Hallo, ich habe seit kurzem eine neue Grafikkarte. GTX 560 2GB DDR5
Nun wollte ich mal ausprobieren ob die auch richtig funktioniert und mal Black Ops angeworfen. Nach 10 bis 15 Min spielen kommt dann Bluescreen mit dem Fehlercode 0x00000124
Hier nun die Fehler Analyse mit dem Debugging Tool:
* Bugcheck Analysis *
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8007e48028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b66ea000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000006000135, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_AuthenticAMD
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: BlackOps.exe
CURRENT_IRQL: f
STACK_TEXT:
fffff880`0316ca48 fffff800`03214a3b : 00000000`00000124 00000000`00000000 fffffa80`07e48028 00000000`b66ea000 : nt!KeBugCheckEx
fffff880`0316ca50 fffff800`033d8513 : 00000000`00000001 fffffa80`07e6a2d0 00000000`00000000 fffffa80`07e6a320 : hal!HalBugCheckSystem+0x1e3
fffff880`0316ca90 fffff800`03214700 : 00000000`00000728 fffffa80`07e6a2d0 fffff880`0316cdf0 00000000`00000000 : nt!WheaReportHwError+0x263
fffff880`0316caf0 fffff800`03214052 : fffffa80`07e6a2d0 fffff880`0316cdf0 fffffa80`07e6a2d0 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`0316cc40 fffff800`03207e8f : 00000000`183a0ebe 00000000`00000001 fffff880`0316ce70 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`0316cc80 fffff800`032c652c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x47
fffff880`0316ccb0 fffff800`032c6393 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`0316cdf0 00000000`008657ef : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
00000000`0b827df0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x8657ef
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_AuthenticAMD_PROCESSOR_CACHE
Followup: MachineOwner
Wo liegt der Fehler?
Arguments:
Debugging Details:
CURRENT_IRQL: f
STACK_TEXT:
STACK_COMMAND: kb
