hunterseyes
Immer wieder morgens beim Starten Bluescreens, bis er endlich mal läuft...einer eine hilfreiche Lösung/Idee?
Mein Rechner:
Win 10 64Bit home
AMD Ryzen 7 3700x D
DDR4-Ram 3200
Geforce GTX 2070 Super
X570 Gaming Egde WiFi
1 TB M.2 970Evo Plus
Define R6 PCGH-Edition
Crash dumps are enabled on your computer.
Crash dump directories:
C:\Windows
C:\Windows\Minidump
On Wed 15.01.2020 06:06:33 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\011520-12484-01.dmp
This was probably caused by the following module: hardware.sys (hardware)
Bugcheck code: 0x1A (0x41792, 0xFFFFEEBFFDDC6418, 0x8000000000, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred. A corrupted PTE has been detected.
This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver. This problem might also be caused because of overheating (thermal issue).
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: hardware.sys .
Google query: hardware.sys MEMORY_MANAGEMENT
crash dump file: C:\Windows\MEMORY.DMP
On Tue 14.01.2020 06:05:33 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\011420-10703-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1C14E0)
Bugcheck code: 0x50 (0xFFFFAEFDC040F0C8, 0x0, 0xFFFFF8913A52C446, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Fri 10.01.2020 13:36:26 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\011020-10734-01.dmp
Bugcheck code: 0xA0 (0x10E, 0xA, 0x7F76, 0x9DEF)
Error: INTERNAL_POWER_ERROR
Bug check description: This bug check indicates that the power policy manager experienced a fatal error.
This is likely to be caused by a hardware problem. This problem might also be caused because of overheating (thermal issue).
Mein Rechner:
Win 10 64Bit home
AMD Ryzen 7 3700x D
DDR4-Ram 3200
C:\Windows
C:\Windows\Minidump
