Bluescreen 3b 1031 - Wo liegt das Problem?
frugi
ich bekomme seit einigen Monaten in unregelmäßigen Abständen einen Bluescreen. Ich würde nun gerne der Sache nachgehen und den Fehler möglichst beheben. Ich habe mit dem Debugging Tool die folgende Datei erstellt:
* Bugcheck Analysis *
PFN_LIST_CORRUPT (4e)
Typically caused by drivers passing bad memory descriptor lists (ie: calling
MmUnlockPages twice with the same list, etc). If a kernel debugger is
available get the stack trace.
Arguments:
Arg1: 0000000000000099, A PTE or PFN is corrupt
Arg2: 0000000000078a8c, page frame number
Arg3: 0000000000000002, current page state
Arg4: 000000000007958b, 0
Debugging Details:
BUGCHECK_STR: 0x4E_99
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: svchost.exe
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from fffff80002d1913c to fffff80002c895c0
STACK_TEXT:
fffff880`0912df98 fffff800`02d1913c : 00000000`0000004e 00000000`00000099 00000000`00078a8c 00000000`00000002 : nt!KeBugCheckEx
fffff880`0912dfa0 fffff800`02cfb945 : 00000000`00000000 fffff683`ff7f86d8 00000000`00000002 00000000`00000001 : nt!MiBadShareCount+0x4c
fffff880`0912dfe0 fffff800`02c5dbb3 : fffffa80`04d2c720 fffff700`0000122b 0000007f`fffffff8 fffff8a0`0499b418 : nt! ?? ::FNODOBFM::`string'+0x321ec
fffff880`0912e070 fffff800`02c5c60e : fffffa80`04d2c720 fffffa80`0000000b fffff8a0`00000878 fffff880`00000000 : nt!MiDeleteAddressesInWorkingSet+0x307
fffff880`0912e920 fffff800`02f6ba8b : fffff8a0`02456060 fffff880`0912ec20 00000000`00000000 fffffa80`068fe060 : nt!MmCleanProcessAddressSpace+0x96
fffff880`0912e970 fffff800`02f44131 : 00000000`000000ff 00000000`00000001 000007ff`fff6a000 fffffa80`0656bb60 : nt!PspExitThread+0x92f
fffff880`0912ea30 fffff800`02c6611b : 00000000`00000000 fffffa80`0658bb50 00000000`03ccfd80 fffff880`0912ebe0 : nt!PsExitSpecialApc+0x1d
fffff880`0912ea60 fffff800`02c66560 : 00000000`77d45298 fffff880`0912eae0 fffff800`02f441b8 00000000`00000001 : nt!KiDeliverApc+0x2eb
fffff880`0912eae0 fffff800`02c888b7 : fffffa80`068fe060 00000000`77d45270 fffff880`000000c0 00000000`00000000 : nt!KiInitiateUserApc+0x70
fffff880`0912ec20 00000000`77c90fba : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9c
00000000`03ccfb98 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77c90fba
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!MiBadShareCount+4c
fffff800`02d1913c cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt!MiBadShareCount+4c
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4e02aa44
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: X64_0x4E_99_nt!MiBadShareCount+4c
Followup: MachineOwner
Also ich kann dir nicht genau sagen was diese Meldung bedeutet aber ich versuch bei nem Bluescreen immer zu testen obs vielleicht an der CPU oder Ram Spannung liegt und erhöhe diese leicht im Bios ansonsten würd ich dann mal ein Bios Update machen.
Aber ich weis nicht ob das dir hilft zumindest könnte man es mal probieren um diese Fehlerquelle auszuschließen.
also Memtest86+ wird heute Nacht durchlaufen.
Hier schon mal die Screenshots von CPU-Z
Es ist nicht immer der selbe Stopfehlercode. In den Dump Files habe ich mehrere verschiedene gefunden:
IMAGE_NAME: ntkrnlmp.exe
IMAGE_NAME: Ntfs.sys
IMAGE_NAME: Pool_Corruption
Ich weiß jetzt allerdings nicht, ob bei jedem Dump File der Bluescreen erschienen ist und Windows abgestürzt ist.
An der Spannung etwas zu verändern traue ich mich ehrlich gesagt nicht. Mal schauen ob die Screenshots und der Test heute mehr Aufschluss geben.
  • Bluescreen Untersuchungdoc.pdf
Dann bin ich erst mal auf das Ergebnis von Memtest gespannt.
Wenn es nach 3-4 Std. keine Fehler ausspuckt, stelle testweise zunächst die Command Rate der RAM im Bios auf 2T.
Memtest86+ lief jetzt 12 Stunden und damit 13 Mal ohne Fehler durch.
Die Einstellung Command Rate habe ich im Bios nicht gefunden. Ich schätze mal das heißt da anders. Könnte es vielleicht DRAM Timing Mode sein? Das steht auf Auto und hat noch die weiteren Optionen DCT 0, DCT 1 und Both.
Stelle den DRAM Timing Mode auf "Both". Die Timingeinstellungen und auch die Command Rate sollten dann zu sehen sein.
Hi simpel1970,
danke für die Info, dann werde ich das so einstellen. Ich kann dir allerdings erst in ein paar Wochen Rückmeldung geben, da ich vorher in Urlaub muss :-)
Danach wird das Problem mit neuer Energie wieder angegangen
