AMD CCC 11.7 und 11.8 Preview veröffentlicht
Own3r
Volt-Modder(in)
amd-jpg.446862
Das Catalyst Control Center Version 11.7 ist heute veröffentlicht worden!
Download findet sich hier
Changelog und known issues:
Resolved Issues for the Windows 7 Operating System
This section provides information on resolved known issues in this release of the AMD Catalyst 11.7 software suite for Windows 7. These include:
  • All issues experienced with mouse cursor lag have been resolved
  • Resolves system hangs seen in the AMD Catalyst 11.6 driver on specific HDMI and DP displays
  • Log event (Event ID 62464) issues when playing video content have been resolved
  • Bluray playback using PowerDVD 10 under High Performance mode no longer randomly displays a blank screen.
  • Bluray playback using PowerDVD 10 under High Performance mode no longer randomly hangs.
  • Some Divx format files no longer display video corruption using WinDVD.
  • AVIVO Video Quality settings are now correctly applied to Flash Video Content.
  • AMD SteadyVideo is now applied to Home Video clips when using WinDVD 10.
  • Random screen corruption is no longer displayed when changing desktop themes.
  • Chequerboard corruption is no longer displayed intermittently when playing DirectX 10 titles in a Crossfire configuration with Eyefinity enabled.
  • Shogun II now renders the cinematics correctly when run in various Eyefinity configurations.
  • Video playback now works correctly when Hardware acceleration is enabled with VLC Player version 1.1.9.
  • 720P Divx video clips no longer display stuttering when played using Windows Media Center and Windows Media Player.
  • Crossfire now functions correctly when playing Hamilton’s Great Adventure.
  • Video corruption is no longer observed when when using the Forward slider on 720P Divx format video clips using Windows Media Player and Windows Media Center.
  • PowerDVD now correctly handles 3D Bluray content.
  • Portal 2 no longer displays flickering on water surface textures with Medium and Low Shader detail settings.
  • Image stabilization now functions correctly when playing Divx content using Windows Media Player.
  • Wraparound corruption is no longer displayed intermittently after exiting a 3D application.
Known issues under the Windows 7 operating system
The following section provides a summary of open issues that may be experienced under the Windows 7 operating system in the latest version of AMD Catalyst. These include:
  • Star Wars Jedi Knight II / Jedi Academy may randomly crash on launch.
  • Image rotation might not function correctly in Photoshop CS5.
  • OpenGL acceleration might not be available in Photoshop CS5.
  • High GPU speeds might be retained after exiting a 3D application.
  • Crysis 2 may display random corruption when Crossfire is enabled and run in DirectX 9 mode
  • Homefront may experience random crashes during gameplay.
  • Crossfire may not perform as expected when playing Earthsim, Bad Company 2 and Metro 2003 under DirectX 11 mode.
Known Issues under the Windows Vista Operating System
The following section provides a summary of open issues that may be experienced under the Windows Vista operating system in the latest version of AMD Catalyst. These include:
  • PowerDVD may display a blank screen during Bluray playback when Crossfire is enabled.
  • Doom 3 and Quake 4 may display random screen corruption.
  • Performing Bezel compensation in certain Eyefinity configurations may cause some bezel groups to not appear.
  • Windows Aero options may no longer be available after installing the driver.
Zudem ist die Preview Version des Catalyst Control Center 11.8 downloadbar (KLICK)
Änderungen zusätzlich der des 11.7:
  • Enables AMD HD3D technology support on DisplayPort panels, such as Samsung 750 and 950 series 3D displays
  • Improves performance:
    • Up to 10% in Crysis 2 DirectX 11 version for both non-Anti-Aliasing, and application enabled Anti-Aliasing cases on the AMD Radeon™ HD 6000 and AMD Radeon HD 5000 series of products
    • Up to 8% in Fear 3 DirectX 11 version with application enabled Anti-Aliasing on the AMD Radeon HD 6000 and AMD Radeon HD 5000 series of products
    • Up to 30% when AMD’s Morphological Anti-Aliasing (MLAA) is enabled through the Catalyst Control Center on AMD Radeon HD 6000 and AMD Radeon HD 5000 series of products
Ich habe ihn schon installiert und konnte keine Probleme feststellen :)
Ich hoffe, dass er auch bei euch ohne Probleme läuft!
AW: AMD CCC 11.7 und 11.8 Preview veröffentlicht
Der Download lohnt sich net, in 1-2 Tagen kommt eh wieder der Hotfix raus.
:ugly: Hmmm, gestern hatte ich den 11.6 gezogen. Hätte ich mal besser noch nen Tag gewartet.
So habe den 11.8 installiert. Läuft super und gibt auch einen ordentlichen Geschwindigkeitsboost ;)
10% sind wahrscheinlich mindestens gegeben ;)
Bisher keine Probleme mit dem 11.8. Warum die WHQL-Zertifizierung immer nur so lange braucht :schief:
Hmm lese gar nichts über Llano im Changelog oO
(habe ja einen A8-3850)
bringt der 11.8er preview echt so viel? Hat keiner irgendwelche Probs?
Den letzten Preview den ich hatte da hatte ich in einigen games n paar textur probleme, nix schlimmes aber hat halt manchmal genervt
Ich bin gespannt.
Heute Abend werde ich beide ausprobieren.
Ich hatte bei Metro 2033 mit der 11.7 Preview und dem 11.6b akute Probleme, das Spiel schmierte immer ab.
Auch als ich die Taktsteigerung zurückgenommen, habe wollte das Spiel nimmer.
MfG Andy
