What's the deal with void main()
Under regular function calling/returning in C and C++, if your don't ever want to return anything from a function, you define it's return type as void. For example, a function that takes no arguments, and returns nothing can be prototyped as:
A common misconception is that the same logic can be applied to main(). Well, it can't, main() is special, you should always follow the standard and define the return type as int. There are some exceptions where void main() is allowed, but these are on specialised systems only. If you're not sure if you're using one of these specialised systems or not, then the answer is simply no, you're not. If you were, you'd know it.
Be warned that if you post your "void main" code on the forums, you're going to get told to correct it. Responding with "my teacher said it's OK" is no defence; teachers have a bad habit of being wrong. Be safe, and post only standard code, and you'll find people concentrate on answering your other problems, rather than waste time telling you about this type of thing.
