Error 1721 kann kein Spiel installieren?
Transrapid033
Wie die überschrift schon sagt kann ich durch diesen obengeannten error das Spiel nicht installieren? an was kann es liegen????????????????
How to Fix Windows Installer Error 1722
Try the following solution to fix the Windows installer error 1722.
1. To fix the error, you have to make sure you have the latest version of InstallShield established your computer. If not, then update it to solve the error.
2. If the installment is unable to locate the required files, try to use the Windows' 'Search' feature to look for the files and offer the location to the installation process.
3. You must logon as administrative before you do the installation.
4. If you are installing over a network, please ensure that you have full access right to the network location where you are running the setup. 5. If the windows installer error 1722 remains, you may need to use a PC error Fixer or registry cleaner to scan your computer. Those tools are specifically designed to rid your computer's registry of the left over wreckage leading from unsuccessful installations. It will clean out the trouble behind unsuccessful installations by cleaning from your registry all of the unnecessary files and harmful programs that interfere with regular computer functions. It is the one-stop solution to most of your computer malfunction troubles and can rid you of those "installation error" messages, directly..
Klappt das? Oder den Artikel selber schon per Google gefunden und gelöst?? ;)
