Danke sehr für die Antworten,so hab die DumpDatei laufen lassen,obwohl ich zu 100% sicher war dass es an einem einzigen Treiber liegen wird weil der gleiche BSOD kommt manchmal beim Laden des Desktops auch auf dem Computer meines Bruders vor der ausser das Mobo die meisten anderen Komponenten (mit Treiber) anders sind,bin ich auf ntkrnlmp.exe gestossen...
Ich hoffe jemand kann weiterhelfen.
* Bugcheck Analysis *
DRIVER_CORRUPTED_EXPOOL (c5)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is
caused by drivers that have corrupted the system pool. Run the driver
verifier against any new (or suspect) drivers, and if that doesn't turn up
the culprit, then use gflags to enable special pool.
Arguments:
Arg1: 0000000600000392, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff80003200617, address which referenced memory
Debugging Details:
BUGCHECK_STR: 0xC5_2
CURRENT_IRQL: 2
FAULTING_IP:
nt!ExAllocatePoolWithTag+537
fffff800`03200617 48895808 mov qword ptr [rax+8],rbx
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: svchost.exe
TRAP_FRAME: fffff880093ff490 -- (.trap 0xfffff880093ff490)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=000000060000038a rbx=0000000000000000 rcx=fffffa8006928220
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80003200617 rsp=fffff880093ff620 rbp=0000000000001000
r8=0000000000000000 r9=fffff8000325c6e0 r10=fffff8000325c588
r11=fffff800030e3cf0 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
nt!ExAllocatePoolWithTag+0x537:
fffff800`03200617 48895808 mov qword ptr [rax+8],rbx ds:00000006`00000392=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff800030d4769 to fffff800030d51c0
STACK_TEXT:
fffff880`093ff348 fffff800`030d4769 : 00000000`0000000a 00000006`00000392 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`093ff350 fffff800`030d33e0 : fffff8a0`03d2db84 00000000`00000000 00000000`00000000 fffff800`0325c6e0 : nt!KiBugCheckDispatch+0x69
fffff880`093ff490 fffff800`03200617 : 00000002`00000000 fffffa80`06b20270 fffffa80`00040004 00000000`00000000 : nt!KiPageFault+0x260
fffff880`093ff620 fffff800`0337155f : 00000000`00000000 fffffa80`06ae94e0 fffffa80`057a1060 00000000`00000000 : nt!ExAllocatePoolWithTag+0x537
fffff880`093ff710 fffff800`0336b818 : 00000000`00881fff fffffa80`06ae94a0 fffff8a0`037f7950 fffffa80`06b20270 : nt!MiAddSecureEntry+0x18f
fffff880`093ff750 fffff800`0337252f : 00000000`00000000 fffffa80`060f1620 00000000`0036ba48 fffffa80`057a1278 : nt!MmSecureVirtualMemoryAgainstWrites+0x278
fffff880`093ff7f0 fffff800`033e0488 : 00000000`00000000 00000000`00000000 fffff880`093ffa00 00000000`00000001 : nt!AlpcpReceiveView+0x9f
fffff880`093ff880 fffff800`033ddffb : fffffa80`068f8de0 fffffa80`00020000 00000000`00339310 00000000`0036ba48 : nt!AlpcpProcessSynchronousRequest+0x5c5
fffff880`093ff9c0 fffff800`030d4453 : fffffa80`06b20270 fffff880`093ffb60 00000000`00000003 00000000`00361320 : nt!NtAlpcSendWaitReceivePort+0x1ab
fffff880`093ffa70 00000000`77cf1b6a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`01e0edf8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77cf1b6a
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!ExAllocatePoolWithTag+537
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4fa390f3
FAILURE_BUCKET_ID: X64_0xC5_2_nt!ExAllocatePoolWithTag+537
Followup: MachineOwner
