AW: Frage zur Ausführung von C++ Dateien
// Dialup.cpp : Defines the class behaviors for the application.
#include "stdafx.h"
#include "Dialup.h"
#include "DialupDlg.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// CDialupApp
BEGIN_MESSAGE_MAP(CDialupApp, CWinApp)
//{{AFX_MSG_MAP(CDialupApp)
// NOTE - the ClassWizard will add and remove mapping macros here.
// DO NOT EDIT what you see in these blocks of generated code!
//}}AFX_MSG
ON_COMMAND(ID_HELP, CWinApp::OnHelp)
END_MESSAGE_MAP()
// CDialupApp construction
CDialupApp::CDialupApp()
// TODO: add construction code here,
// Place all significant initialization in InitInstance
// The one and only CDialupApp object
CDialupApp theApp;
// CDialupApp initialization
BOOL CDialupApp::InitInstance()
AfxEnableControlContainer();
// Standard initialization
// If you are not using these features and wish to reduce the size
// of your final executable, you should remove from the following
// the specific initialization routines you do not need.
#ifdef _AFXDLL
Enable3dControls(); // Call this when using MFC in a shared DLL
#else
Enable3dControlsStatic(); // Call this when linking to MFC statically
#endif
CDialupDlg dlg;
m_pMainWnd = &dlg;
int nResponse = dlg.DoModal();
if (nResponse == IDOK)
// TODO: Place code here to handle when the dialog is
// dismissed with OK
else if (nResponse == IDCANCEL)
// dismissed with Cancel
// Since the dialog has been closed, return FALSE so that we exit the
// application, rather than start the application's message pump.
return FALSE;
