Hello.
Gigabyte 2080 Ti Aorus Waterforce Xtreme
The LED lights are located above the PCIe power connectors on the card.
When card is underload i can see white lights near pcie 2 connectors. Not blinking. Just white lights continuously. No problem in stability,clocks are normal.
Psu is Seasonic ULTRA TX 750W Platinum. Anybody have the same card?
Card is plugged by 2 separate pcie cables.
But according to AORUS white leds lightning continuosly means that there is no power LOL. So i guess its bug with RGB . Both two white lights are not blinking. They just lightning continuously. Card working ok.
