JoM79
Trockeneisprofi (m/w)
Dann kannst du den XG43UQ lauft Definition der VESA auch vergessen.
VESA Publishes DisplayPort™ Standard Version 1.4 - DisplayPortDP 1.4 further builds on the capabilities of the standard’s prior incarnations. The use of video transport compression enhances the ability to take advantage of the USB Type-C connector, enabling both high-definition video and SuperSpeed USB, while also facilitating High Dynamic Range (HDR) and 8K video across the DisplayPort or USB-C connector. Examples of increased display resolution with the new standard include 8Kp60Hz HDR deep color and 4Kp120Hz HDR deep color.
