Corsair Force MP510 - SMART zeigt Errors 0x4004 INVALID_FIELD
cyril15
Hi,
habe bei meinem Proxmox Server (Linux) eine Warnung erhalten:
The following warning/error was logged by the smartd daemon:
Device: /dev/nvme0, number of Error Log entries increased from 39 to 42
Device info:
Force MP510, S/N:18498207000127712007, FW:ECFM12.1, 960 GB
For details see host's SYSLOG.
You can also use the smartctl utility for further investigation.
Another message will be sent in 24 hours if the problem persists.
Das /var/log/syslog zeigt Folgendes:
Code:
Sep 14 00:52:58 SRV smartd[1081]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 106 to 107
Sep 14 00:52:58 SRV smartd[1081]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 111 to 112
Sep 14 01:22:58 SRV smartd[1081]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 112 to 111
Sep 14 02:22:59 SRV smartd[1081]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 112 to 111
Sep 14 02:52:58 SRV smartd[1081]: Device: /dev/sdd [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 109 to 110
Sep 14 02:52:58 SRV smartd[1081]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 111 to 112
Sep 14 03:22:58 SRV smartd[1081]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 112 to 111
[...] einige weitere solcher Einträge[...]
Sep 14 16:23:29 SRV systemd[1]: Starting The Proxmox VE cluster filesystem...
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/sde [SAT], is SMART capable. Adding to "monitor" list.
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/sde [SAT], state read from /var/lib/smartmontools/smartd.WDC_WD40EFRX_68WT0N0-WD_WCC4E5CVXVF5.ata.state
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/nvme0, opened
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/nvme0, Force MP510, S/N:18498207000127712007, FW:ECFM12.1, 960 GB
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/nvme0, is SMART capable. Adding to "monitor" list.
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/nvme0, state read from /var/lib/smartmontools/smartd.Force_MP510-18498207000127712007.nvme.state
Sep 14 16:23:29 SRV smartd[2495]: Monitoring 5 ATA/SATA, 0 SCSI/SAS and 1 NVMe devices
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 106 to 105
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/sde [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 111 to 110
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/nvme0, number of Error Log entries increased from 39 to 42
Sep 14 16:23:29 SRV smartd[2495]: Sending warning via /usr/share/smartmontools/smartd-runner to root ...
Sep 14 16:23:29 SRV smartd[2495]: Warning via /usr/share/smartmontools/smartd-runner to root: successful
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/sda [SAT], state written to /var/lib/smartmontools/smartd.WDC_WD40EFRX_68WT0N0-WD_WCC4E6DZ6LHE.ata.state
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/sdb [SAT], state written to /var/lib/smartmontools/smartd.WDC_WD40EFRX_68WT0N0-WD_WCC4E7RP1YXC.ata.state
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/sdc [SAT], state written to /var/lib/smartmontools/smartd.WDC_WD40EFRX_68WT0N0-WD_WCC4E4UH018T.ata.state
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/sdd [SAT], state written to /var/lib/smartmontools/smartd.WDC_WD40EFRX_68WT0N0-WD_WCC4E3JH0EUK.ata.state
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/sde [SAT], state written to /var/lib/smartmontools/smartd.WDC_WD40EFRX_68WT0N0-WD_WCC4E5CVXVF5.ata.state
Sep 14 16:23:29 SRV smartd[2495]: Device: /dev/nvme0, state written to /var/lib/smartmontools/smartd.Force_MP510-18498207000127712007.nvme.state
Sep 14 16:23:29 SRV systemd[1]: Started Self Monitoring and Reporting Technology (SMART) Daemon.
smartctl -a /dev/nvme0 zeigt Folgendes:
Code:
smartctl 7.0 2018-12-30 r4883 [x86_64-linux-5.0.15-1-pve] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number:                       Force MP510
Serial Number:                      18498207000127712007
Firmware Version:                   ECFM12.1
PCI Vendor/Subsystem ID:            0x1987
IEEE OUI Identifier:                0x6479a7
Total NVM Capacity:                 960,197,124,096 [960 GB]
Unallocated NVM Capacity:           0
Controller ID:                      1
Number of Namespaces:               1
Namespace 1 Size/Capacity:          960,197,124,096 [960 GB]
Namespace 1 Formatted LBA Size:     512
Namespace 1 IEEE EUI-64:            6479a7 1533133037
Local Time is:                      Sat Sep 14 16:43:20 2019 CEST
Firmware Updates (0x12):            1 Slot, no Reset required
Optional Admin Commands (0x0017):   Security Format Frmw_DL Self_Test
Optional NVM Commands (0x005d):     Comp DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp
Maximum Data Transfer Size:         512 Pages
Warning  Comp. Temp. Threshold:     70 Celsius
Critical Comp. Temp. Threshold:     90 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +    10.73W       -        -    0  0  0  0        0       0
 1 +     7.69W       -        -    1  1  1  1        0       0
 2 +     6.18W       -        -    2  2  2  2        0       0
 3 -   0.0490W       -        -    3  3  3  3     2000    2000
 4 -   0.0018W       -        -    4  4  4  4    25000   25000
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         2
 1 -    4096       0         1
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        48 Celsius
Available Spare:                    100%
Available Spare Threshold:          5%
Percentage Used:                    0%
Data Units Read:                    6,818,828 [3.49 TB]
Data Units Written:                 9,699,437 [4.96 TB]
Host Read Commands:                 167,986,048
Host Write Commands:                233,499,863
Controller Busy Time:               235
Power Cycles:                       7
Power On Hours:                     1,363
Unsafe Shutdowns:                   3
Media and Data Integrity Errors:    0
Error Information Log Entries:      42
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Error Information (NVMe Log 0x01, max 63 entries)
Num   ErrCount  SQId   CmdId  Status  PELoc          LBA  NSID    VS
  0         42     0  0x0008  0x4004      -            0     0     -
  1         41     0  0x0007  0x4004      -            0     0     -
  2         40     0  0x0004  0x4004      -            0     0     -
  3         39     0  0x0008  0x4004      -            0     0     -
  4         38     0  0x0007  0x4004      -            0     0     -
  5         37     0  0x0004  0x4004      -            0     0     -
  6         36     0  0x0008  0x4004      -            0     0     -
  7         35     0  0x0007  0x4004      -            0     0     -
  8         34     0  0x0004  0x4004      -            0     0     -
  9         33     0  0x0008  0x4004      -            0     0     -
 10         32     0  0x0007  0x4004      -            0     0     -
 11         31     0  0x0004  0x4004      -            0     0     -
 12         30     0  0x0008  0x4004      -            0     0     -
 13         29     0  0x0007  0x4004      -            0     0     -
 14         28     0  0x0004  0x4004      -            0     0     -
 15         27     0  0x0008  0x4004      -            0     0     -
... (26 entries not shown)
In human-readable Format hier die vollständige Liste an Errors: nvme error-log /dev/nvme0n1
Code:
Error Log Entries for device:nvme0n1 entries:63
 Entry[ 0]
error_count  : 42
sqid         : 0
cmdid        : 0x8
status_field : 0x4004(INVALID_FIELD: A reserved coded value or an unsupported value in a defined field)
parm_err_loc : 0xffff
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[ 1]
error_count  : 41
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[ 2]
error_count  : 40
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[ 3]
error_count  : 39
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[ 4]
error_count  : 38
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[ 5]
error_count  : 37
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[ 6]
error_count  : 36
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[ 7]
error_count  : 35
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[ 8]
error_count  : 34
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[ 9]
error_count  : 33
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[10]
error_count  : 32
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[11]
error_count  : 31
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[12]
error_count  : 30
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[13]
error_count  : 29
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[14]
error_count  : 28
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[15]
error_count  : 27
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[16]
error_count  : 26
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[17]
error_count  : 25
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[18]
error_count  : 24
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[19]
error_count  : 23
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[20]
error_count  : 22
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[21]
error_count  : 21
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[22]
error_count  : 20
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[23]
error_count  : 19
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[24]
error_count  : 18
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[25]
error_count  : 17
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[26]
error_count  : 16
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[27]
error_count  : 15
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[28]
error_count  : 14
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[29]
error_count  : 13
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[30]
error_count  : 12
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[31]
error_count  : 11
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[32]
error_count  : 10
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[33]
error_count  : 9
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[34]
error_count  : 8
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[35]
error_count  : 7
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[36]
error_count  : 6
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[37]
error_count  : 5
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[38]
error_count  : 4
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[39]
error_count  : 3
sqid         : 0
cmdid        : 0x8
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[40]
error_count  : 2
sqid         : 0
cmdid        : 0x7
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[41]
error_count  : 1
sqid         : 0
cmdid        : 0x4
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[42]
error_count  : 0
sqid         : 0
cmdid        : 0
status_field : 0(SUCCESS: The command completed successfully)
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[43]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[44]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[45]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[46]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[47]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[48]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[49]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[50]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[51]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[52]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[53]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[54]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[55]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[56]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[57]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[58]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[59]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[60]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[61]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
 Entry[62]
error_count  : 0
sqid         : 0
cmdid        : 0
parm_err_loc : 0
lba          : 0
nsid         : 0
vs           : 0
cs           : 0
Die Temperatur scheint wohl nicht damit zusammenzuhängen, da sie mit 48°C auch normal nicht heiß ist.
Tatsächlich sind also alle 42 Error Log Einträge vom selben Typ:
Habt ihr eine Ahnung, was das sein könnte?
System:
- ASRock Rack E3C236D4U
- Intel Xeon E3-1260L v5
- 4x 16 GB Micron 18ASF2G72AZ-2G3B1 ECC RAM
- Corsair Force MP510, erst seit wenigen Monaten im Einsatz, sonst habe ich soweit nichts Auffälliges bemerkt, Performance passt
- 5x WDC WD40EFRX-68WT0N0, seit Jahren ohne Probleme im Einsatz, SMART zeigt bei denen jeweils No Errors Logged
Ein Problem im Zusammenspiel Linux, smartctl, SSD Firmware und NVMe.
Eventuell kann hier das aktualisieren dieser Softwarekomponenten Abhilfe schaffen.
