Corsair bringt neues Gehäuse
der_george
Seit kurzem ist auf der Corsair eigenen Homepage ein neues Gehäuse aufgetaucht.
Obsidian Series™ 650D Mid-Tower Case
SKU# CC650DW
Brilliant Design, Inside and Out™
The Obsidian Series 650D is manufactured with strong, stamped steel parts for increased rigidity, and coated in a black textured paint. The front panel features a beautiful black brushed aluminum faceplate to bring a subtle elegance to your next build. "
Quelle: Obsidian Series? 650D Mid-Tower Case - Obsidian Series - Cases
Technische Daten:
Warranty Two years
MB Support ATX, mATX
Expansion Slots 8
Form Factor Mid-tower
Material Steel structure with black brushed aluminum faceplate
Drive Bays (x4) 5.25” (x6) 3.5”/2.5” Drive Caddies
Cooling (x2) 200mm Fans (x1) 120mm Fans
Front I/O (x4) USB 2.0 (x1) USB 3.0 (x1) IEEE 1394 (x1) Headphone, (x1) Mic 4-channel Fan Controller
Power Supply ATX (not included)
Advanced Features for Extreme Flexibility
Six drive bays with clever snap-in trays accommodate both 3.5" and 2.5" drives with no adapter necessary. A unique cable routing system virtually eliminates cable clutter that can impede airflow. The tool-free design allows for easy entry, easy access, and quick installation of 5.25" drives.
Features include
  • Dual 200mm fans provide outstanding cooling for even the hottest components
  • Easily accessible dust filters make maintenance simple and hassle-free
  • Quick-release side panels make it easier than ever to upgrade your hardware
  • Integrated fan controller lets you quickly adjust cooling performance and noise levels
  • Four tool-free optical drive bays and up to six SSD-ready hard drive trays provide plenty of expansion
  • CPU backplate cutout makes it easy to upgrade your CPU cooler
  • Brilliant cable routing system provides a way to keep your system neat and tidy
  • Adjustable drive cages can be removed and relocated to accommodate large video cards
  • Room for long power supplies gives you peace of mind for future upgrades
About The Obsidian Family
The Obsidian Series 800D and 700D full-tower cases share the same case dimensions, rock-solid construction, isolated cooling zones, and lots of other features that make them truly great cases for builders. Choose the Obsidian Series 800D if you'd like hot-swap SATA drive bays and the clear side panel strikes your fancy; if you don't need the hot-swap feature and you like the look of the solid side panel, the Obsidian Series 700D is for you. The 650D is a mid-tower variant for those that don’t need the room of the 800D and 700D, but still want excellent cooling and elegant good looks in a compact package.
Leider ist noch kein Preis verfügbar, dürfte sich aber wohl unter den bekannten Obsidian Gehäusen 800D und 700D ansiedeln.So long :0)
AW: Corsair bringt neues Gehäuse
und für alle die zu Faul sind die Quelle anzuklicken, habe ich mal die Fotos hier angehängt.
Wenn du hier eine News schreibst, dann mach es bitte richtig, und schriebe einen eigenen Text, und kopiere keinen, erst recht nicht wenn er englisch ist.
Ansonsten schönes Gehäuse.
Mal gucken, vielleicht ist es ja mal eines tages meins :)
Übersetzung? :ugly:
Also vor befürchte ich wird die News dicht gemacht, denn das ist nur zweimal copy&paste...
Ansonsten trotzdem Danke, Corsair ist mir leider durch gegangen.
EDIT: Ok das danke kannste streichen.
geht ja mal garnicht....
Mir gefallen nur die Hebel zum Öffnen der Seitenwand absolut nicht... sonst ein super case, optisch :daumen:
Das Gehäuse hätte schon was, klassisch Elegant. Die Griffe und den komischen Fensterrahmen hätte man weglassen dürfen. Wenn dann noch der Preis stimmen würde könnte man es für ein zukünftiges Upgrade mit einbeziehen.
Seitenteil sieht ja mal schei*e aus, aber ansonsten ist ein sehr schönes Gehäuse. Was wird es wohl kosten? 150€?
Schöner als der Plastikbomber 600T ist es auf jeden Fall. Gefällt mir eigentlich ganz gut, den Preis muss man mal abwarten
Der dicke Gummirand fürs Fenster zerstört natürlich den schönen Gesamteindruck, aber alles andere gefällt mir sehr gut bis jetzt.
