XHotSniperX
Hi
ich bekomme einen Fehler bei der Installation von Red5 Server unter Debian 5
Log:
was könnte das Problem sein?
vielen dank!
Log:
Code:
Log
s162:~# dpkg -i red5_0.7.0_all.deb
(Reading database ... 236791 files and directories currently installed.)
Preparing to replace red5 0.7.0 (using red5_0.7.0_all.deb) ...
/etc/init.d/red5: line 12: /etc/rc.d/init.d/functions: No such file or directory
Stopping Red5 flash streaming server: /etc/init.d/red5: line 62: failure: command not found
invoke-rc.d: initscript red5, action "stop" failed.
dpkg: warning - old pre-removal script returned error exit status 127
dpkg - trying script from the new package instead ...
dpkg: error processing red5_0.7.0_all.deb (--install):
subprocess new pre-removal script returned error exit status 127
update-rc.d: warning: /etc/init.d/red5 missing LSB information
update-rc.d: see <http://wiki.debian.org/LSBInitScripts>
Starting Red5 flash streaming server: /etc/init.d/red5: line 52: cd: /opt/red5-0.8/: No such file or directory
touch: cannot touch `/var/lock/subsys/red5': No such file or directory
Errors were encountered while processing:
red5_0.7.0_all.deb
vielen dank!
