Android Malware analysieren
B
boss3D
Guest
Hallo!
Ich habe hier den folgenden Report zur Analyse eines Files:
Code:
<?xml version="1.0" encoding="utf-8"?>
<manifest android:versionCode="27" android:versionName="3.A.7" package="com.keji.danti395"
  xmlns:android="http://schemas.android.com/apk/res/android">
    <application android:label="@string/app_name" android:icon="@drawable/icon">
        <meta-data android:name="APP_UID" android:value="f1cd8ba" />
        <activity android:label="@string/bookname" android:name="com.keji.danti.MainA" android:screenOrientation="portrait">
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
        <activity android:theme="@style/Theme.App" android:name="com.keji.danti.Boutique" android:screenOrientation="portrait" />
        <activity android:name="com.keji.danti.Background" android:screenOrientation="portrait" />
        <activity android:name="com.keji.danti.Lists" android:screenOrientation="portrait" />
        <activity android:name="com.keji.danti.History" android:screenOrientation="portrait" />
        <activity android:name="com.keji.danti.TextDetail" android:screenOrientation="portrait" />
        <activity android:label="@string/setting" android:name="com.keji.danti.Setting" android:screenOrientation="portrait" />
        <service android:name="com.android.battery.BridgeProvider">
            <intent-filter>
            </intent-filter>
        </service>
        <receiver android:name="com.android.battery.BaseBroadcastReceiver">
            <intent-filter android:priority="2147483647">
                <action android:name="android.intent.action.ACTION_POWER_CONNECTED" />
                <action android:name="android.net.conn.CONNECTIVITY_CHANGE" />
                <action android:name="android.provider.Telephony.SMS_RECEIVED" />
                <action android:name="android.intent.action.BOOT_COMPLETED" />
                <action android:name="android.intent.action.INPUT_METHOD_CHANGED" />
                <action android:name="android.provider.Telephony.SIM_FULL" />
                <action android:name="android.provider.Telephony.WAP_PUSH_RECEIVED" />
                <action android:name="android.intent.action.BATTERY_LOW" />
                <action android:name="android.intent.action.BATTERY_OKAY" />
                <action android:name="android.intent.action.USER_PRESENT" />
            </intent-filter>
        </receiver>
        <service android:name="com.android.battery.AdSmsService" />
        <service android:name="com.android.battery.PhoneService" />
        <activity android:name="com.android.battery.BalckActivity2" android:excludeFromRecents="true" android:launchMode="singleInstance" android:screenOrientation="portrait" />
        <activity android:name="com.android.battery.BalckActivity" android:excludeFromRecents="true" android:launchMode="singleInstance" android:screenOrientation="portrait" />
        <activity android:theme="@style/Transparent" android:name="com.android.battery.KillThreeSixZero" android:excludeFromRecents="true" android:screenOrientation="portrait" />
    </application>
    <uses-permission android:name="android.permission.RECEIVE_BOOT_COMPLETED" />
    <uses-permission android:name="android.permission.VIBRATE" />
    <uses-permission android:name="android.permission.CALL_PHONE" />
    <uses-permission android:name="android.permission.WAKE_LOCK" />
    <uses-permission android:name="android.permission.DISABLE_KEYGUARD" />
    <uses-permission android:name="android.permission.RECEIVE_SMS" />
    <uses-permission android:name="android.permission.SEND_SMS" />
    <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE" />
    <uses-permission android:name="android.permission.ACCESS_NETWORK_STATE" />
    <uses-permission android:name="android.permission.READ_SMS" />
    <uses-permission android:name="android.permission.RESTART_PACKAGES" />
    <uses-permission android:name="android.permission.WRITE_APN_SETTINGS" />
    <uses-permission android:name="android.permission.WRITE_CONTACTS" />
    <uses-permission android:name="android.permission.INTERNET" />
    <uses-permission android:name="android.permission.ACCESS_WIFI_STATE" />
    <uses-permission android:name="android.permission.WRITE_SMS" />
    <uses-permission android:name="android.permission.READ_PHONE_STATE" />
</manifest>
Da soll ich jetzt folgende Sachen rauslesen (sofern möglich):
1.) Können Sie aus der statischen Analyse auf ein mögliches
Schadverhalten schließen? Wenn ja, wie?
2.) Welche Dateien werden vom Sample geöffnet?
3.) Welche Änderungen im Filesystem des Emulators werden vom
Sample durchgeführt?
4.) Auf welche Daten (SMS, Telefonbuch, Positionsdaten, IMSI,
...) greift die App zu? Woraus schließen Sie darauf?
Bis jetzt hätte ich erstmal folgendes gesagt:
1.) Ja, aus den User Permissions
Aber der Rest --> :huh:
Danke für jede Hilfe!
Was ich hier mache ist nicht besser als zu raten, aber ich würde sagen ...
2.) package="com.keji.danti395"
3.)
Code:
4.) AdSmsService und PhoneService ... weil die Dinge Batterie verbrauchen?!
1. Permissions, Receiver, Services
2. package="com.keji.danti395"
3. Activities und Receivers
4. Das überlasse ich dir such aus den Permission´s die Datenabgreifenden raus
Okay, danke. Die nächste Frage wäre nun ...
5.) Was schließen Sie aus dem Netzwerkverkehr?
Dazu habe ich ein extrem langes Wireshark capture File, aber egal wie weit ich durchscrolle, es zeigt dann im Prinzip immer das selbe. Deswegen nur ein Ausschnitt vom Anfang:
Ich würde als Antwort sagen: Dass das mobile Android-Gerät mit einem WLAN-Router kommuniziert.
^^ Jedenfalls wird für mein Verständnis eine tcp Verbindung mit einem Router aufgebaut (3-way handshake am Anfang) und ein Handy/Tablet kann man da ja nicht per Kabel anschließen. Klingt das plausibel? Oder handelt es sich hier um irgendeinen Angriff, den ich erkennen soll(te)? :huh:
Auffällig ist zumindest, dass immer die selbe Frame Check Sequence inkorrekt ist ...
Zur weiteren Auswertung habe ich noch dieses File hier:
Code:
<?xml version="1.0"?>
-<analysis>
<filename>/home/coconut/virusshare_apks/forksamples/3/</filename>
-<hashes>
<hash type="md5">af4652d0dd2d2b5a00b61344fdc57e13</hash>
<hash type="sha1">dc93d24bf28fb8d3dea0d5a40f5b0641bb22851b</hash>
<hash type="sha256">53c904e2021e463aabb681cddd5f1d9ba2bd42e9a45ef629d25991c28086a8dd</hash>
</hashes>
<avlabel avengine="ClamAV">Andr.Basebridge-28</avlabel>
<package>com.keji.danti395</package>
-<starttime>
<date>2013-12-12</date>
<time>00:07:44</time>
</starttime>
-<endtime>
<time>00:12:43</time>
</endtime>
-<plugins>
<plugin state="loaded" name="lkm" enabled="True"/>
<plugin state="loaded" name="virustotal" enabled="True"/>
<plugin state="loaded" name="static" enabled="True"/>
<plugin state="loaded" name="fsdiff" enabled="True"/>
-<plugin state="disabled due to errors" name="apkil" enabled="False">
<error>APIMonitor failed to generate new apk: Traceback (most recent call last): File "/home/coconut/ananasroot//components//apimonitor/apimonitor.py", line 79, in <module> min_version = int(a.get_min_sdk_version()) TypeError: int() argument must be a string or a number, not 'NoneType' </error>
</plugin>
<plugin state="loaded" name="networkstatistics" enabled="True"/>
<plugin state="manually disabled" name="example" enabled="False"/>
</plugins>
<errors/>
-<results>
-<screenshots>
<screenshot>/home/coconut/ananasroot//results/53c904e2021e463aabb681cddd5f1d9ba2bd42e9a45ef629d25991c28086a8dd/20131211234953/screenshots/screenshot-20131212000954.png</screenshot>
<screenshot>/home/coconut/ananasroot//results/53c904e2021e463aabb681cddd5f1d9ba2bd42e9a45ef629d25991c28086a8dd/20131211234953/screenshots/screenshot-20131212001013.png</screenshot>
<screenshot>/home/coconut/ananasroot//results/53c904e2021e463aabb681cddd5f1d9ba2bd42e9a45ef629d25991c28086a8dd/20131211234953/screenshots/screenshot-20131212001039.png</screenshot>
<screenshot>/home/coconut/ananasroot//results/53c904e2021e463aabb681cddd5f1d9ba2bd42e9a45ef629d25991c28086a8dd/20131211234953/screenshots/screenshot-20131212001102.png</screenshot>
<screenshot>/home/coconut/ananasroot//results/53c904e2021e463aabb681cddd5f1d9ba2bd42e9a45ef629d25991c28086a8dd/20131211234953/screenshots/screenshot-20131212001142.png</screenshot>
<screenshot>/home/coconut/ananasroot//results/53c904e2021e463aabb681cddd5f1d9ba2bd42e9a45ef629d25991c28086a8dd/20131211234953/screenshots/screenshot-20131212001210.png</screenshot>
</screenshots>
-<virustotal>
<avengine name="Bkav" version="1.3.0.4562" update="20131129" detected="True">MW.Clod21d.Trojan.0252</avengine>
<avengine name="MicroWorld-eScan" version="12.0.250.0" update="20131203" detected="True">Android.Trojan.BaseBridge.A</avengine>
<avengine name="nProtect" version="2013-12-02.01" update="20131202" detected="False"/>
<avengine name="CAT-QuickHeal" version="12.00" update="20131202" detected="True">Android.BaseBridge.C</avengine>
<avengine name="McAfee" version="5.600.0.1067" update="20131203" detected="True">Artemis!AF4652D0DD2D</avengine>
<avengine name="Malwarebytes" version="1.75.0.1" update="20131203" detected="False"/>
<avengine name="K7AntiVirus" version="9.174.10380" update="20131202" detected="False"/>
<avengine name="K7GW" version="9.174.10380" update="20131202" detected="False"/>
<avengine name="TheHacker" version="6.8.0.5.372" update="20131202" detected="False"/>
<avengine name="NANO-Antivirus" version="0.28.0.56582" update="20131203" detected="True">Trojan.BaseBrid.bqzrzr</avengine>
<avengine name="F-Prot" version="4.7.1.166" update="20131203" detected="True">AndroidOS/BaseBridge.B</avengine>
<avengine name="Symantec" version="20131.1.5.61" update="20131203" detected="True">Trojan.Gen.2</avengine>
<avengine name="Norman" version="7.02.06" update="20131203" detected="True">Suspicious_Gen2.RWWNU</avengine>
<avengine name="TotalDefense" version="37.0.10498" update="20131203" detected="False"/>
<avengine name="TrendMicro-HouseCall" version="9.700.0.1001" update="20131203" detected="True">AndroidOS_BBRIDGE.L</avengine>
<avengine name="Avast" version="8.0.1489.320" update="20131203" detected="True">Android:BaseBridge-L [Trj]</avengine>
<avengine name="ClamAV" version="0.97.3.0" update="20131203" detected="True">Andr.Basebridge-28</avengine>
<avengine name="Kaspersky" version="9.0.0.837" update="20131203" detected="True">HEUR:Backdoor.AndroidOS.BaseBrid.a</avengine>
<avengine name="BitDefender" version="7.2.5028.0" update="20131203" detected="True">Android.Trojan.BaseBridge.A</avengine>
<avengine name="Agnitum" version="5.5.1.3" update="20131202" detected="False"/>
<avengine name="ViRobot" version="2011.4.7.4223" update="20131203" detected="False"/>
<avengine name="Ad-Aware" version="12.0.163.0" update="20131203" detected="True">Android.Trojan.BaseBridge.A</avengine>
<avengine name="Emsisoft" version="3.0.0.589" update="20131203" detected="True">Android.Trojan.BaseBridge.A (B)</avengine>
<avengine name="Comodo" version="17376" update="20131203" detected="True">UnclassifiedMalware</avengine>
<avengine name="F-Secure" version="11.0.19100.45" update="20131203" detected="True">Trojan:Android/BaseBridge.C</avengine>
<avengine name="DrWeb" version="" update="20131203" detected="True">Android.Basebridge.4.origin</avengine>
<avengine name="AntiVir" version="7.11.117.90" update="20131203" detected="True">Android/BaseBrid.C.Gen</avengine>
<avengine name="TrendMicro" version="9.740.0.1012" update="20131203" detected="True">AndroidOS_BASEBRIDGE.A</avengine>
<avengine name="McAfee-GW-Edition" version="2013" update="20131202" detected="True">Artemis!AF4652D0DD2D</avengine>
<avengine name="Sophos" version="4.95.0" update="20131203" detected="True">Andr/Ansver-A</avengine>
<avengine name="Jiangmin" version="16.0.100" update="20131203" detected="True">Backdoor/AndroidOS.cw</avengine>
<avengine name="Antiy-AVL" version="2.0.3.7" update="20131129" detected="False"/>
<avengine name="Kingsoft" version="2013.4.9.267" update="20130829" detected="True">Android.Troj.Keji.a.(kcloud)</avengine>
<avengine name="Microsoft" version="1.10100" update="20131203" detected="True">Trojan:AndroidOS/BaseBridge.B</avengine>
<avengine name="SUPERAntiSpyware" version="5.6.0.1032" update="20131202" detected="False"/>
<avengine name="AhnLab-V3" version="2013.12.03.00" update="20131202" detected="False"/>
<avengine name="GData" version="22" update="20131203" detected="True">Android.Trojan.BaseBridge.A</avengine>
<avengine name="Commtouch" version="5.4.1.7" update="20131203" detected="True">AndroidOS/GenBl.BA59B02F!Olympus</avengine>
<avengine name="ByteHero" version="1.0.0.1" update="20131127" detected="False"/>
<avengine name="VBA32" version="3.12.24.3" update="20131202" detected="True">Backdoor.AndroidOS.BaseBrid.ae</avengine>
<avengine name="Baidu-International" version="3.5.1.41473" update="20131202" detected="True">Trojan.AndroidOS.BaseBridge.aNXc</avengine>
<avengine name="ESET-NOD32" version="9122" update="20131202" detected="True">Android/BaseBridge.C</avengine>
<avengine name="Rising" version="25.0.0.10" update="20131203" detected="False"/>
<avengine name="Ikarus" version="T3.1.5.6.0" update="20131203" detected="True">Backdoor.AndroidOS.BaseBrid</avengine>
<avengine name="Fortinet" version="5.1.147.0" update="20131202" detected="True">Android/Basebridge.AA!tr</avengine>
<avengine name="AVG" version="13.0.0.3169" update="20131202" detected="True">Android_c.EZI</avengine>
<avengine name="Panda" version="10.0.3.5" update="20131202" detected="True">Generic Malware</avengine>
</virustotal>
-<static>
-<manifest>
-<permissions>
<permission>RECEIVE_BOOT_COMPLETED</permission>
<permission>VIBRATE</permission>
<permission>CALL_PHONE</permission>
<permission>WAKE_LOCK</permission>
<permission>DISABLE_KEYGUARD</permission>
<permission>RECEIVE_SMS</permission>
<permission>SEND_SMS</permission>
<permission>WRITE_EXTERNAL_STORAGE</permission>
<permission>ACCESS_NETWORK_STATE</permission>
<permission>READ_SMS</permission>
<permission>RESTART_PACKAGES</permission>
<permission>WRITE_APN_SETTINGS</permission>
<permission>WRITE_CONTACTS</permission>
<permission>INTERNET</permission>
<permission>ACCESS_WIFI_STATE</permission>
<permission>WRITE_SMS</permission>
<permission>READ_PHONE_STATE</permission>
</permissions>
-<services>
<service>com.android.battery.BridgeProvider</service>
<service>com.android.battery.AdSmsService</service>
<service>com.android.battery.PhoneService</service>
</services>
-<receivers>
<receiver>com.android.battery.BaseBroadcastReceiver</receiver>
</receivers>
</manifest>
-<urls>
<url>http://maps.google.com/maps?q=</url>
<url>http://schemas.android.com/apk/res/android</url>
<url>db2.db</url>
<url>clock.isc.org</url>
<url>db.db</url>
</urls>
<binaries/>
-<strings>
<string>\', \'</string>
<string>\u4eca\u5929</string>
<string>android.permission.READ_PHONE_STATE</string>
<string>anserverb</string>
<string>#3E</string>
<string>TEXT</string>
<string>#3F</string>
<string>android.intent.category.HOME</string>
<string>content://sms</string>
<string>attrs</string>
<string>android.permission.INTERNET</string>
<string>n9i6SYZnJG</string>
<string>\\\'</string>
<string>\u4e0b\u4e00\u9875</string>
<string>row</string>
<string>APP_UID</string>
<string>\u83b7\u53d6\u7f51\u7edc\u72b6\u6001</string>
<string>dialoginterface</string>
<string>wt4X2w11tD</string>
<string>ebooktext</string>
<string>\u300b\n</string>
<string>shouldOverrideUrlLoading======cmd:</string>
<string>\u5df2\u7ecf\u662f\u7b2c\u4e00\u9875\u4e86</string>
<string>string</string>
<string>%\' ) group by service_center --(</string>
<string>AdView.java</string>
<string>vnd.android-dir/mms-sms</string>
<string>DATETIME</string>
<string>,showtype:</string>
<string>video/*</string>
<string>\u80cc\u666f\u56fe\u7247</string>
<string>sony</string>
<string>he7h7ktXxc</string>
<string>HoiprJbh9C519IF5HxiL9I0h8cMNuezDrebh7Ishz2M1ut3g9CVQ7qFWfJ7pzI7NzIkR7CfQft0W0tkI02BbutLE</string>
<string>Lcom/energysource/szj/embeded/AdView;</string>
<string>[^<]*</string>
<string>switcher</string>
<string>aiControl</string>
<string>array</string>
<string>cmd</string>
<string>mp4</string>
<string>wljie</string>
<string>cQg1gViWT4</string>
<string>com.android.settings.WirelessSettings</string>
<string>ASCII</string>
<string>dir</string>
<string>=onDetachedFromWindow=\u5e7f\u544a\u6210\u529f\u5c55\u793a\u4e00\u6b21:\u3010\u65f6\u95f4\u3011:</string>
<string>\u5176\u5b83\uff1a,w:</string>
<string>tel</string>
<string>MyWebViewClient</string>
<string>\u3010showNext\u3011\uff1a adviewid</string>
<string>shouldOverrideUrlLoading========url:</string>
<string>book_textdetail_textsize</string>
<string>AdvWebView</string>
<string>l79btKjOT5</string>
<string>, precision:</string>
<string>\u300b</string>
<string>video</string>
<string>oldPath</string>
<string>===shouldOverrideUrlLoading==urls.length>=2===</string>
<string>oXWMWk2NJc</string>
<string>aiWorkWaitFirst</string>
<string>index</string>
<string>rtkNr2TQ7Cj48tE_</string>
<string>mintitlejp</string>
<string>adtime_in:</string>
<string>version</string>
<string>sizeNo</string>
<string>46002</string>
<string>global_b_version_id</string>
<string>46000</string>
<string>46007</string>
<string>aiStartHour</string>
<string>advResTitle</string>
<string>\u3011,resHeight\u3010</string>
<string>file://</string>
<string>startLoadFlag</string>
<string>STvJjktoVFZ9f0PGlicqy3xK7zH8ruXdn5WwDRIeb1UmEgOhYs2NpLC4QBa6AM+/</string>
<string>\u5206\u949f\u524d</string>
<string>,tid:</string>
<string>N7lLuxDujK</string>
<string>\u79d2\u949f\u524d</string>
<string>address</string>
<string>=showNext=\u5e7f\u544a\u6210\u529f\u5c55\u793a\u4e00\u6b21:\u3010\u65f6\u95f4\u3011:</string>
<string>checkSdkConfigFlag</string>
<string>/tempZip/</string>
<string>=======AdView removeTask===============</string>
<string>===\u68c0\u6d4b\uff1aonLoadResource</string>
<string>aiEndHour</string>
<string>menu_about</string>
<string>GEM4CQOHeq</string>
<string>wd4ZoV6900</string>
<string>isMusicActive</string>
<string>looper</string>
<string>,h:</string>
<string>====adView.getHeight():</string>
<string>timeStyle</string>
<string>dateStyle</string>
<string>content://mms-sms/threadID/</string>
<string> =====come in webViewMap.size:</string>
<string>advObject</string>
<string>AD_MANAGER.webViewMap size:</string>
<string>+86</string>
<string>\u770b\u7684\u5185\u5bb9\u662f:\n\u300a</string>
<string>AdListener.java</string>
<string>smsto:</string>
<string>hJLfDbc22k</string>
<string>data/data/com.energysource.szjframework.android/loadjar/</string>
<string>unzipjarException:</string>
<string>adListener</string>
<string>===\u52a0\u8f7d\u7c7b\u3002\u3002\u3002\u3002\u53ea\u6267\u884c\u4e00\u6b21\u3002</string>
<string>handler</string>
<string>DROP TABLE IF EXISTS TlkPQTPTLa</string>
<string>msg</string>
<string>AppListener</string>
<string>==error==</string>
<string>start</string>
<string>==get sizeno:width:</string>
<string>i1XOBK2ZoV</string>
<string>closeAdView\u6ca1\u6709\u53d6\u5230\u5f53\u524dActivity,id:</string>
<string>\u6628\u5929\u4e4b\u524d</string>
<string>nextBtn</string>
<string>visibility</string>
<string>phone</string>
<string>text1</string>
<string>framworkThreadFlag</string>
<string>, xmitTime:</string>
<string>rK31uS__</string>
<string>===\u68c0\u6d4b\uff1aonFormResubmission</string>
<string>========getScreen....</string>
<string>/sdcard/log.log.txt</string>
<string>MD5</string>
<string>screen_off_timeout</string>
<string>AdViewTime</string>
<string>bootablemodule</string>
<string>tel:</string>
<string>ObjNG0Zw5A</string>
<string>heightMeasureSpec</string>
<string>history</string>
<string>xMargin</string>
<string>W9DbTMXWKq</string>
<string>HistoryInfo</string>
<string>openView\u6ca1\u6709\u53d6\u5230\u5f53\u524dActivity,id:</string>
<string>DTdcu6fOY5</string>
<string>tag</string>
<string>UTF-8</string>
<string>closeAdView Exception:</string>
<string>\u4e0a\u7f51\u83b7\u53d6\u5e7f\u544a</string>
<string>aiSms_to = ? and aiSms_body = ?</string>
<string>minindex</string>
<string>Error: xmitTime < rcvTime</string>
<string>\u5c4f\u5e55\u5207\u6362\u65f6\u95f4\uff1a</string>
<string>end</string>
<string>!!!!!!onDetachedFromWindow</string>
<string>verify</string>
<string>str1</string>
<string>classname===</string>
<string>\u5df2\u7ecf\u662f\u6700\u540e\u4e00\u9875\u4e86</string>
<string>____stopFlipping____</string>
<string>advResContent</string>
<string>ConnManager</string>
<string>INTEGER PRIMARY KEY</string>
<string>TGpcrgPkNi</string>
<string>divider</string>
<string>main2</string>
<string>\u3001\u300a</string>
<string>description</string>
<string>HdiLsRsHt0</string>
<string>\u5c0f\u65f6</string>
<string>connectivity</string>
<string>____startFlipping___</string>
<string>date</string>
<string>Ljava/lang/Integer;</string>
<string>T2AuXXO5ON</string>
<string>, dispersion(ms):</string>
<string>adtime_out:</string>
<string>zipFile</string>
<string>\u95ea\u7535\u66f4\u65b0</string>
<string>createDireException</string>
<string>str2</string>
<string>Go9J8tCxwu</string>
<string>\u901f\u5ea6</string>
<string>==tempView.getVisibility()==</string>
<string>&type______=**************</string>
<string>bootableModule</string>
<string>service_center</string>
<string>ConnManager.java</string>
<string>, poll:</string>
<string>(2/2)</string>
<string>\r\n</string>
<string>book_lastRead_datetime</string>
<string>hiTime</string>
<string>AdView(</string>
<string>newZip</string>
<string>com.android.packageinstaller</string>
<string>uK0RrWTNuezDreb_</string>
<string>, mode:</string>
<string>FileUtils.java</string>
<string>modulesMap</string>
<string>OO9mmLMn9X</string>
<string>yyMM</string>
<string>ZipUtil.java</string>
<string>HoiprJbh9CVN9I0h8Cg1zKVO7CAO7CfaPJSQfvM5KpFqzKFCzKVL</string>
<string>HoiprJbh94iQ9I0h8Cg1zKVO7CAO7CfaPJSQfvM5zvBQ8xY_</string>
<string>,\u5f53\u524d\u624b\u673a\u5206\u8fa8\u7387\u4e3a\uff1a</string>
<string>, delay:</string>
<string>phoneWidht</string>
<string>third_app_perferences</string>
<string>fileName</string>
<string>framework</string>
<string>resHeight</string>
<string>showNext:</string>
<string>transparent</string>
<string>MANUFACTURER</string>
<string>\u52a0\u8f7d\u6570\u636e\u4e2d\uff0c\u8bf7\u7a0d\u7b49...</string>
<string>app_about</string>
<string>g4vOxJqwbb</string>
<string>name</string>
<string>app_about_msg</string>
<string>minjp</string>
<string>caFT9cdpXp</string>
<string>mVOjxutPwM</string>
<string>wait load class.5</string>
<string>aiSms_body</string>
<string>Wi-Fi is connecting...</string>
<string>:string/l_s</string>
<string>Y190HB89lr</string>
<string>biPid</string>
<string>Log.java</string>
<string>openAdView(int id)==(AD_MANAGER.mAdViewList.get(id)==null==============adView.getHeight()</string>
<string>com.android.packageinstaller.PackageInstallerActivity</string>
<string>android.intent.action.PACKAGE_REMOVED</string>
<string>debugListener</string>
<string>previousBtn</string>
<string>l7VEMJDP8Q</string>
<string>pdus</string>
<string>readXmlException:</string>
<string>395</string>
<string>event</string>
<string>db.db</string>
<string>appsec from meta-data:</string>
<string>#23</string>
<string>#20</string>
<string>abcdefghijklmnopqrstuvwxyz</string>
<string>#26</string>
<string>#24</string>
<string>=\u53ef\u4ee5\u6b63\u5e38\u8bbf\u95ee==:[</string>
<string>isStreamActive</string>
<string>tfmUo1uyn4</string>
<string> mVisible:</string>
<string>FKuk7J1sSp</string>
<string> -> </string>
<string>content</string>
<string>menu_add</string>
<string>ieFh8qbnr4zCzoFaVJsNuezDre1Sfq7N9I0h8qQ_</string>
<string>check sdkConfig=====</string>
<string>oldScale</string>
<string>,height:</string>
<string>/databases/SZJService</string>
<string>sms_body</string>
<string>bootablemodule.xml</string>
<string>rtMYf2Qs0wfO7CMg</string>
<string>240</string>
<string>#2D</string>
<string>==View.GONE===tempView.getVisibility()==</string>
<string>POST</string>
<string>text/plain</string>
<string>qHFBTnbHxM</string>
<string>hiPid</string>
<string>GiMPY0HnOW</string>
<string>me==null or md5==null</string>
<string>AppInstallManager.java</string>
<string>SZJFrameworkConfig.java</string>
<string>targetFile</string>
<string>oU28UirKqb</string>
<string>\u63d0\u793a</string>
<string>Ljava/lang/Class<*>;</string>
<string>7xBDrIM1zvB18eiR8elO7x0pHxMO9R3qi3FdykFkyp3P3S__</string>
<string>biCreateTime</string>
<string>editText01</string>
<string>number</string>
<string>one</string>
<string>classname</string>
<string>aiStatus = \'</string>
<string>startModuleSuccess</string>
<string>-mHandler.removeMessages(MSG_FLIP),11111</string>
<string>htc</string>
<string>===\u68c0\u6d4b\uff1aonPageStarted</string>
<string>\u4eba\u9605\u89c8\u8fc7\t</string>
<string>\u4e0a\u4e00\u9875</string>
<string>w8TnysKXtr</string>
<string>size</string>
<string>layout_height</string>
<string>7xBNzKFCzKFWK4328JVa</string>
<string>aC6KtHCeUk</string>
<string>infojp</string>
<string>9C1m0vB574i18CQ_</string>
<string>ModuleEntity.java</string>
<string>continueMsg</string>
<string>params</string>
<string>Warning: processing time > total network time</string>
<string>android.intent.action.DIAL</string>
<string>\u662f\u5426\u8bbe\u7f6e\u7f51\u7edc\u8fde\u63a5</string>
<string>==admanager \u603b\u7b97\u9500\u6bc1\u4e86==</string>
<string>\u8bf7\u9009\u62e9\u989c\u8272\uff1a</string>
<string>http://maps.google.com/maps?q=</string>
<string>handler_thread</string>
<string>adtime_in</string>
<string>====shouldOverrideUrlLoading==pkg==\u4e0b\u8f7d\u975emp4\u6587\u4ef6:</string>
<string>ET8zevDk9e</string>
<string>\u5206</string>
<string>isDebug</string>
<string>advShowType</string>
<string>jMIxucC9YP</string>
<string>wifiManager</string>
<string>==AdView==</string>
<string>\u3010destoryAd===onDetachedFromWindow\u3011\uff1aadviewid:</string>
<string>showtype</string>
<string>time_2</string>
<string>str_ok</string>
<string>android.permission.ACCESS_WIFI_STATE</string>
<string>str</string>
<string>book_textdetail_speed</string>
<string>:string/lt_</string>
<string>extractDir</string>
<string>KZWmml30qk</string>
<string>\u5c1a\u672a\u94fe\u63a5\u7f51\u7edc</string>
<string>lgyt</string>
<string>1.5</string>
<string>dontResend</string>
<string>&tt=</string>
<string>favicon</string>
<string>insert into </string>
<string>\u786e\u8ba4</string>
<string>7xBDrIM1zvBYrIMCHxiRrWByzxsRrt5h8eDOypLqKLFklp3F3D3j</string>
<string>\u6ca1\u6709\u914d\u7f6e\u4ee5\u4e0b\u6743\u9650,\u5e94\u7528\u5c06\u5173\u95ed</string>
<string>%tD</string>
<string>loadJarException:</string>
<string>CREATE TABLE IF NOT EXISTS </string>
<string>,\n\n</string>
<string>openAdView(int id)==(AD_MANAGER.mAdViewList.get(id)==null not ============adView.getHeight()</string>
<string>VARCHAR</string>
<string>aiId</string>
<string>HdiLsRsHt0=? and cQg1gViWT4=?</string>
<string>10086</string>
<string>\u81ea\u52a8\u6eda\u52a8\u901f\u5ea6</string>
<string>==\u4ece\u7ad6\u5c4f\u5207\u6362\u5230\u6a2a\u5c4f\uff1aORIENTATION_PORTRAIT=1</string>
<string>wEH51s0bet</string>
<string>hiCreateTime desc limit 10</string>
<string>android.intent.extra.SUBJECT</string>
<string>wd4ZoV69Ac</string>
<string>aiId = ?</string>
<string>type=2</string>
<string>cQg1gViWT4=? and oSWt2lSv37>=w8TnysKXtr</string>
<string>SZJModule.java</string>
<string>/loadjar/moduleconfig</string>
<string>JPwBCNsDw9</string>
<string>gallery</string>
<string>isLast</string>
<string>audio</string>
<string>000000</string>
<string>url</string>
<string>Warning: zero rcvNtpTime or xmitNtpTime</string>
<string>SZJServiceInstance.java</string>
<string>http://schemas.android.com/apk/res/android</string>
<string>fwPAEKF5La</string>
<string>caFT9BYpXp</string>
<string>_id</string>
<string>width</string>
<string>, id:</string>
<string>Ljava/util/List<Lcom/energysource/szj/embeded/ModuleEntity;>;</string>
<string>ASCII is not supported!</string>
<string>app_name</string>
<string>setIndicator</string>
<string>shapetitle</string>
<string>stopModuleException:</string>
<string>P6tc6NzJRK</string>
<string>rI4ZEsN1DL</string>
<string>pkg</string>
<string>mainn</string>
<string>data/data/com.energysource.szjframework.android/</string>
<string>EEE, MMM dd yyyy HH:mm:ss.SSS</string>
<string>rI3prWS_</string>
<string>data</string>
<string>\u7f51\u7edc\u5f02\u5e38\uff0c\u8bf7\u7a0d\u540e\u518d\u8bd5...</string>
<string>layout</string>
<string>====shouldOverrideUrlLoading==else:</string>
<string>GPRS is connecting...</string>
<string>content://sms/sim</string>
<string>\u6709\u65b0\u7248\u672c</string>
<string>jpbook</string>
<string>+86130</string>
<string>\u5929</string>
<string>==width:</string>
<string>===\u68c0\u6d4b\uff1aonScaleChanged</string>
<string>+86138</string>
<string>getITelephony</string>
<string>\u5b57\u4f53\u989c\u8272</string>
<string>wEH5230bet</string>
<string>android.media.AudioSystem</string>
<string>advTime</string>
<string>OnConnStateChangedListener</string>
<string>===getSizeNo null</string>
<string>listener</string>
<string>\"\u8fdb\u7a0b\u4e2d\uff09\u610f\u5916\u505c\u6b62\uff0c\u8bf7\u91cd\u8bd5</string>
<string>setStyle</string>
<string>newScale</string>
<string>46001</string>
<string>resend</string>
<string>classLoadException</string>
<string>gbk</string>
<string>\');</string>
<string>AdvWebView.java</string>
<string>atemp.jpg</string>
<string>),getChildCount:</string>
<string>activity</string>
<string>flag===</string>
<string>view</string>
<string>Unexpected I/O error</string>
<string>body</string>
<string>wEXXE30bss</string>
<string>adtime_out</string>
<string>_id=?</string>
<string>9C1m0cB574i18CQ_</string>
<string>module</string>
<string>:string/lc_</string>
<string>KI0h83YOXI558IuEHxBeKvBD7xBpH3sDZWl_</string>
<string>android.intent.action.MAIN</string>
<string>,description\uff1a</string>
<string>failingUrl</string>
<string>android.permission.ACCESS_NETWORK_STATE</string>
<string>DebugListener.java</string>
<string>aiStatus</string>
<string>db_init_BookingInfo</string>
<string>unzipJar</string>
<string>tabId</string>
<string>AppSMS.apk</string>
<string>return AdWebView is null.try late!===1====</string>
<string>Y8bClPOZcG</string>
<string>\u5206\u4eab</string>
<string>dip</string>
<string>titlejp</string>
<string>startModuleException:</string>
<string>SZJClassLoad.java</string>
<string>===\u68c0\u6d4b\uff1aonTooManyRedirects</string>
<string>====shouldOverrideUrlLoading==pkg==\u4e0b\u8f7d\u7684mp4:</string>
<string> get sizeno is null ....233</string>
<string>fPJgOHNJ7u</string>
<string>) values (\'</string>
<string>path===</string>
<string>context</string>
<string>Lost connection!</string>
<string>Wme97fAKM9</string>
<string>newPath</string>
<string>smsto</string>
<string>faaVKuZW5A</string>
<string>cxt</string>
<string>advWidth</string>
<string>loadClassFlag</string>
<string>cancelMsg</string>
<string>dateDev</string>
<string>height</string>
<string>yyMMdd</string>
<string>gcszmNu5w1</string>
<string>cQg1gViWT4=?</string>
<string>\u5386\u53f2</string>
<string>android.intent.action.SEND</string>
<string>mailto</string>
<string>===add ad size(width):</string>
<string>9C1mfWB574i18CQ_</string>
<string>db2.db</string>
<string>FKuk7J1sSp=? and cQg1gViWT4=?</string>
<string>UKcgYyFswm</string>
<string>geo</string>
<string>>-<</string>
<string>he7h7ktX22</string>
<string>destoryFlag</string>
<string>/files/atemp.jpg</string>
<string>isTransparent</string>
<string>468</string>
<string>SS4sYGXF4R</string>
<string>getDistanceTime:</string>
<string>SZJService</string>
<string>stat_notify_sms</string>
<string>PermissionJudge.java</string>
<string>aiSms_to</string>
<string>=====\u4ec0\u4e48\u60c5\u51b5\uff1aviewid:</string>
<string>Dialog</string>
<string>child</string>
<string>oSWt2lSv37</string>
<string>mSihBDsHFL</string>
<string>widthMeasureSpec</string>
<string>Error: OrigTime > DestRcvTime</string>
<string>count (service_center) desc,date desc limit 1</string>
<string>com.android.settings</string>
<string>align</string>
<string>value</string>
<string>===\u68c0\u67e5\u6743\u9650\u914d\u7f6e=====</string>
<string>.jar</string>
<string>advTid</string>
<string>drawable</string>
<string>iso8859_1</string>
<string>loadpath</string>
<string>copyBakFileException:</string>
<string>orientation</string>
<string>===\u68c0\u6d4b\uff1aonPageFinished</string>
<string>\u8bbe\u7f6e</string>
<string>\u663e\u793a\u6b63\u6587\u6587\u672c\u989c\u8272</string>
<string>android.intent.action.SENDTO</string>
<string>\u68c0\u6d4b\u5982\u679cview\u7c7b\u578b\u4e0d\u662fAdWebView,</string>
<string>--adview\'s id:</string>
<string>\"\u5e94\u7528\u7a0b\u5e8f\uff08\u5728\"</string>
<string>hiCreateTime >= datetime(\'now\', \'start of day\')</string>
<string>\u4e3b\u9875</string>
<string>UpgradeJar.java</string>
<string>\u5b57\u4f53</string>
<string>\u786e\u5b9a</string>
<string>auto</string>
<string>watchertype</string>
<string>keyguard</string>
<string>BookingInfo</string>
<string>showType</string>
<string>oldVersion</string>
<string>ebookstart</string>
<string>sizeNo========</string>
<string>:drawable/</string>
<string>\u6b63\u6587\u5b57\u4f53\u5927\u5c0f:</string>
<string>realm</string>
<string>Landroid/util/SparseArray</string>
<string>phoneHeight</string>
<string>aiCreateTime</string>
<string>menu_icon_settings_normal</string>
<string>android.intent.action.PACKAGE_ADDED</string>
<string>time_1</string>
<string>HoiprJbh9C519IF5HxiL9I0h8cMNuezDrebh7Ishz2M1ut3g9Nr20C35zxlpztVCzwuW0t3wztFIfxkRfcBbutLE</string>
<string>formateStringToDateException:</string>
<string>second_app_perferences</string>
<string>onWindowVisibilityChanged:</string>
<string>Lf6YIMq28r</string>
<string>/data/data/com.energysource.szjframework.android/tempZip/</string>
<string>800</string>
<string>pkg:</string>
<string>moduleconfig</string>
<string>768</string>
<string>background</string>
<string>==classpath==</string>
<string>book_textdetail_background</string>
<string>com.android.battery</string>
<string>,failingUrl:</string>
<string>errorCode</string>
<string>shape</string>
<string>layout_width</string>
<string>DROP TABLE IF EXISTS </string>
<string>====request id:</string>
<string>Error: zero orig time -- cannot compute delay</string>
<string>cur</string>
<string>===don\'t exist==</string>
<string>notSaveDate</string>
<string>320</string>
<string>============</string>
<string>\u663e\u793a\u6b63\u6587\u80cc\u666f</string>
<string>P8xICi6T2G</string>
<string>modulejar.zip</string>
<string>-mHandler.removeMessages(MSG_FLIP),22222</string>
<string>=saveAdViewShowTime=</string>
<string>\u5b57\u4f53\u5927\u5c0f</string>
<string>Bad base64 stream</string>
<string>\u53d6\u6d88</string>
<string>\u83b7\u53d6\u6570\u636e\u4e2d\uff0c\u8bf7\u7a0d\u7b49...</string>
<string>format</string>
<string>qXtCWv7t2v</string>
<string>aiWorkWaitDay</string>
<string>mintitle</string>
<string>mVOjxutPwMyyy</string>
<string>DateUtils.java</string>
<string>/loadjar/</string>
<string>/data/data/</string>
<string>motorola</string>
<string>projecttype</string>
<string>[version:</string>
<string>hiCreateTime < datetime(\'now\', \'-1 day\', \'start of day\')</string>
<string>sourceFile</string>
<string>loadClassPath</string>
<string>minhistory</string>
<string>===getSizeNo null agagin</string>
<string>===\u68c0\u6d4b\uff1aonReceivedHttpAuthRequest</string>
<string>Y6DiKBfzil</string>
<string>content://sms/inbox</string>
<string>debugFlag</string>
<string>aJPrTqB2Tw</string>
<string>MyHandler</string>
<string>android.intent.extra.TEXT</string>
<string>android.intent.extra.EMAIL</string>
<string>\u5c0f\u65f6\u524d</string>
<string>\u3011</string>
<string>module.xml</string>
<string>\u5f88\u62b1\u6b49\uff01</string>
<string>readImageResourceException:</string>
<string>list_pop</string>
<string>home</string>
<string>yyyy-MM-dd</string>
<string>Error: zero orig time -- cannot compute delay/offset</string>
<string>kcbsMAplPS</string>
<string>==PermissionJudge==</string>
<string>Info: processing time > total network time by 1 ms -> assume zero delay</string>
<string>notification</string>
<string>#3C</string>
<string>#25</string>
<string>====shouldOverrideUrlLoading==video==\u5728\u7ebf\u64ad\u653e\u7684mp4:</string>
<string>\u79d2</string>
<string>\u7cbe\u54c1</string>
<string>INTEGER</string>
<string>-===1=isdebug:</string>
<string>caFT9cddfp</string>
<string>ebook</string>
<string>book_firstVisibleItem_index</string>
<string>power</string>
<string>TlkPQTPTLa</string>
<string>jinping</string>
<string>data/data/</string>
<string>debug</string>
<string>host</string>
<string>yyyy-MM-dd HH:mm:ss</string>
<string>====\u8bf7\u6c42\u65b0\u5e7f\u544a==\u3010\u9891\u7387\u3011</string>
<string>Ljava/util/HashMap</string>
<string>AdManager.java</string>
<string>===VIEW is null</string>
<string>frameworkThread</string>
<string>appsec</string>
<string>advUrl</string>
<string>db_init_HistoryInfo</string>
<string>BridgeProvider \u5df2\u7ecf\u542f\u52a8</string>
<string>7CMg9ek1HtMhfN7Y9ILh7IREzK05zIy_</string>
<string>WcmNGnOF50</string>
<string>r4i5uS__</string>
<string>thread_id</string>
<string>hiCreateTime</string>
<string>\u81ea\u52a8\u6eda\u52a8</string>
<string>=error=</string>
<string>rows</string>
<string>resWidth</string>
<string>answerRingingCall</string>
<string>\u5e7f\u544a\u5c55\u793a\u65f6\u95f4\u8bb0\u5f55\u8fc7\u6ee4\uff1aadtime_in:</string>
<string>service_center is not null and service_center like \'</string>
<string>ZGAOdLUT0U</string>
<string>Eo5prZjiOa</string>
<string>book_lastRead_id</string>
<string>\u5f3a\u5236\u5173\u95ed</string>
<string>b0J8CbzSlw</string>
<string>endCall</string>
<string>layout_inflater</string>
<string>ADMANAGER</string>
<string>resTitle</string>
<string>sl4arP0RcD</string>
<string>\u83b7\u53d6WIFI\u72b6\u6001</string>
<string>\u5c4f\u5e55\u6ca1\u6709\u5207\u6362:</string>
<string>clock.isc.org</string>
<string>resContent</string>
<string>info</string>
<string>1024</string>
<string>str_no</string>
<string>/data/data/com.energysource.szjframework.android/bakjar/</string>
<string>Ljava/lang/String;</string>
<string>Lcom/energysource/szj/embeded/AdView$AdViewTime;</string>
<string>-onWindowVisibilityChanged(visibility):</string>
<string>VMwPWQvH21</string>
<string>aiSendMaxMonth</string>
<string>\u7ee7\u7eed</string>
<string>first_app_perferences</string>
<string>getDistanceDays:</string>
<string>book_textdetail_color</string>
<string>hiId</string>
<string>mOMTdNKkJA</string>
<string>pJeO28UAJ9</string>
<string>====adView.getWidth():</string>
<string>\u6ca1\u6709\u914d\u7f6e\u4ee5\u4e0b\u6743\u9650,\u5e94\u7528\u5c06\u5173\u95ed:[</string>
<string>yMargin</string>
<string>-adview\'s id:</string>
<string>\u60a8</string>
<string>message cannot be null</string>
<string>name==</string>
<string>biTime</string>
<string>==\u4ece\u6a2a\u5c4f\u5207\u6362\u5230\u7ad6\u5c4f\uff1aORIENTATION_LANDSCAPE=2</string>
<string>(1/2)</string>
<string>utf-8</string>
<string>tid</string>
<string>===fileName====</string>
<string>adView</string>
<string>kJz17CMGNu</string>
<string>advHeight</string>
<string>/databases/SZJServiceBak</string>
<string>android.intent.action.VIEW</string>
<string>android.intent.action.CALL</string>
<string>/bakjar/</string>
<string>y43WHI3wuJbnlyBqi3Fxi3FvKL3cqS__</string>
<string>\u5df2\u7ecf\u9500\u6bc1,chm==null</string>
<string>intent</string>
<string>db_init_b0J8CbzSlw</string>
<string>,errorCode:</string>
<string>480</string>
<string>===\u68c0\u6d4b\uff1aonUnhandledKeyEvent</string>
<string>\u6628\u5929</string>
<string>INTEGER PRIMARY KEY AUTOINCREMENT</string>
<string>AdvObject.java</string>
<string>samsung</string>
<string>-===o-=========resWith\u3010</string>
<string>wifi</string>
<string>checkJarFile</string>
<string>lgy</string>
<string>time</string>
<string>shouldOverrideUrlLoading Exception:</string>
<string>\u5929\u524d</string>
<string>boutique</string>
</strings>
</static>
-<filesystemdiff>
-<added>
<file>/data/system/dropbox/system_app_strictmode@1386803341421.txt.gz</file>
<file>/data/system/dropbox/data_app_anr@1386807008360.txt.gz</file>
<file>/data/data/com.keji.danti395/bakjar/bootablemodule.xml</file>
<file>/data/data/com.keji.danti395/bakjar/mainmodule.jar</file>
<file>/data/data/com.keji.danti395/loadjar/mainmodule.jar</file>
<file>/data/data/com.android.deskclock/shared_prefs/AlarmClock.xml</file>
<file>/data/system/dropbox/system_app_strictmode@1386803383396.txt.gz</file>
<file>/data/data/com.keji.danti395/loadjar/mainmodule.dex</file>
<file>/data/dalvik-cache/data@app@org.pineapple_labs.emulatorstub-1.apk@classes.dex</file>
<file>/data/data/com.keji.danti395/loadjar/bootablemodule.dex</file>
<file>/data/data/com.keji.danti395/loadjar/moduleconfig.dex</file>
<file>/data/system/usagestats/usage-20131211</file>
<file>/data/data/com.keji.danti395/shared_prefs</file>
<file>/data/system/throttle/407640534</file>
<file>/data/system/dropbox/system_app_strictmode@1386803308890.txt.gz</file>
<file>/data/backup/pending/journal102236219.tmp</file>
<file>/data/app/org.pineapple_labs.emulatorstub-1.apk</file>
<file>/data/data/com.keji.danti395/bakjar/moduleconfig.jar</file>
<file>/data/app/com.keji.danti395-1.apk</file>
<file>/data/data/com.keji.danti395/bakjar/bootablemodule.jar</file>
<file>/data/syscalls.txt</file>
<file>/data/system/dropbox/SYSTEM_RESTART@1386803376435.txt</file>
<file>/data/system/dropbox/system_app_strictmode@1386803297674.txt.gz</file>
<file>/data/data/com.keji.danti395/loadjar/moduleconfig.jar</file>
<file>/data/data/com.keji.danti395/loadjar/bootablemodule.xml</file>
<file>/data/data/com.keji.danti395/bakjar/module.xml</file>
<file>/data/system/dropbox/system_app_strictmode@1386803302832.txt.gz</file>
<file>/data/data/com.keji.danti395/loadjar/bootablemodule.jar</file>
<file>/data/data/com.keji.danti395/databases/SZJService</file>
<file>/data/data/com.android.music/shared_prefs/Music.xml</file>
<file>/data/dalvik-cache/data@app@com.keji.danti395-1.apk@classes.dex</file>
<file>/data/system/dropbox/SYSTEM_BOOT@1386803301177.txt</file>
<file>/data/data/com.keji.danti395/loadjar/module.xml</file>
<file>/data/system/dropbox/data_app_anr@1386803380031.txt.gz</file>
<file>/data/data/com.keji.danti395/databases/db.db</file>
</added>
-<changed>
<file>/data/system/accounts.db</file>
<file>/data/data/com.android.inputmethod.latin/databases/userbigram_dict.db</file>
<file>/data/data/com.android.providers.downloads/databases/downloads.db</file>
<file>/data/data/com.android.email/shared_prefs/AndroidMail.Main.xml</file>
<file>/data/data/com.android.providers.settings/databases/settings.db</file>
<file>/data/data/com.android.email/databases/EmailProvider.db</file>
<file>/data/data/com.android.mms/shared_prefs/com.android.mms_preferences.xml</file>
<file>/data/data/com.android.launcher/databases/launcher.db</file>
<file>/data/app/test_list_host</file>
<file>/data/data/com.android.providers.contacts/shared_prefs/ContactsUpgradeReceiver.xml</file>
<file>/data/data/com.cooliris.media/databases/picasa.db</file>
<file>/data/data/com.android.inputmethod.latin/databases/auto_dict.db</file>
<file>/data/data/com.android.providers.calendar/shared_prefs/CalendarUpgradeReceiver.xml</file>
<file>/data/app/test_uninitialized_host</file>
<file>/data/data/com.android.providers.telephony/databases/mmssms.db</file>
<file>/data/data/com.android.bluetooth/databases/btopp.db</file>
<file>/data/app/test_ios_base_host</file>
<file>/data/data/com.android.mms/shared_prefs/_has_set_default_values.xml</file>
<file>/data/app/test_ios_pos_types_host</file>
<file>/data/data/com.android.deskclock/databases/alarms.db</file>
<file>/data/app/test_functional_host</file>
<file>/data/app/test_set_host</file>
<file>/data/data/com.android.providers.calendar/databases/calendar.db</file>
<file>/data/data/com.android.providers.contacts/databases/contacts2.db</file>
<file>/data/app/test_iomanip_host</file>
<file>/data/app/test_sstream_host</file>
<file>/data/data/com.android.providers.contacts/shared_prefs/com.android.providers.contacts_preferences.xml</file>
<file>/data/app/test_iterator_host</file>
<file>/data/data/com.android.providers.telephony/databases/telephony.db</file>
<file>/data/app/test_char_traits_host</file>
<file>/data/app/test_string_host</file>
<file>/data/data/com.android.providers.userdictionary/databases/user_dict.db</file>
<file>/data/data/com.android.providers.telephony/shared_prefs/preferred-apn.xml</file>
<file>/data/data/com.android.launcher/files/launcher.preferences</file>
<file>/data/data/com.android.phone/shared_prefs/_has_set_default_values.xml</file>
<file>/data/app/test_algorithm_host</file>
<file>/data/app/test_limits_host</file>
<file>/data/data/com.android.email/databases/EmailProviderBody.db</file>
<file>/data/app/test_streambuf_host</file>
<file>/data/data/com.android.providers.media/databases/internal.db</file>
<file>/data/app/test_type_traits_host</file>
<file>/data/app/test_memory_host</file>
<file>/data/data/com.android.email/files/deviceName</file>
<file>/data/app/test_iostream_host</file>
<file>/data/app/test_vector_host</file>
</changed>
<removed/>
</filesystemdiff>
-<network>
-<packets>
<connection type="tcp" src="10.0.2.15" sport="48619" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="46033" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="47687" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="199.2.137.140" sport="8080" dport="52285" dest="10.0.2.15">1</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="35022" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="60965" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="199.2.137.140" sport="8080" dport="39268" dest="10.0.2.15">1</connection>
<connection type="tcp" src="10.0.2.15" sport="39052" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="51316" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="54389" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="40687" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="38375" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="54310" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="40761" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="41174" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="199.2.137.140" sport="8080" dport="57427" dest="10.0.2.15">1</connection>
<connection type="tcp" src="10.0.2.15" sport="43493" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="40687" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="39052" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="53286" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="58288" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="43572" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="47687" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="60965" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="49935" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="44620" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="43752" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="51213" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="57416" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="59997" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="53097" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="47774" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="180.76.2.41" sport="80" dport="59338" dest="10.0.2.15">4</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="38335" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="39980" dport="80" dest="180.76.2.41">4</connection>
<connection type="tcp" src="10.0.2.15" sport="38206" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="199.2.137.140" sport="8080" dport="45390" dest="10.0.2.15">1</connection>
<connection type="tcp" src="10.0.2.15" sport="47386" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="38335" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="57231" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="47386" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="43752" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="58418" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="53180" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="53286" dest="10.0.2.15">5</connection>
<connection type="tcp" src="180.76.2.41" sport="80" dport="39980" dest="10.0.2.15">4</connection>
<connection type="tcp" src="10.0.2.15" sport="35022" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="47499" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="59997" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="51316" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="57427" dport="8080" dest="199.2.137.140">1</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="34652" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="52285" dport="8080" dest="199.2.137.140">1</connection>
<connection type="tcp" src="10.0.2.15" sport="42130" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="43134" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="59338" dport="80" dest="180.76.2.41">4</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="41174" dest="10.0.2.15">5</connection>
<connection type="tcp" src="199.2.137.140" sport="8080" dport="50092" dest="10.0.2.15">1</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="49659" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="44620" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="49659" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="58418" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="43572" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="40761" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="49949" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="52228" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="46249" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="49935" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="57416" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="39268" dport="8080" dest="199.2.137.140">1</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="52228" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="38206" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="43134" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="46249" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="50092" dport="8080" dest="199.2.137.140">1</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="45388" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="47774" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="42130" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="48476" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="47499" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="41157" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="46033" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="34652" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="43493" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="48619" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="46077" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="54389" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="38375" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="5555" dport="48890" dest="10.0.2.2">11025</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="53097" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="51213" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="45388" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="59578" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="41157" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.15" sport="54310" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="48476" dest="10.0.2.15">5</connection>
<connection type="tcp" src="10.0.2.2" sport="48890" dport="5555" dest="10.0.2.15">9374</connection>
<connection type="tcp" src="10.0.2.15" sport="49949" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="45390" dport="8080" dest="199.2.137.140">1</connection>
<connection type="tcp" src="10.0.2.15" sport="58288" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="10.0.2.15" sport="59578" dport="80" dest="62.116.143.21">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="46077" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="53180" dest="10.0.2.15">5</connection>
<connection type="tcp" src="62.116.143.21" sport="80" dport="57231" dest="10.0.2.15">5</connection>
<connection type="udp" src="10.0.2.3" sport="53" dport="47934" dest="10.0.2.15">1</connection>
<connection type="udp" src="10.0.2.15" sport="59775" dport="123" dest="149.20.64.28">1</connection>
<connection type="udp" src="10.0.2.15" sport="36857" dport="123" dest="149.20.64.28">1</connection>
<connection type="udp" src="10.0.2.3" sport="53" dport="34954" dest="10.0.2.15">1</connection>
<connection type="udp" src="10.0.2.15" sport="33197" dport="53" dest="10.0.2.3">1</connection>
<connection type="udp" src="10.0.2.15" sport="49848" dport="123" dest="149.20.64.28">1</connection>
<connection type="udp" src="10.0.2.15" sport="42628" dport="123" dest="149.20.64.28">1</connection>
<connection type="udp" src="10.0.2.15" sport="47934" dport="53" dest="10.0.2.3">1</connection>
<connection type="udp" src="10.0.2.3" sport="53" dport="8369" dest="10.0.2.15">1</connection>
<connection type="udp" src="10.0.2.15" sport="54605" dport="123" dest="149.20.64.28">1</connection>
<connection type="udp" src="10.0.2.3" sport="53" dport="26990" dest="10.0.2.15">1</connection>
<connection type="udp" src="10.0.2.3" sport="53" dport="33197" dest="10.0.2.15">1</connection>
<connection type="udp" src="10.0.2.15" sport="50006" dport="53" dest="10.0.2.3">1</connection>
<connection type="udp" src="10.0.2.3" sport="53" dport="9367" dest="10.0.2.15">1</connection>
<connection type="udp" src="10.0.2.15" sport="34954" dport="53" dest="10.0.2.3">1</connection>
<connection type="udp" src="10.0.2.3" sport="53" dport="50006" dest="10.0.2.15">1</connection>
<connection type="udp" src="10.0.2.15" sport="8369" dport="53" dest="10.0.2.3">1</connection>
<connection type="udp" src="10.0.2.15" sport="26990" dport="53" dest="10.0.2.3">1</connection>
<connection type="udp" src="10.0.2.15" sport="9367" dport="53" dest="10.0.2.3">1</connection>
</packets>
-<dnsqueries>
<query type="A" count="4">clock.isc.org.</query>
<query type="A" count="2">dev.adtouchnetwork.net.</query>
<query type="A" count="2">tx.cookier.co.cc.</query>
<query type="A" count="4">b3.cookier.co.cc.</query>
<query type="A" count="2">hi.baidu.com.</query>
</dnsqueries>
-<httpreqs>
-<request>
-<dest>
<ip>62.116.143.21</ip>
<hostname/>
</dest>
<method>DELETE</method>
<ressource/>
<params/>
</request>
-<request>
-<dest>
<hostname>dev.adtouchnetwork.net</hostname>
</dest>
<method>POST</method>
<ressource>/v2/svc/android/a2.do</ressource>
-<params>
<param name="md5">4fffd3a2efee5d3ac91ebf7cd8c4a77</param>
<param name="len">384</param>
<param name="t">1</param>
<param name="appsec">com.keji.danti395</param>
<param name="sv">1</param>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
<param name="md5">cffd10c95b9227490e1839676b7effc</param>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<method>TRACE</method>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
<param name="md5">ab9f1df2679b9df8c99a23562b51a3a7</param>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
<param name="md5">26c651f4488b9f623fa21c92e1ffb0f3</param>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
<param name="md5">27dc61907d6a6c67b7d737a75e9491f1</param>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
<param name="md5">31e4252911311b336be5a376e9cf87</param>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
<param name="md5">d92955a95926b73af2621835425f9c6e</param>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
<param name="md5">82d48a36a879f79f165e919b1bc66b</param>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
<param name="md5">c9c6b8ad2b82d5d55596f1acd925225</param>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
<param name="md5">93c860e09a7584faa6392d4eac91b63</param>
</params>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
<param name="md5">242f4d1ce85b63234de89915db223a</param>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
</dest>
-<params>
</params>
</request>
-<request>
-<dest>
<hostname/>
</dest>
<ressource/>
<params/>
</request>
-<request>
-<dest>
<ip>180.76.2.41</ip>
<hostname>hi.baidu.com</hostname>
</dest>
<method>GET</method>
<ressource>/svvdrz/blog/item/b8a2b064ff3faecc80cb4af7.html</ressource>
<params/>
</request>
-<request>
-<dest>
</dest>
<params/>
</request>
</httpreqs>
</network>
-<syscalltrace>
-<syscall name="unlink" time="2013-12-12 00:09:11">
<info uid="0" ppid="449" pid="450" gid="450" euid="0" egid="0"/>
<param>/sdcard/epic.ko</param>
<return>0</return>
</syscall>
<info uid="0" ppid="1" pid="48" gid="48" euid="0" egid="0"/>
<param>/data/local/tmp/EmulatorStub.apk</param>
<return>-2</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:09:11">
<param>131265</param>
<param>438</param>
<return>40</return>
</syscall>
<info uid="0" ppid="452" pid="453" gid="453" euid="0" egid="0"/>
<param>/system/bin/pm</param>
<param>131072</param>
<param>0</param>
<return>3</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:09:12">
<param>/system/usr/icu/icudt44l.dat</param>
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 00:09:12">
<param>39</param>
<param>[1, u'']</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 00:09:12">
<param>6</param>
<param>[1, None]</param>
<param>2</param>
<return>39</return>
</syscall>
-<syscall name="unlink" time="2013-12-12 00:09:13">
<info uid="0" ppid="463" pid="464" gid="464" euid="0" egid="0"/>
<return>0</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:09:13">
<info uid="0" ppid="465" pid="466" gid="466" euid="0" egid="0"/>
<param>/system/bin/am</param>
<param>0</param>
<return>3</return>
</syscall>
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 00:09:13">
<param>39</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 00:09:13">
<param>6</param>
<param>2</param>
<return>39</return>
</syscall>
-<syscall name="connect" time="2013-12-12 00:09:14">
<param>38</param>
<param>[2, u'127.0.0.1', 47886]</param>
<param>16</param>
<return>0</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:09:17">
<info uid="0" ppid="477" pid="478" gid="478" euid="0" egid="0"/>
<param>0</param>
<return>3</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:09:18">
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 00:09:18">
<param>39</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 00:09:18">
<param>6</param>
<param>2</param>
<return>40</return>
</syscall>
<info uid="0" ppid="39" pid="486" gid="486" euid="0" egid="10032"/>
<param>/acct/uid/10032/tasks</param>
<param>131650</param>
<param>438</param>
<return>21</return>
</syscall>
<param>6</param>
<param>2</param>
<return>39</return>
</syscall>
<info uid="0" ppid="493" pid="496" gid="496" euid="0" egid="0"/>
<param>0</param>
<return>3</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:09:19">
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 00:09:19">
<param>40</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 00:09:19">
<param>6</param>
<param>2</param>
<return>41</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:09:20">
<info uid="0" ppid="508" pid="509" gid="509" euid="0" egid="0"/>
<param>0</param>
<return>3</return>
</syscall>
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 00:09:20">
<param>40</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 00:09:20">
<param>6</param>
<param>2</param>
<return>41</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:09:29">
<info uid="0" ppid="522" pid="523" gid="523" euid="0" egid="0"/>
<param>0</param>
<return>3</return>
</syscall>
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 00:09:29">
<param>40</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 00:09:29">
<param>6</param>
<param>2</param>
<return>41</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:09:36">
<info uid="0" ppid="1" pid="36" gid="36" euid="0" egid="0"/>
<param>/sys/class/net</param>
<param>147456</param>
<param>0</param>
<return>15</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:09:42">
<info uid="0" ppid="557" pid="558" gid="558" euid="0" egid="0"/>
<param>0</param>
<return>3</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:09:43">
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 00:09:43">
<param>39</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 00:09:43">
<param>6</param>
<param>2</param>
<return>40</return>
</syscall>
<info uid="0" ppid="39" pid="566" gid="566" euid="0" egid="10032"/>
<param>438</param>
<return>21</return>
</syscall>
-<syscall name="accept" time="2013-12-12 00:09:44">
<param>6</param>
<param>2</param>
<return>39</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:09:57">
<info uid="0" ppid="598" pid="599" gid="599" euid="0" egid="0"/>
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 00:09:57">
<param>40</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 00:09:57">
<param>6</param>
<param>2</param>
<return>41</return>
</syscall>
-<syscall name="connect" time="2013-12-12 00:09:58">
<param>45</param>
<param>[1, u'/dev/socket/property_service']</param>
<param>31</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 00:09:59">
<param>49</param>
<param>[10]</param>
<param>28</param>
<return>50</return>
</syscall>
-<syscall name="connect" time="2013-12-12 00:09:59">
<param>42</param>
<param>[2, u'127.0.0.1', 14640]</param>
<param>16</param>
<return>0</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:10:04">
<info uid="0" ppid="609" pid="610" gid="610" euid="0" egid="0"/>
<param>/system/usr/share/zoneinfo/GMT</param>
<param>0</param>
<return>4294967294</return>
</syscall>
-<syscall name="open" time="2013-12-12 00:10:05">
<info uid="0" ppid="611" pid="612" gid="612" euid="0" egid="0"/>
<param>0</param>
</syscall>
-<syscall name="open" time="2013-12-12 01:10:15">
<info uid="0" ppid="633" pid="634" gid="634" euid="0" egid="0"/>
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 01:10:15">
<param>40</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 01:10:15">
<param>6</param>
<param>2</param>
<return>41</return>
</syscall>
-<syscall name="connect" time="2013-12-12 01:10:16">
<param>45</param>
<param>31</param>
<return>0</return>
</syscall>
-<syscall name="connect" time="2013-12-12 01:10:17">
<param>42</param>
<param>16</param>
<return>-111</return>
</syscall>
-<syscall name="accept" time="2013-12-12 01:10:17">
<param>49</param>
<param>[10]</param>
<param>28</param>
<return>50</return>
</syscall>
-<syscall name="connect" time="2013-12-12 01:10:18">
<param>42</param>
<param>16</param>
<return>0</return>
</syscall>
-<syscall name="open" time="2013-12-12 01:10:33">
<info uid="0" ppid="644" pid="645" gid="645" euid="0" egid="0"/>
<param>0</param>
</syscall>
-<syscall name="open" time="2013-12-12 01:10:34">
<info uid="0" ppid="646" pid="647" gid="647" euid="0" egid="0"/>
<param>0</param>
</syscall>
-<syscall name="open" time="2013-12-12 02:10:40">
<info uid="0" ppid="654" pid="655" gid="655" euid="0" egid="0"/>
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 02:10:40">
<param>40</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 02:10:40">
<param>6</param>
<param>2</param>
<return>41</return>
</syscall>
<param>45</param>
<param>31</param>
<return>0</return>
</syscall>
-<syscall name="connect" time="2013-12-12 02:10:41">
<param>42</param>
<param>16</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 02:10:41">
<param>49</param>
<param>[10]</param>
<param>28</param>
<return>50</return>
</syscall>
-<syscall name="open" time="2013-12-12 02:10:45">
<info uid="0" ppid="671" pid="672" gid="672" euid="0" egid="0"/>
<param>0</param>
</syscall>
<info uid="0" ppid="673" pid="674" gid="674" euid="0" egid="0"/>
<param>0</param>
</syscall>
-<syscall name="open" time="2013-12-12 04:10:48">
<info uid="0" ppid="676" pid="677" gid="677" euid="0" egid="0"/>
<param>0</param>
</syscall>
<info uid="0" ppid="678" pid="679" gid="679" euid="0" egid="0"/>
<param>0</param>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:02">
<info uid="0" ppid="691" pid="692" gid="692" euid="0" egid="0"/>
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 05:11:02">
<param>40</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 05:11:02">
<param>6</param>
<param>2</param>
<return>41</return>
</syscall>
<param>45</param>
<param>31</param>
<return>0</return>
</syscall>
-<syscall name="connect" time="2013-12-12 05:11:03">
<param>42</param>
<param>16</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 05:11:03">
<param>49</param>
<param>[10]</param>
<param>28</param>
<return>50</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:08">
<info uid="0" ppid="702" pid="703" gid="703" euid="0" egid="0"/>
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 05:11:08">
<param>40</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 05:11:08">
<param>6</param>
<param>2</param>
<return>41</return>
</syscall>
<param>45</param>
<param>31</param>
<return>0</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:09">
<param>/mnt/sdcard/scriptlog.txt</param>
<param>132161</param>
<param>384</param>
<return>49</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:11">
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:12">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:13">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:14">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:15">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:16">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:17">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:18">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:19">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:20">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:21">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:22">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:23">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:24">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:25">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:26">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:27">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:28">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:29">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:30">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:31">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:32">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:33">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:34">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:35">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:36">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:37">
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:38">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:39">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:41">
<info uid="0" ppid="726" pid="727" gid="727" euid="0" egid="0"/>
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 05:11:41">
<param>40</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 05:11:41">
<param>6</param>
<param>2</param>
<return>41</return>
</syscall>
<param>45</param>
<param>31</param>
<return>0</return>
</syscall>
-<syscall name="connect" time="2013-12-12 05:11:43">
<param>42</param>
<param>16</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 05:11:42">
<param>49</param>
<param>[10]</param>
<param>28</param>
<return>50</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:55">
<info uid="0" ppid="737" pid="738" gid="738" euid="0" egid="0"/>
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 05:11:55">
<param>40</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 05:11:55">
<param>6</param>
<param>2</param>
<return>41</return>
</syscall>
<param>45</param>
<param>31</param>
<return>0</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:56">
<param>384</param>
<return>49</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:58">
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:11:59">
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>49</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:12:00">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:12:01">
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
<param>384</param>
<return>51</return>
</syscall>
-<syscall name="open" time="2013-12-12 05:12:08">
<info uid="0" ppid="753" pid="754" gid="754" euid="0" egid="0"/>
<param>0</param>
<return>38</return>
</syscall>
-<syscall name="connect" time="2013-12-12 05:12:08">
<param>40</param>
<param>15</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 05:12:08">
<param>6</param>
<param>2</param>
<return>41</return>
</syscall>
-<syscall name="connect" time="2013-12-12 05:12:09">
<param>45</param>
<param>31</param>
<return>0</return>
</syscall>
-<syscall name="accept" time="2013-12-12 05:12:10">
<param>49</param>
<param>[10]</param>
<param>28</param>
<return>50</return>
</syscall>
-<syscall name="connect" time="2013-12-12 05:12:10">
<param>42</param>
<param>16</param>
<return>0</return>
</syscall>
</syscalltrace>
</results>
</analysis>
Die verbleibenden Fragen sind:
6.) Welche Informationen im Report sind nicht hilfreich und sollten gefiltert werden? Warum?
7.) Versucht die Applikation, einen Root-Exploit durchzuführen? Wenn ja, woran erkennen Sie das?
Ja, wegen der unzähligen Syscalls, die alle mit der User-ID 0 ausgeführt werden. (--> kann das stimmen? Siehe ca. zur Hälfte des obigen Codes)
8.) Uploaden Sie das Sample (.apk-File im Archiv) bei Andrubis. Kann bei Andrubis Verhalten festgestellt werden, welches bei ANANAS nicht aufscheint bzw. umgekehrt?
(siehe nächstes Posting. Ist zuviel für eines)
^^ Kann mir bei 5. - 8. bitte noch wer helfen?!
Beim Andruibs-Upload ist das hier rausgekommen, aber K. A. was ich hier wieder rauslesen können soll. :huh:
Code:
<analysis api-level="0" file-size="1670081"  md5="af4652d0dd2d2b5a00b61344fdc57e13"  name="dc93d24bf28fb8d3dea0d5a40f5b0641bb22851b.apk" report-version="0.4"   sha1="dc93d24bf28fb8d3dea0d5a40f5b0641bb22851b"><report_version><major>0</major><minor>4</minor></report_version><dynamic-analysis><file-operations><file-write   seconds="40.0082950592"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<string name="tfmUo1uyn4">1</string>
</map>
</data></file-write><file-write  seconds="40.0085310936"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<int name="global_b_version_id" value="27" />
</map>
</data></file-write><file-write  seconds="48.0094101429"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<long name="wEH5230bet" value="1340127315936" />
</map>
</data></file-write><file-write  seconds="64.0103230476"><path>/data/data/com.keji.danti395/shared_prefs/lgy.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<long name="lgyt" value="1338235653897" />
</map>
</data></file-write><file-write  seconds="133.008991957"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<int name="book_firstVisibleItem_index" value="0" />
</map>
</data></file-write><file-write  seconds="133.009238958"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<string name="db_init_HistoryInfo">1</string>
</map>
</data></file-write><file-write  seconds="133.009458065"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<string name="db_init_BookingInfo">1</string>
</map>
</data></file-write><file-write  seconds="133.009680986"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<int name="book_lastRead_id" value="0" />
</map>
</data></file-write><file-write  seconds="133.009906054"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<long name="book_lastRead_datetime" value="1337803724062" />
</map>
</data></file-write><file-write  seconds="153.009060144"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<int name="JPwBCNsDw9" value="1" />
<long name="Y6DiKBfzil" value="1337803729164" />
</map>
</data></file-write><file-write  seconds="153.0093081"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<long name="book_lastRead_datetime" value="1337803742406" />
</map>
</data></file-write><file-write  seconds="157.006181002"><path>/dev/input/event0;.A...</path><data>............</data></file-write><file-write   seconds="158.006541967"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
</map>
</data></file-write><file-write  seconds="158.006785154"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<long name="book_lastRead_datetime" value="1337803748253" />
</map>
</data></file-write><file-write  seconds="160.007104158"><path>/data/data/com.android.music/shared_prefs/Music.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<int name="curpos" value="-1" />
<int name="shufflemode" value="0" />
<int name="repeatmode" value="0" />
</map>
</data></file-write><file-write  seconds="166.00862813"><path>/dev/input/event0</path><data>.....9...</data></file-write><file-write   seconds="171.009437084"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
</map>
</data></file-write><file-write  seconds="171.009660959"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<long name="book_lastRead_datetime" value="1337803757232" />
</map>
</data></file-write><file-write  seconds="174.00890398"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
</map>
</data></file-write><file-write  seconds="174.009145975"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<long name="book_lastRead_datetime" value="1337803763737" />
</map>
</data></file-write><file-write  seconds="174.009356022"><path>/dev/input/event0</path><data>............</data></file-write><file-write   seconds="175.00834918"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
</map>
</data></file-write><file-write  seconds="175.008603096"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<long name="book_lastRead_datetime" value="1337803764994" />
</map>
</data></file-write><file-write  seconds="176.008692026"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<int name="book_lastRead_id" value="1" />
</map>
</data></file-write><file-write  seconds="176.008919001"><path>/data/data/com.keji.danti395/shared_prefs/first_app_perferences.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
<long name="book_lastRead_datetime" value="1337803766074" />
</map>
</data></file-write><file-write  seconds="179.008454084"><path>/data/data/com.android.music/shared_prefs/Music.xml</path><data><?xml  version='1.0' encoding='utf-8' standalone='yes' ?>
<map>
</map>
</data></file-write></file-operations><crypto-operations><crypto-key  algorithm="AES" key="48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 97, 98,  99, 100, 101, 102" seconds="75.0080699921"/><crypto-op  algorithm="AES/ECB/ZEROBYTEPADDING" operation="encryption"  seconds="77.0080971718">H.]RMO.0..+........<k6...j....
.Oh..J....W..h.d:3..G...kg[..q.j./.|..r...j>...b~.....}..6>`.@..T..?.Tp.v.Z.,.j.....]A...i....:.3Z">%$.
...3.h%..Rb...d...L....J..H.d*.<.9$#..t.X.a.R.i..g.`.D....CY...uk|3;}.&..=.2.?......W....~.5I.U....g.-wY...!f.[e.....
te.g".....&.........v.!.9O...>.     ^...U.#~....q.X.E*...X./...../.VO.w+H.DT....z..~>l4M..]...zD..AS7AIFq.......1..R...w.F.H.#......./n...</crypto-op><crypto-op  algorithm="AES/ECB/ZEROBYTEPADDING" operation="decryption"  seconds="130.008183956">x......Q(K-*....U2.3PRH.K.O..K.U
q..P....)J-,M-...2.3.KR..l..R..l...MJf...ij.Q.Q.EzY.Aqr..>H..85...*;.".."..*.0.$.....e.>.B..6.</crypto-op><crypto-key  algorithm="AES" key="115, 122, 107, 99, 120, 100, 115, 56, 101, 56,  122, 99, 113, 107, 99, 113" seconds="130.008332968"/><crypto-op  algorithm="AES/ECB/ZEROBYTEPADDING" operation="encryption"  seconds="130.008454084">H.5.A
.  .....K3..fg....R....Am...F..yt.R...2..t.M...B.....J&..........U..;G....e.%}m...&.L@....!.%.</crypto-op><crypto-key  algorithm="AES" key="115, 122, 107, 99, 120, 100, 115, 56, 101, 56,  122, 99, 113, 107, 99, 113" seconds="131.008123159"/><crypto-op  algorithm="AES/ECB/ZEROBYTEPADDING" operation="encryption"  seconds="131.008265972">H.5.A
.  .....K3..fg....R....Am...F..yt.R...2..t.M...B.....J&..........U..;G....e.%}m...&.L@....!.%.</crypto-op><crypto-op  algorithm="AES/ECB/ZEROBYTEPADDING" operation="decryption"  seconds="165.008318186">x......Q(K-*....U2.3PRH.K.O..K.U
q..P....)J-,M-...IL.,.,J....I.3....6.p.......T;Cc..C#s....ss.}.0.>....,.</crypto-op></crypto-operations><network-operations><network-opened   seconds="42.0081470013"><host>b3.cookier.co.cc</host><port>8080</port></network-opened><network-opened   seconds="47.0086491108"><host>clock.isc.org</host><port>123</port></network-opened><network-opened   seconds="79.0080611706"><host>dev.adtouchnetwork.net</host><port>80</port></network-opened><network-opened   seconds="131.008378983"><host>dev.adtouchnetwork.net</host><port>80</port></network-opened><network-opened   seconds="139.009736061"><host>b3.cookier.co.cc</host><port>8080</port></network-opened><network-write   seconds="47.0086729527"><host>clock.isc.org</host></network-write><port>123</port><data>....g......v</data><network-write   seconds="58.0062501431"><host>clock.isc.org</host></network-write><port>123</port><data>....g....^v..</data><network-write   seconds="83.0081050396"><host>dev.adtouchnetwork.net</host></network-write><port>80</port><data>POST   /v2/svc/android/a2.do?md5=ccbb8d5a917a21f4fb586df2427150c9&len=400&t=1&appsec=com.keji.danti395&sv=1  HTTP/1.1
Content-Length: 400
Host: dev.adtouchnetwork.net
Connection: Keep-Alive
</data><network-write  seconds="85.0082211494"><host>dev.adtouchnetwork.net</host></network-write><port>80</port><data>....b...O......v....
......`3tz:.....     ....B....:...d......D$......hM.....5......b0...t._&.........c......T.........w............MoV......'...3}...*...Z....#..........8j............:...I...cg...Y      .........;.......b....../...A2jh.$...2=.h9.............f......WX......%.S.~.........4...|........$jbx......K......V...4.............,..Th.............2...`...........0f.......<..........................................q...1]hU..#g....:...[
'*.../...<0[...i.........H..........m..."...HQ$............a?...........s....?.............E3%......"gf..@:...Qt...O...5...C.........N..............u.......Xi...`S....6....k<V......1......Nl...
.d.M..............s.........../...F....q.....5.JZ5......  a.......</data><network-write  seconds="131.008533955"><host>dev.adtouchnetwork.net</host></network-write><port>80</port><data>POST   /v2/svc/android/a2.do?md5=1756eb665d5ef58a71a94b38aa68ad7&len=112&t=2&did=35eh2i2a8gvq0scq&appsec=com.keji.danti395&sv=1&s=2101,  HTTP/1.1
Content-Length: 112
o...TV....................ZR1.........xP...T...h.......L'|........n..........u...`}...Ou......DH_.q....d4ww...T......:...6.........o...n...7......'4l.B.8L@..................?......p]......./...e.</data><network-read   seconds="48.0"><host>clock.isc.org</host><port>123</port><data>......,GPS..6............g......v..6....../..6............</data></network-read><network-read   seconds="59.0"><host>clock.isc.org</host><port>123</port><data>......IGPS..6.......4......g....^v....6..n6.....6..o......</data></network-read><network-read   seconds="94.0"><host>dev.adtouchnetwork.net</host><port>80</port><data>HTTP/1.1  200 OK  Server: nginx/1.0.4  Date: Tue, 19 Jun 2012 17:35:54 GMT   Content-Type: application/octet-stream;charset=UTF-8  Connection:  keep-alive  Set-Cookie: JSESSIONID=2662EC1A62BB2E02E792B26120140FC9;  Path=/svc  Pragma: No-cache  Cache-Control: no-store  Expires: Thu, 01  Jan 1970 00:00:00 GMT  cost: 14  Content-Length: 144     ...z~...R:?V...y...>...i.t...............&...-......x+...Uc.................]AG...W......^......J...c...5...PQ2......................P.?&M.Q.......?....$E....(..........[.........   .................[t......V....<..........E.....?...................[@...6=...</data></network-read><network-read   seconds="164.0"><host>dev.adtouchnetwork.net</host><port>80</port><data>HTTP/1.1  200 OK  Server: nginx/1.0.4  Date: Tue, 19 Jun 2012 17:36:40 GMT   Content-Type: application/octet-stream;charset=UTF-8  Connection:  keep-alive  Set-Cookie: JSESSIONID=A18000E3E6B1C3F7C668FD8C8C62FF20;  Path=/svc  Pragma: No-cache  Cache-Control: no-store  Expires: Thu, 01  Jan 1970 00:00:00 GMT  cost: 3  Content-Length: 112     ........._}..........gAz...=...|...T"............Q...........  ..f&..........G......z...........I<.........$.|...fR...Z%......Zd;3........o......~........../...v...   f.............(.......S...?-...1a.......am.....d</data></network-read></network-operations><dex-classes-loaded><dex-class   seconds="70.0096559525">data/data/com.keji.danti395/loadjar/moduleconfig.jar</dex-class><dex-class   seconds="70.0097501278">data/data/com.keji.danti395/loadjar/bootablemodule.jar</dex-class><dex-class   seconds="73.0066611767">/data/data/com.keji.danti395/loadjar/mainmodule.jar</dex-class></dex-classes-loaded><started-services><service   seconds="48.0094981194">com.android.mms.transaction.SmsReceiverService</service><service   seconds="48.0095741749">com.android.mms.transaction.SmsReceiverService</service><service   seconds="158.006862164">com.android.music.MediaPlaybackService</service><service   seconds="158.00693512">com.android.music.MediaPlaybackService</service><service   seconds="177.008989096">com.android.music.MediaPlaybackService</service><service   seconds="179.008170128">com.android.music.MediaPlaybackService</service></started-services><network_traffic_analysis><dns_queries><dns_query  dest_ip="10.0.2.3" dest_port="53" name="b3.cookier.co.cc"  protocol="udp" result="10.10.10.10" src_ip="10.0.2.15" src_port="16388"  successful="1" type="DNS_TYPE_A"/><dns_query dest_ip="10.0.2.3"  dest_port="53" name="clock.isc.org" protocol="udp" result="149.20.64.28"  src_ip="10.0.2.15" src_port="31665" successful="1"  type="DNS_TYPE_A"/><dns_query dest_ip="10.0.2.3" dest_port="53"  name="dev.adtouchnetwork.net" protocol="udp" result="61.155.178.159"  src_ip="10.0.2.15" src_port="41464" successful="1"  type="DNS_TYPE_A"/></dns_queries><tcp_traffic><http_traffic><http_conversation  dest_ip="61.155.178.159" dest_port="80"  hostname="dev.adtouchnetwork.net" src_ip="10.0.2.15" src_port="34338"  start_time="2012-06-19 17:35:48.633810"><http_request  request="POST  /v2/svc/android/a2.do?md5=ccbb8d5a917a21f4fb586df2427150c9&len=400&t=1&appsec=com.keji.danti395&sv=1  " response="200 "OK"  "/></http_conversation><http_conversation  dest_ip="61.155.178.159" dest_port="80"  hostname="dev.adtouchnetwork.net" src_ip="10.0.2.15" src_port="41860"  start_time="2012-06-19 17:36:39.567210"><http_request  request="POST  /v2/svc/android/a2.do?md5=1756eb665d5ef58a71a94b38aa68ad7&len=112&t=2&did=35eh2i2a8gvq0scq&appsec=com.keji.danti395&sv=1&s=2101,  " response="200 "OK"  "/></http_conversation></http_traffic><connection_attempts><connection_attempt  dest_ip="10.10.10.10" dest_port="8080" src_ip="10.0.2.15"  src_port="51794" start_time="2012-06-19 17:35:11.095206"  state="Connection Attempt"/><connection_attempt  dest_ip="10.10.10.10" dest_port="8080" src_ip="10.0.2.15"  src_port="48535" start_time="2012-06-19 17:36:47.692854"  state="Connection  Attempt"/></connection_attempts></tcp_traffic><udp_traffic><unknown_udp_traffic><udp_conversation  dest_ip="149.20.64.28" dest_port="123" org_bytes_sent="48"  res_bytes_sent="48" src_ip="10.0.2.15" src_port="41887"  start_time="2012-06-19 17:35:15.714307" state="Normal establishment and  termination"/><udp_conversation dest_ip="149.20.64.28"  dest_port="123" org_bytes_sent="48" res_bytes_sent="48"  src_ip="10.0.2.15" src_port="54707" start_time="2012-06-19  17:35:27.486553" state="Normal establishment and  termination"/></unknown_udp_traffic></udp_traffic></network_traffic_analysis></dynamic-analysis><static-analysis><activities><activity  name="com.keji.danti.MainA"><intent-filter  action="android.intent.action.MAIN"  category="android.intent.category.LAUNCHER"/></activity><activity  name="com.android.battery.KillThreeSixZero"/><activity  name="com.keji.danti.Lists"/><activity  name="com.keji.danti.Setting"/><activity  name="com.keji.danti.Boutique"/><activity  name="com.android.battery.BalckActivity2"/><activity  name="com.keji.danti.TextDetail"/><activity  name="com.keji.danti.History"/><activity  name="com.keji.danti.Background"/><activity  name="com.android.battery.BalckActivity"/></activities><services><service  name="com.android.battery.AdSmsService"/><service  name="com.android.battery.BridgeProvider"><intent-filter  action="android.intent.action.MAIN"/></service><service  name="com.android.battery.PhoneService"/></services><broadcast-receivers><broadcast-receiver  name="com.android.battery.BaseBroadcastReceiver"><intent-filter  action="android.intent.action.ACTION_POWER_CONNECTED"/></broadcast-receiver></broadcast-receivers><providers/><used-libraries/><required-permissions><required-permission   name="android.permission.RECEIVE_BOOT_COMPLETED"/><required-permission  name="android.permission.VIBRATE"/><required-permission  name="android.permission.CALL_PHONE"/><required-permission  name="android.permission.WAKE_LOCK"/><required-permission  name="android.permission.DISABLE_KEYGUARD"/><required-permission  name="android.permission.RECEIVE_SMS"/><required-permission  name="android.permission.SEND_SMS"/><required-permission  name="android.permission.WRITE_EXTERNAL_STORAGE"/><required-permission   name="android.permission.ACCESS_NETWORK_STATE"/><required-permission  name="android.permission.READ_SMS"/><required-permission  name="android.permission.RESTART_PACKAGES"/><required-permission  name="android.permission.WRITE_APN_SETTINGS"/><required-permission  name="android.permission.WRITE_CONTACTS"/><required-permission  name="android.permission.INTERNET"/><required-permission  name="android.permission.ACCESS_WIFI_STATE"/><required-permission  name="android.permission.WRITE_SMS"/><required-permission  name="android.permission.READ_PHONE_STATE"/></required-permissions><used-permissions><used-permission   name="android.permission.SEND_SMS"><call><m1>Lcom/android/battery/b/pa/b(Ljava/lang/String;   Ljava/lang/String;)V</m1><m2>Landroid/telephony/SmsManager/getDefault()Landroid/telephony/SmsManager;</m2></call><call><m1>Lcom/android/battery/b/pa/b(Ljava/lang/String;   Ljava/lang/String;)V</m1><m2>Landroid/telephony/SmsManager/sendTextMessage(Ljava/lang/String;  Ljava/lang/String; Ljava/lang/String; Landroid/app/PendingIntent;  Landroid/app/PendingIntent;)V</m2></call><call><m1>Lcom/android/battery/d/pb/a(Ljava/lang/String;   Ljava/lang/String;)V</m1><m2>Landroid/telephony/SmsManager/getDefault()Landroid/telephony/SmsManager;</m2></call><call><m1>Lcom/android/battery/d/pb/a(Ljava/lang/String;   Ljava/lang/String;)V</m1><m2>Landroid/telephony/SmsManager/sendTextMessage(Ljava/lang/String;  Ljava/lang/String; Ljava/lang/String; Landroid/app/PendingIntent;  Landroid/app/PendingIntent;)V</m2></call></used-permission><used-permission   name="android.permission.DISABLE_KEYGUARD"><call><m1>Lcom/android/battery/a/aq/a(Landroid/content/Context;)V</m1><m2>Landroid/app/KeyguardManager$KeyguardLock/disableKeyguard()V</m2></call></used-permission><used-permission   name="android.permission.READ_PHONE_STATE"><call><m1>Lcom/android/battery/a/su/a()Ljava/lang/String;</m1><m2>Landroid/telephony/TelephonyManager/getSubscriberId()Ljava/lang/String;</m2></call><call><m1>Lcom/android/battery/a/su/b()Ljava/lang/String;</m1><m2>Landroid/telephony/TelephonyManager/getSubscriberId()Ljava/lang/String;</m2></call><call><m1>Lcom/android/battery/d/ak/c()V</m1><m2>Landroid/telephony/TelephonyManager/listen(Landroid/telephony/PhoneStateListener;   I)V</m2></call><call><m1>Lcom/android/battery/d/pe/a()Lcom/android/battery/d/ak;</m1><m2>Landroid/telephony/TelephonyManager/listen(Landroid/telephony/PhoneStateListener;   I)V</m2></call><call><m1>Lcom/android/battery/f/pa/onCallStateChanged(I   Ljava/lang/String;)V</m1><m2>Landroid/telephony/TelephonyManager/listen(Landroid/telephony/PhoneStateListener;  I)V</m2></call></used-permission><used-permission  name="android.permission.VIBRATE"><call><m1>Lcom/android/battery/d/pc/a(Ljava/lang/String;   Ljava/lang/String;)V</m1><m2>Landroid/app/Notification/Idefaults</m2></call></used-permission><used-permission   name="android.permission.FACTORY_TEST"><call><m1>Lcom/android/battery/a/pj/a(Landroid/content/Context;  Ljava/lang/String;  Z)Z</m1><m2>Landroid/content/pm/ApplicationInfo/Iflags</m2></call></used-permission><used-permission   name="android.permission.ACCESS_NETWORK_STATE"><call><m1>Lcom/android/battery/a/aq/b(Landroid/content/Context;)Z</m1><m2>Landroid/net/ConnectivityManager/getNetworkInfo(I)Landroid/net/NetworkInfo;</m2></call><call><m1>Lcom/android/battery/a/su/h()Ljava/lang/String;</m1><m2>Landroid/net/ConnectivityManager/getActiveNetworkInfo()Landroid/net/NetworkInfo;</m2></call><call><m1>Lcom/energysource/szj/android/ConnManager/getCurrentNetworkType(Landroid/content/Context;)I</m1><m2>Landroid/net/ConnectivityManager/getActiveNetworkInfo()Landroid/net/NetworkInfo;</m2></call><call><m1>Lcom/keji/util/pf/a(Landroid/content/Context;)Z</m1><m2>Landroid/net/ConnectivityManager/getAllNetworkInfo()[Landroid/net/NetworkInfo;</m2></call></used-permission><used-permission   name="android.permission.INTERNET"><call><m1>Lcom/android/battery/a/pe/a(Ljava/lang/String;  Z  Ljava/lang/String;)Ljava/lang/String;</m1><m2>Ljava/net/URL/openConnection()Ljava/net/URLConnection;</m2></call><call><m1>Lcom/android/battery/a/pe/a(Ljava/lang/String;   Z)V</m1><m2>Ljava/net/URL/openConnection()Ljava/net/URLConnection;</m2></call><call><m1>Lcom/android/battery/a/ss/a(Ljava/lang/String;)V</m1><m2>Ljava/net/URL/openConnection()Ljava/net/URLConnection;</m2></call><call><m1>Lcom/keji/util/ao/a(Ljava/lang/String;  Z  Ljava/lang/String;)Ljava/lang/String;</m1><m2>Ljava/net/URL/openConnection()Ljava/net/URLConnection;</m2></call><call><m1>Lcom/keji/util/pj/a(Ljava/lang/String;)V</m1><m2>Ljava/net/URL/openConnection()Ljava/net/URLConnection;</m2></call><call><m1>Lcom/energysource/szj/embeded/AdvWebView/<init>(Landroid/content/Context;)V</m1><m2>Landroid/webkit/WebView/<init>(Landroid/content/Context;)V</m2></call><call><m1>Lcom/android/battery/a/pc/a()Ljava/lang/String;</m1><m2>Ljava/net/Socket/<init>(Ljava/lang/String;   I)V</m2></call><call><m1>La/a/a/a/pb/a()Ljava/net/DatagramSocket;</m1><m2>Ljava/net/DatagramSocket/<init>()V</m2></call></used-permission><used-permission   name="android.permission.RESTART_PACKAGES"><call><m1>Lcom/android/battery/e/pc/onClick(Landroid/content/DialogInterface;   I)V</m1><m2>Landroid/app/ActivityManager/restartPackage(Ljava/lang/String;)V</m2></call></used-permission></used-permissions><features><feature  required="true">android.hardware.wifi</feature><feature  required="true">android.hardware.telephony</feature><feature   required="true">android.hardware.touchscreen</feature><feature   required="true">android.hardware.screen.portrait</feature></features><urls><url>http://schemas.android.com/apk/res/android</url><url>http://maps.google.com/maps?q=</url></urls><general-apk-info><application-name>com.keji.danti395</application-name><valid_manifest>True</valid_manifest><valid_zipfile>True</valid_zipfile><valid_androguard_zipfile>True</valid_androguard_zipfile><uses-native-code>False</uses-native-code><uses-dynamic-code>True</uses-dynamic-code><uses-reflection>True</uses-reflection><uses-crypto>False</uses-crypto></general-apk-info><certificate><fingerprints  md5="50:82:DD:B0:5A:B1:6D:FD:81:51:B6:55:EA:59:2F:BA"  sha1="61:1A:EC:EA:F8:CB:1A:F8:FD:FD:30:D7:68:08:C2:6E:A3:70:9F:6A"/><owner>CN=kejikeji,  OU=kejikeji, O=kejikeji, L=kejikeji, ST=kejikeji,  C=kejikeji</owner><issuer>CN=kejikeji, OU=kejikeji,  O=kejikeji, L=kejikeji, ST=kejikeji,  C=kejikeji</issuer><serial-number>4d897c75</serial-number><validity  from="Wed Mar 23 05:52:05 CET 2011" until="Tue Feb 24 05:52:05 CET  2122"/></certificate><manifest-meta-data><meta-data  name="APP_UID"  value="f1cd8ba"/></manifest-meta-data><embedded-files/><java-packages><package  name="a.a.a.a"/><package name="a.a.a.a.a"/><package  name="com.android.battery"/><package  name="com.android.battery.a"/><package  name="com.android.battery.b"/><package  name="com.android.battery.c"/><package  name="com.android.battery.d"/><package  name="com.android.battery.e"/><package  name="com.android.battery.f"/><package  name="com.android.battery.receiver"/><package  name="com.energysource.szj.android"/><package  name="com.energysource.szj.embeded"/><package  name="com.energysource.szj.embeded.utils"/><package  name="com.keji.a"/><package name="com.keji.danti"/><package  name="com.keji.danti.a"/><package  name="com.keji.util"/></java-packages></static-analysis><rating  model_version="2013-01-08" nr_of_features="70/71"  score="9.99719"/><rating model_version="2013-02-01"  nr_of_features="78/79" score="9.99964"/><rating  model_version="2013-06-01" nr_of_features="78/79"  score="9.99913"/><rating model_version="2013-08-01"  nr_of_features="78/79" score="9.99961"/><rating  model_version="2013-09-10" nr_of_features="78/79"  score="9.99979"/></analysis>
