 82aba0e5 84a2cb08 848bbd48 84d81380 nt!IoPageRead+0x1f5
8ab03ab4 82a95f67 82b424c0 a470283c 84d81348 nt!MiIssueHardFault+0x28c
8ab03b3c 82a54608 00000008 a470283c 00000000 nt!MmAccessFault+0x2656
8ab03b3c a470283c 00000008 a470283c 00000000 nt!KiTrap0E+0xdc
8ab03bc4 82a4a48c 86221020 84dda210 84dda210 0xa470283c
8ab03bdc 8899f20c 8571dbf0 84dda210 00000000 nt!IofCallDriver+0x63
8ab03c00 8899f3cb 8ab03c20 8571dbf0 00000000 fltmgr!FltpLegacyProcessingAfterPreCallbacksCompleted+0x2aa
8ab03c38 82a4a48c 8571dbf0 84dda210 8571dbf0 fltmgr!FltpDispatch+0xc5
8ab03c50 82a432c8 8502e008 8502e04c 86040000 nt!IofCallDriver+0x63
8ab03c80 82aa6c2f 867758e8 00000000 860000e8 nt!CcSetValidData+0x96
8ab03ca8 82aaf00e 8ab03cc4 a3fec48a 848a0158 nt!CcWriteBehind+0x381
8ab03d00 82a7c03b 848a0158 00000000 848bbd48 nt!CcWorkerThread+0x164
8ab03d50 82c1c9df 00000000 a3fec41a 00000000 nt!ExpWorkerThread+0x10d
8ab03d90 82ace219 82a7bf2e 00000000 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt!IofCallDriver+63
MODULE_NAME: nt
IMAGE_NAME: ntkrpamp.exe
STACK_COMMAND: .cxr 0xffffffff8ab03490 ; kb
FAILURE_BUCKET_ID: 0x34_BAD_IP_nt!IofCallDriver+63
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 00000004, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: 82a7fae6, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 82b7c718
Unable to read MiSystemVaType memory at 82b5c160
00000004
CURRENT_IRQL: 2
FAULTING_IP:
nt!KiInsertTimerTable+1e2
82a7fae6 895804 mov dword ptr [eax+4],ebx
BUGCHECK_STR: 0xA
PROCESS_NAME: firefox.exe
TRAP_FRAME: a05bdb54 -- (.trap 0xffffffffa05bdb54)
ErrCode = 00000002
eax=00000000 ebx=85ff3b30 ecx=00000002 edx=85ff3b18 esi=82b3f680 edi=84c3edf0
eip=82a7fae6 esp=a05bdbc8 ebp=a05bdc10 iopl=0 nv up ei pl zr na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246
nt!KiInsertTimerTable+0x1e2:
82a7fae6 895804 mov dword ptr [eax+4],ebx ds:0023:00000004=????????
LAST_CONTROL_TRANSFER: from 82a7fae6 to 82a5a7fb
STACK_TEXT:
a05bdb54 82a7fae6 badb0d00 85ff3b18 00000000 nt!KiTrap0E+0x2cf
a05bdc10 82a814eb 85ff3b18 00000004 85ff3b48 nt!KiInsertTimerTable+0x1e2
a05bdc40 82a7b40f 85ff3a88 85ff3b48 00000004 nt!KiCommitThreadWait+0x1a7
a05bdcb8 82c459e5 86c28138 00000006 a05bdd01 nt!KeWaitForSingleObject+0x393
a05bdd20 82a5741a 00000208 00000000 a05bdce4 nt!NtWaitForSingleObject+0xc6
a05bdd20 77b06344 00000208 00000000 a05bdce4 nt!KiFastCallEntry+0x12a
02e5fa2c 00000000 00000000 00000000 00000000 0x77b06344
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_NAME: nt!KiInsertTimerTable+1e2
MODULE_NAME: nt
FAILURE_BUCKET_ID: 0xA_nt!KiInsertTimerTable+1e2
Hoffe ihr könnt mir helfen
MfG Kress
Hallo Leute,
Athlon II x2 2x3ghz
2gb Kingston Value
Asus M4A88T-M/USB3
HD5450 passiv
Arguments:
Arg2: c00985a0
Arg3: 3d45e867
Arg4: c000d2b8
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
82adf6b8 cc int 3
MODULE_NAME: nt
CACHE_MANAGER (34)
Arguments:
Arg1: 00050830
Arg2: 8ab038b0
Arg3: 8ab03490
Arg4: 53dbf826
Debugging Details:
NumberParameters: 2
53dbf826 ?? ???
CURRENT_IRQL: 0
53dbf826
FOLLOWUP_IP:
nt!IofCallDriver+63
82a4a48c 5e pop esi
FAULTING_IP:
+5cd52faf030ddbfc
53dbf826 ?? ???
+5cd52faf030ddbfc
53dbf826 ?? ???
BUGCHECK_STR: 0x34
ErrCode = 00000010
a470283c ?? ???
STACK_TEXT:
MODULE_NAME: nt
Arguments:
Debugging Details:
00000004
CURRENT_IRQL: 2
FAULTING_IP:
BUGCHECK_STR: 0xA
ErrCode = 00000002
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: nt
MfG Kress
